Home » Archived » BIRT » Wierd issue with Birt 3.7.0
Wierd issue with Birt 3.7.0 [message #725058] Tue, 13 September 2011 16:16 Go to next message
Hi, my application is J2EE web application based on struts/spring and hibernate. I am using BIRT Report Viewer for the reporting needs as it has very cool features embedded. I am able to successfully integrate the BIRT VIEWER 2.6.2 to my application and the report I created showing up fine and recently migrated to 3.7.0 runtime.
I am facing an environment setup issue (I didn't face this issue with 2.6.2)-
I use tomcat 6.0.20 and I deploy 2 applications (applications have different context root, the source code in both applications same, just some environment settings diffrent like directories of log files creation, etc) on that server. Both applications use Birt Viewer, Birt Viewer working in only from one application but not from other application. When I issue below url -
http://<server>:8080/<Appcontextroot>/frameset?__report=report/userCert.rptdesign&__overwrite=true&runTime=true&__parameterpage=true
the birt viewer is invoking in another winodw, but it is redirecting back to my application login page...
http://<server>:8080/<Appcontextroot>/Login.do
What could be the reason for that? I really appreciate any input on this.
Thank you,
Jyothi
[Updated on: Tue, 13 September 2011 16:23] by Moderator
Re: Wierd issue with Birt 3.7.0 [message #725068 is a reply to message #725058] Tue, 13 September 2011 16:33 Go to previous messageGo to next message
Are you getting anything in the logs? Set the log level to FINE.
Jason
> 2.6.2)- I use tomcat 6.0.20 and I deploy 2 applications (applications
> have different context root) on that server. Both applications use Birt
> Viewer, Birt Viewer working in only one application but not from other
> Thank you,
> Jyothi
Re: Wierd issue with Birt 3.7.0 [message #725081 is a reply to message #725068] Tue, 13 September 2011 17:44 Go to previous messageGo to next message
Jason Weathersby wrote on Tue, 13 September 2011 16:33
Jason
Jason, Thank you for the reply.
yes, some log messages are writing to ReportEngine.log file when I set the log level to FINE. Here I am attaching the two files for your reference.
ReportEngine_IST_App2.log file is the file of application that is having issues.
ReportEngine_DEV_App1.log is the file of the application that is working.
It appears that initiliazation happening fine, but it is abruptly stopping and redirecting back to login page...Point me to the right direction.
Jyothi
Re: Wierd issue with Birt 3.7.0 [message #725137 is a reply to message #725081] Wed, 14 September 2011 00:44 Go to previous messageGo to next message
Does the process that is running the viewer have write permission to the
documents folder. If you look at your working system you can see the
next thing that happens is a write to:
/apps/tomcat/webapps/etrantest/documents/
Is anything being created in the documents folder on the non working system?
Jason
>> Jason
> Jyothi
Re: Wierd issue with Birt 3.7.0 [message #725318 is a reply to message #725137] Wed, 14 September 2011 10:04 Go to previous messageGo to next message
Jason Weathersby wrote on Wed, 14 September 2011 00:44
Jason
Jason, I checked the permissions on documents folder for both applications, both have same permissions as below (I am running applications in Linux environment)... I even set the 777 on documents folder on non-working appliation, still the same issue. One more wired thing is, it is working randomly sometimes for non-working application as well. So, I am lost here, why sometimes (very randomly)birtviewer coming up fine and why it is redirecting back to loging page mostly??? What settings I have to check??
drwxr-x--x 2 etrnos etrnos 1024 Sep 13 14:54 documents
and also, I am interested to know whether BirtViewer is shared between applications, if they are deployed in same tomcat server??
Thanks again for your help on this...
[Updated on: Wed, 14 September 2011 11:04] by Moderator
Re: Wierd issue with Birt 3.7.0 [message #725351 is a reply to message #725318] Wed, 14 September 2011 10:58 Go to previous messageGo to next message
Are you using JNDI on these reports? Also set your log level to FINEST
and post the results again.
Jason
>> the documents folder. If you look at your working system you can see
>> the next thing that happens is a write to:
>> system?
>> Jason
Re: Wierd issue with Birt 3.7.0 [message #725375 is a reply to message #725351] Wed, 14 September 2011 11:52 Go to previous messageGo to next message
Jason Weathersby wrote on Wed, 14 September 2011 10:58
Jason
Jason, yes, I am using JNDI on these reports. Here I am attaching the log files from both application after setting the log level to FINEST.
ReportEngine_DEV_App1.log file is for application that has no issues.
ReportEngine_IST_App2.log file is for application that has issues..
Thanks again!
Re: Wierd issue with Birt 3.7.0 [message #725389 is a reply to message #725375] Wed, 14 September 2011 12:12 Go to previous messageGo to next message
On the ist machine can you try to use /preview instead of /frameset?
Jason
>> Jason
> Thanks again!
Re: Wierd issue with Birt 3.7.0 [message #725405 is a reply to message #725389] Wed, 14 September 2011 13:18 Go to previous messageGo to next message
Jason Weathersby wrote on Wed, 14 September 2011 12:12
Jason
yes, preview is working. but it don't have the toolbar, navigation bar and table of contents and parameter page icon etc...It appears that AJAX is not working properly when I user frameset url pattern???
Re: Wierd issue with Birt 3.7.0 [message #725678 is a reply to message #725405] Thu, 15 September 2011 09:47 Go to previous messageGo to next message
The AJAX code uses a web service. I wonder if this is causing the
issue. BTW you can also try the /run mapping which I assume will fail
as well because it uses AJAX.
Jason
>> Jason
Re: Wierd issue with Birt 3.7.0 [message #725773 is a reply to message #725678] Thu, 15 September 2011 14:09 Go to previous messageGo to next message
Jason Weathersby wrote on Thu, 15 September 2011 09:47
Jason
So, how to resolve AJAx issue then? I am adding below url pattersn in my application security filter:
/frameset
/run
/preview
/download
/parameter
/document
/output
/extract
/webcontent
/birt.tld
Now, the BirtViewer initializinf and coming up fine first time when the user logs in, but when the user tries to open the report second time it is redirecting to my application home page, and from next attempt again it is working fine. only second attempt is failing. Can point me if there any other Birt related url pattern (that Birt runtime uses internally) I should add to ignore list of applciation security filter? Thanks for all the help...
Re: Wierd issue with Birt 3.7.0 [message #726111 is a reply to message #725773] Fri, 16 September 2011 11:36 Go to previous message
The AJAX code uses those same servlets as well as SOAP request calling
GetUpdatedObjects SOAP Method. I am not exactly sure how you would open
this up. It is on the same port. Any chance you can open a bugzilla
entry for this?
Jason
>> Jason
> /frameset
> /run /preview /download
> /parameter
> /document
> /output /extract
> /webcontent
> /birt.tld
Previous Topic:Sun JVM birt problem
Next Topic:Rendering the rptDocument while its being generated
Current Time: Sat Jul 26 22:30:35 EDT 2025
Powered by FUDForum. Page generated in 0.06152 seconds
