Home » Archived » M2M (model-to-model transformation) » [ATL] Group elements together in target model
[ATL] Group elements together in target model [message #72427] Thu, 17 January 2008 16:13 Go to next message
I have an ATL rule that create multiple elements in my target model. I
would like to know if there is a way to keep them grouped together.
Suposse I have a rule that creates two elements (say A and 8) in the
target model, each time it is invoked. Now there is another rule that
needs to collect these 'pairs' of A and B. But all As and Bs are no
longer "grouped together".
rule Select
from
nqlSelect : nql!Select( nqlSelect.oclIsTypeOf(nql!Select) )
to
acHqlArg : ac!Statement(
name <- 'PUSH',
arguments <- nqlSelect.arguments->collect( a |
thisModule.resolveTemp( a, 'argOut' ) )
acQuery : ac!Statement(
name <- 'QUERY'
Instead of creating acHqlArg and acQuery I would like to output:
Sequence{ acHqlArg, acQuery }
I want my transformation to remain declarative.
How can I do this?
Daniel
Re: [ATL] Group elements together in target model [message #72445 is a reply to message #72427] Fri, 18 January 2008 03:57 Go to previous messageGo to next message
Originally posted by: Hugo.Bruneliere.univ-nantes.fr
Hi Daniel,
> rule Select
> from
> to
> name <- 'PUSH',
> name <- 'QUERY'
> How can I do this?
The output generated model conforms to a given metamodel ("ac" in your
example). So if you want two "ac!Statement" to be grouped in your output
model, you have to add a specific concept allowing to do this in your
"ac" metamodel. Then, you can create such an element (which groups the
two "ac!Statement" elements) in your output model.
> Daniel
Hugo
Hugo Bruneliere - R&D Engineer
ATLAS Group (INRIA & LINA) - University of Nantes
2, rue de la Houssiniere
44322 Nantes Cedex 3 - France
office +33 2 51 12 58 10 /\ cell.+33 6 07 42 45 30
EMail: Hugo.Bruneliere@univ-nantes.fr
http://www.sciences.univ-nantes.fr/lina/atl/
Re: [ATL] Group elements together in target model [message #72463 is a reply to message #72445] Fri, 18 January 2008 05:01 Go to previous messageGo to next message
Hi Daniel,
Hugo suggested to modify your metamodel. Depending on what you precisely
want, this may be a good option.
However, if what you want to achieve is to "interleave" the collection
of pairs of elements (without modifying the metamodel), you could use
the scheme presented below.
Here is a description of what we want to achieve here. Note that the
value of property *elements* is not implemented, but described in this
version:
rule R1 {
from
s : MM1!A
to
t1 : MM2!B,
t2 : MM2!C
rule R2 {
from
s : MM1!D
to
t : MM2!E (
elements <- "for each element of s.as, get its B then its C"
For instance, given model:
d1 {a1, a2, a3, a4}
where d1 is a MM1!D, and a<n> are MM1!As.
We want to obtain:
e1 {b1, c1, b2, c2, b3, c3, b4, c4}
And here is a possible implementation using lazy rules:
unique lazy rule R1_B {
from
s : MM1!A
to
t1 : MM2!B
unique lazy rule R1_C {
from
s : MM1!A
to
t2 : MM2!C
rule R2 {
from
s : MM1!D
to
t : MM2!E (
elements <- s.as->collect(e |
Sequence {
thisModule.R1_B(e),
thisModule.R1_C(e)
)->flatten()
Frédéric Jouault
Hugo Bruneliere wrote:
> Hi Daniel,
>> rule Select
>> from
>> to
>> name <- 'PUSH',
>> name <- 'QUERY'
>> How can I do this?
>> Daniel
> Best regards,
> Hugo
Re: [ATL] Group elements together in target model [message #72481 is a reply to message #72445] Fri, 18 January 2008 05:00 Go to previous messageGo to next message
I already thought of this. But my situation is the following, in my
source model I have many select elements. What you suggest is this (in
pseudo code)
nql!Select ->
<ac!GroupingConcept><ac!Statement1><ac!Statement2></ac!GroupingConcept >
I do have some sort of 'acGroupingConcept' element in my target model.
But this element must contain ALL pairs of
<ac!Statement1><ac!Statement2> in a long list.
<acMain>
<acGroupingConcept><ac!Statement1><ac!Statement2></acGroupingConcept >
<acGroupingConcept><ac!Statement3><ac!Statement4></acGroupingConcept >
<acGroupingConcept><ac!Statement5><ac!Statement6></acGroupingConcept >
</acMain>
What I want is this:
<acMain>
</acMain>
I need a mechanism to temporarily keep these ac!Statement pairs together
and finally collect all these pairs and put them in ac!Main
Thanks in advance,
Daniel
> Hi Daniel,
>> rule Select
>> from
>> to
>> name <- 'PUSH',
>> name <- 'QUERY'
>> How can I do this?
>> Daniel
> Best regards,
> Hugo
Re: [ATL] Group elements together in target model [message #72503 is a reply to message #72463] Fri, 18 January 2008 05:16 Go to previous messageGo to next message
Yes this is exactly what I was looking for. This should work fine for
grouping two elements together. But is doesn't really scale well.
Suppose I have five target elements does that mean I have to create 5 +
1 rules to the same?
I think it will be usefull if rules could be specific like this:
from
s : MM1!A
to
x : Sequence( MM2!B, MM2!C ) {
t1: MM2!B,
t2: MM2!C
Then I can do something like this:
rule R2 {
from
s : MM1!D
to
t : MM2!E (
elements <- thisModule.R1_C( s.as )
What do you think of it?
Frédéric Jouault wrote:
> Hi Daniel,
> version:
> rule R1 {
> from
> s : MM1!A
> to
> t1 : MM2!B,
> t2 : MM2!C
> rule R2 {
> from
> s : MM1!D
> to
> t : MM2!E (
> d1 {a1, a2, a3, a4}
> We want to obtain:
> from
> s : MM1!A
> to
> t1 : MM2!B
> from
> s : MM1!A
> to
> t2 : MM2!C
> rule R2 {
> from
> s : MM1!D
> to
> t : MM2!E (
> Sequence {
> thisModule.R1_B(e),
> thisModule.R1_C(e)
> )->flatten()
> Regards,
> Frédéric Jouault
>> Hi Daniel,
>>> I would like to know if there is a way to keep them grouped together.
>>> rule Select
>>> from
>>> to
>>> name <- 'PUSH',
>>> name <- 'QUERY'
>>> How can I do this?
>> output model, you have to add a specific concept allowing to do this
>> in your "ac" metamodel. Then, you can create such an element (which
>> groups the two "ac!Statement" elements) in your output model.
>>> Daniel
>> Best regards,
>> Hugo
Re: [ATL] Group elements together in target model [message #72520 is a reply to message #72503] Fri, 18 January 2008 07:02 Go to previous messageGo to next message
Well, if you prefer having a single rule, you should be able to do it
using resolveTemp:
rule R1 {
from
s : MM1!A
to
t1 : MM2!B,
t2 : MM2!C
rule R2 {
from
s : MM1!D
to
t : MM2!E (
Sequence {
e, -- equivalent to: thisModule.resolveTemp(e, 't1')
thisModule.resolveTemp(e, 't2')
)->flatten()
Frédéric Jouault
> from
> s : MM1!A
> to
> t1: MM2!B,
> t2: MM2!C
> rule R2 {
> from
> s : MM1!D
> to
> t : MM2!E (
>> Hi Daniel,
>> precisely want, this may be a good option.
>> version:
>> rule R1 {
>> from
>> s : MM1!A
>> to
>> t1 : MM2!B,
>> t2 : MM2!C
>> rule R2 {
>> from
>> s : MM1!D
>> to
>> t : MM2!E (
>> d1 {a1, a2, a3, a4}
>> We want to obtain:
>> from
>> s : MM1!A
>> to
>> t1 : MM2!B
>> from
>> s : MM1!A
>> to
>> t2 : MM2!C
>> rule R2 {
>> from
>> s : MM1!D
>> to
>> t : MM2!E (
>> Sequence {
>> thisModule.R1_B(e),
>> thisModule.R1_C(e)
>> )->flatten()
>> Regards,
>> Frédéric Jouault
>>> Hi Daniel,
>>>> that needs to collect these 'pairs' of A and B. But all As and Bs
>>>> are no longer "grouped together".
>>>> rule Select
>>>> from
>>>> to
>>>> name <- 'PUSH',
>>>> name <- 'QUERY'
>>>> How can I do this?
>>> your example). So if you want two "ac!Statement" to be grouped in
>>> your output model, you have to add a specific concept allowing to do
>>> this in your "ac" metamodel. Then, you can create such an element
>>> (which groups the two "ac!Statement" elements) in your output model.
>>>> Daniel
>>> Best regards,
>>> Hugo
Re: [ATL] Group elements together in target model [message #73174 is a reply to message #72520] Wed, 23 January 2008 06:57 Go to previous messageGo to next message
One more thing,
You assume in rule R2 in the 'to' part that I have an 'elements'
container. What if I do not have this elements collection? It is
possible to generate a bunch of single elements without assigning them.
Is the same possible with a collection? (And that I assign them later)
> using resolveTemp:
> rule R1 {
> from
> s : MM1!A
> to
> t1 : MM2!B,
> t2 : MM2!C
> rule R2 {
> from
> s : MM1!D
> to
> t : MM2!E (
> Sequence {
> )->flatten()
> Regards,
> Frédéric Jouault
>> + 1 rules to the same?
>> from
>> s : MM1!A
>> to
>> t1: MM2!B,
>> t2: MM2!C
>> rule R2 {
>> from
>> s : MM1!D
>> to
>> t : MM2!E (
>>> Hi Daniel,
>>> collection of pairs of elements (without modifying the metamodel),
>>> you could use the scheme presented below.
>>> this version:
>>> rule R1 {
>>> from
>>> s : MM1!A
>>> to
>>> t1 : MM2!B,
>>> t2 : MM2!C
>>> rule R2 {
>>> from
>>> s : MM1!D
>>> to
>>> t : MM2!E (
>>> d1 {a1, a2, a3, a4}
>>> We want to obtain:
>>> from
>>> s : MM1!A
>>> to
>>> t1 : MM2!B
>>> from
>>> s : MM1!A
>>> to
>>> t2 : MM2!C
>>> rule R2 {
>>> from
>>> s : MM1!D
>>> to
>>> t : MM2!E (
>>> Sequence {
>>> thisModule.R1_B(e),
>>> thisModule.R1_C(e)
>>> )->flatten()
>>> Regards,
>>> Frédéric Jouault
>>>> Hi Daniel,
>>>>> model. I would like to know if there is a way to keep them grouped
>>>>> together.
>>>>> the target model, each time it is invoked. Now there is another
>>>>> rule that needs to collect these 'pairs' of A and B. But all As and
>>>>> Bs are no longer "grouped together".
>>>>> rule Select
>>>>> from
>>>>> to
>>>>> name <- 'PUSH',
>>>>> name <- 'QUERY'
>>>>> How can I do this?
>>>>> Daniel
>>>> Best regards,
>>>> Hugo
Re: [ATL] Group elements together in target model [message #73267 is a reply to message #73174] Thu, 24 January 2008 11:35 Go to previous message
If you do not assign the collection of grouped element to a property,
then it will not exist in the target model.
Frédéric Jouault
Previous Topic:[QVTO] Implicit source vs contextless invocation
Next Topic:[ATL] Select and delete ASMModelElement
Current Time: Sun Jul 27 13:01:35 EDT 2025
Powered by FUDForum. Page generated in 0.06778 seconds
