Home » Modeling » Graphiti » Scrolling / zooming programmatically
Scrolling / zooming programmatically [message #725212] Wed, 14 September 2011 05:12 Go to next message
I am setting the selection programmatically, which works fine. However, I want to make sure that all selected elements are visible. Is there a way to programmatically scroll / zoom the diagram in the editor?
Andreas
Re: Scrolling / zooming programmatically [message #725214 is a reply to message #725212] Wed, 14 September 2011 05:14 Go to previous messageGo to next message
Andreas,
I have set the selection programmatically as well. In my case Graphiti automatically scrolls the diagram to make the selected element visible. I did this for a single selection only. Doesn't this work for you? If so, how do you program the selection?
Jos
Re: Scrolling / zooming programmatically [message #725245 is a reply to message #725214] Wed, 14 September 2011 07:10 Go to previous messageGo to next message
Hi Jos,
here is my code:
 public void execute(ICustomContext context) {
    	PictogramElement[] pes = context.getPictogramElements();
    	if (pes != null && pes.length == 1) {
           PictogramElement pe = pes[0];
           if(pe instanceof Connection)
        	   Anchor sa = ((Connection) pe).getStart();
        	   Anchor se = ((Connection) pe).getEnd();
        	   getFeatureProvider().getDiagramTypeProvider().getDiagramEditor().selectPictogramElements(new PictogramElement[] {
        			   sa.getParent(),
        			   se.getParent()
(I am selecting the peers of a connection).
However, there is no scrolling in this case. (see attached screenshot).
If I reverse the order of pictogram elements, (se.getParent(), sa.getParent()) I see some scrolling. I guess it depends on primary / secondary selection?.
Andreas
Re: Scrolling / zooming programmatically [message #725261 is a reply to message #725245] Wed, 14 September 2011 07:37 Go to previous messageGo to next message
Ok, I have done this in a very different way. The focus I did was through the selectionChanged(IWorkbenchPart part, ISelection selection) method in the DiagramEditor class. I have subclassed this and overridden the selectionChanged method to listen to changes from other parts. The main thing is that you need a ISelection with the businessObject to be selected inside (you can create your own StruturedSelection instance for this.
My usage is different in that the selection was done in another workbench part and went through the selectionChanged(...) method of the DiagramEditor class and I always have only one element selected.
Jos
Re: Scrolling / zooming programmatically [message #725592 is a reply to message #725245] Thu, 15 September 2011 05:54 Go to previous messageGo to next message
Andreas,
the selection method only uses the first element in the given array, that's
what GEF allows there. So this explains the behavior you have noticed.
Michael
"Andreas Graf" schrieb im Newsbeitrag news:j4q1dq$45e$1@news.eclipse.org...
Hi Jos,
here is my code:
sa.getParent(),
se.getParent()
Andreas
Re: Scrolling / zooming programmatically [message #725606 is a reply to message #725592] Thu, 15 September 2011 06:38 Go to previous message
OK, that explains that. Would there be another way to scroll and zoom the diagram?
Previous Topic:Use emf editor property sheet page
Next Topic:boolean return value of canCreate / canMove etc.
Current Time: Wed Jul 23 07:47:16 EDT 2025
Powered by FUDForum. Page generated in 0.08428 seconds
