Re: How to save report to excel or pdf silently in server or client PC [message #723620 is a reply to message #723540] |
Thu, 08 September 2011 21:23   |
actually i'm not really sure what method i use, i think it is BIRT Viewer, i put the "webviewerExample" in the tomcat server, is it Viewer?
can i you explain me too about the RE API?
Jason Weathersby wrote on Thu, 08 September 2011 14:39Are you using the RE API or the BIRT Viewer?
Jason
On 9/6/2011 9:28 PM, cbr125x wrote:
> Thanks Jason for reply,
> yes, i want to generate the report that i made by BIRT into PDF file,
> and save the file in the server local drive or client local drive (which
> i already granted permission to write).
> Let's say i want to generate the report in pdf file at C:\PDF\ or at
> \\server1\PDF\
> is there a way to do that?
> Jason Weathersby wrote on Tue, 06 September 2011 10:38
>> Can you give some more detail? Do you want as a user views the report
>> in html the server to generate a pdf copy somewhere?
>> Jason
>> On 9/6/2011 4:24 AM, cbr125x wrote:
>> > Hi all,
>> > Is there a way to save or export report to pdf or excel silently in
>> > server or client PC?
>> > Thanks
Re: How to save report to excel or pdf silently in server or client PC [message #724557 is a reply to message #723620] |
Mon, 12 September 2011 10:16   |
That is the viewer. You could write some script in the report that
would save the report to the server in a different format while the user
is viewing it in HTML. Is that what you want?
Jason
> Thanks
>> Jason
>> (which
>> > \\server1\PDF\
>> >> Jason
>> >> > Hi all,
>> >> > Thanks
Re: How to save report to excel or pdf silently in server or client PC [message #724731 is a reply to message #724557] |
Mon, 12 September 2011 21:27   |
Yes, that is what i want, what script i should write?
Jason Weathersby wrote on Mon, 12 September 2011 10:16 :
Jason
> Thanks
>> Jason
>> (which
>> > \\server1\PDF\
>> >> Jason
>> >> > Hi all,
>> >> > Thanks
Re: How to save report to excel or pdf silently in server or client PC [message #725008 is a reply to message #724731] |
Tue, 13 September 2011 13:52   |
I am attaching an example of a report that creates a pdf for every row
in a detail table. Look at the table row oncreate to get an idea on how
to call the api from script. In your case you can put the script in the
afterFactory of the report.
Jason
> That is the viewer. You could write some script in the report that would
> save the report to the server in a different format while the user is
> Jason
>> Thanks
>>> Jason
>>> (which
>>> > \\server1\PDF\
>>> >> Jason
>>> >> > Hi all,
>>> >> > Thanks
Attachment: burst.zip
(Size: 5.53KB, Downloaded 1179 times)
Re: How to save report to excel or pdf silently in server or client PC [message #1818701 is a reply to message #1771891] |
Mon, 23 December 2019 21:58  |
You can set parameters as
ntask.setParameterValue(paramaterName, parameterValue);
Example -
importPackage(Packages.org.eclipse.birt.report.engine.api);
var re = reportContext.getReportRunnable().getReportEngine();
var des = re.openReportDesign("D:\\Projects\\BirtReport\\BirtReport\\test\\Agent_Details_Report.rptdesign");
var ntask = re.createRunAndRenderTask(des);
//set paameters
ntask.setParameterValue("dob", params["dob"].value);
ntask.setParameterValue("agentCode", params["agentCode"].value);
var options = new PDFRenderOption();
var outputfile = "d:/birt_pdf/testAgent.pdf";
options.setOutputFileName(outputfile);
options.setOutputFormat("pdf");
ntask.setRenderOption(options);
ntask.run();
ntask.close();
Tejaswini
FUDForum. Page generated in 0.31400 seconds
