Home » Eclipse Projects » Standard Widget Toolkit (SWT) » OS X: launcher inside .app
OS X: launcher inside .app [message #723454] Thu, 08 September 2011 11:22 Go to next message
For AWT/Swing applications one usually uses the JavaApplicationStub to launch. For SWT applications we need to use the VM option -XstartOnFirstThread. According to my tests this seems not to work when using JavaApplicationStub and passing this option in the Info.plist (tried similar to the -Xmx option). Hence I'm now using a plain shell script.
Is that the correct way of launching an SWT application on OS X?
[Updated on: Thu, 08 September 2011 11:23] by Moderator
Re: OS X: launcher inside .app [message #724449 is a reply to message #723454] Mon, 12 September 2011 07:45 Go to previous messageGo to next message
Does none has an idea?
Re: OS X: launcher inside .app [message #724452 is a reply to message #723454] Mon, 12 September 2011 07:52 Go to previous messageGo to next message
> script. Is that the correct way of launching an SWT application on OS X?
I have *no* experience with MacOS and SWT, but does this possibly help:
http://www.digitalsanctuary.com/tech-blog/java/eclipse-startonfirstthread-error-and-fix.html
http://bineshgummadi.com/node/11
Greetings from Bremen,
Daniel Krügler
Re: OS X: launcher inside .app [message #724792 is a reply to message #724452] Tue, 13 September 2011 03:33 Go to previous messageGo to next message
Eclipse User wrote on Mon, 12 September 2011 07:52
Originally posted by:I have *no* experience with MacOS and SWT, but does this possibly help:
Unfortunately, no, because it looks like AWT related.
Re: OS X: launcher inside .app [message #726191 is a reply to message #723454] Fri, 16 September 2011 14:25 Go to previous messageGo to next message
Am 08.09.11 17:22, schrieb Thomas Singer:
Maybe this link helps:
http://eclipse.org/swt/macosx/
Disclaimer: I have never tried it myself.
Bernhard
Re: OS X: launcher inside .app [message #726194 is a reply to message #726191] Fri, 16 September 2011 14:50 Go to previous messageGo to next message
Bernhard Pieber wrote on Fri, 16 September 2011 14:25
That's what I'm currently doing, but I'm not sure whether this still is the officially suggested way to do it, especially because Apple promotes the JavaApplicationStub - at least for AWT/Swing.
Re: OS X: launcher inside .app [message #728553 is a reply to message #726194] Fri, 23 September 2011 09:22 Go to previous messageGo to next message
Eclipse provides a way to create a Mac application bundle from a Java project.
Right click on project > Export > other > Mac OSX Application Bundle. In the wizard page, select the checkbox "Use SWT" and fill in the other details. The app bundle is created automatically.
(Sorry, I didn't remember this before Sad )
Re: OS X: launcher inside .app [message #734284 is a reply to message #728553] Fri, 07 October 2011 07:34 Go to previous messageGo to next message
Lakshmi Shanmugam wrote on Fri, 23 September 2011 09:22
Unfortunately, there is no "other" category visible in my Export wizard. I've downloaded "Eclipse IDE for Java Developers" and created a small test project with SWT code.
Re: OS X: launcher inside .app [message #735242 is a reply to message #734284] Tue, 11 October 2011 06:09 Go to previous messageGo to next message
I tried the "Eclipse IDE for Java Developers" 3.7.1 version and the export wizard does have the other category (tried File > Export... )
Re: OS X: launcher inside .app [message #735569 is a reply to message #735242] Wed, 12 October 2011 04:56 Go to previous messageGo to next message
Lakshmi Shanmugam wrote on Tue, 11 October 2011 06:09
Sorry, I've downloaded a fresh copy of eclipse-java-indigo-SR1-win32.zip and when I invoke File -> Export there is no Other node. Maybe you have installed some additional plugins I don't have?
Re: OS X: launcher inside .app [message #735640 is a reply to message #735569] Wed, 12 October 2011 09:13 Go to previous messageGo to next message
Thomas Singer wrote on Wed, 12 October 2011 14:26
This is a mac only feature, can you try with the mac-cocoa eclipse download?
Re: OS X: launcher inside .app [message #735679 is a reply to message #735640] Wed, 12 October 2011 10:34 Go to previous messageGo to next message
Lakshmi Shanmugam wrote on Wed, 12 October 2011 09:13
You are right, this feature is available in OS-X-Eclipse. Unfortunately, the result looks very basic: I've got just following directory structure
Test.app/
[-] Contents
   [-] MacOS
   PkgInfo
That's it. Nothing in the MacOS directory, no Info.plist, no library (though I told it to use my launch configuration).
[Updated on: Wed, 12 October 2011 10:34] by Moderator
Re: OS X: launcher inside .app [message #736988 is a reply to message #735679] Fri, 14 October 2011 10:43 Go to previous messageGo to next message
I exported a SWT project as a Mac application and it got created fine with Info.plist and the jars.
directory structure using ls -R Test.app
Contents
Test.app/Contents:
Info.plist MacOS PkgInfo Resources
Test.app/Contents/MacOS:
JavaApplicationStub
Test.app/Contents/Resources:
Java
Test.app/Contents/Resources/Java:
jar_0.jar org.eclipse.swt.cocoa.macosx_3.8.0.v3800d.jar
-You need check the "use SWT" checkbox and provide the correct run configuration.
-In the "Classpath and Libraries" page in the export wizard lists the jars & folder that will be added to the classpath.
Re: OS X: launcher inside .app [message #737134 is a reply to message #723454] Fri, 14 October 2011 13:48 Go to previous messageGo to next message
First, thanks for your continuing effort. To shorten the thread, could you please post the content of the generated Info.plist (assuming that the application starts fine)? Thanks in advance.
Re: OS X: launcher inside .app [message #739654 is a reply to message #737134] Mon, 17 October 2011 13:50 Go to previous messageGo to next message
Attached the Info.plist here...
I'm still curious why the export mechanism is not working for you?!
  • Attachment: Info.plist
    (Size: 1.33KB, Downloaded 409 times)
Re: OS X: launcher inside .app [message #740127 is a reply to message #739654] Tue, 18 October 2011 03:26 Go to previous message
Lakshmi Shanmugam wrote on Mon, 17 October 2011 13:50
Thanks. How to add the command line parameter -d32, too?
I've tried again. Please see following screenshots.
index.php/fa/4395/0/
index.php/fa/4396/0/
index.php/fa/4397/0/
index.php/fa/4398/0/
index.php/fa/4399/0/
Please note following bugs:
- the "Use this launch configuration" combobox is too narrow
- selecting the item from the "Use this launch configuration" combobox does not pick any main class or classpath entry
- clicking the "Search" button right beside the Main class input field does nothing
Previous Topic:TAB as global shortcut key
Next Topic:Question about "deferred events"
Current Time: Wed Jul 23 00:44:32 EDT 2025
Powered by FUDForum. Page generated in 1.09716 seconds
