Home » Archived » BIRT » Report Preview Problems in Eclipse Designer 3.7
Report Preview Problems in Eclipse Designer 3.7 [message #724511] |
Mon, 12 September 2011 09:59  |
Hi:
I am able to use the BIRT report runtime outside the report designer. I am using Spring JDBC templates to fetch my report data. Deployed to Tomcat or Weblogic, it works fine. Inside the Eclipse IDE however is a different story. I can only preview a report once. When I try to preview a second time, I encounter class loader issues that are Spring-related. I get: IllegalArgumentException; interface org.springframework.aop.SpringProxy is not visible from class loader (report/data-sets/script/-data-set[@id="94"]/method[@name="open]#3)
I am including my Spring code by setting the build path in Project Properties (project->properties->report design->classpath).
I tried replacing the runtime war in the eclipse plugins with the one I deploy; but that totally fails; it does not find ANY of the Spring classes in that case.
If I close and then re-open eclipse, I can run preview again, but just once before I have to close it again.
Any suggestions?
Re: Report Preview Problems in Eclipse Designer 3.7 [message #724616 is a reply to message #724562] |
Mon, 12 September 2011 12:39   |
Jason:
I added the following to my Report Design Classpath, it's in the same workspace;
1. A jar with my classes with the Spring JDBC templates and a report event handler, as well as spring security related classes.
2. log4j
3. Spring
4. oracle driver
5. commons dbcp
6. commons-pool
7. An API jar developed internally in our organization.
Jason Weathersby wrote on Mon, 12 September 2011 10:31John,
In Eclipse do you have your code in a project in the same workspace as
the reports? What are you adding to the classpath?
Jason
On 9/12/2011 9:59 AM, John Roberts wrote:
> Hi:
> Any suggestions?
Re: Report Preview Problems in Eclipse Designer 3.7 [message #724628 is a reply to message #724616] |
Mon, 12 September 2011 12:54   |
Is the oracle driver already in the drivers directory of the jdbc plugin?
Jason
On 9/12/2011 12:39 PM, John Roberts wrote:
> Jason:
> workspace;
> 2. log4j
> 3. Spring
> 4. oracle driver
> 5. commons dbcp
> 6. commons-pool
>> John,
>> Jason
>> > Hi:
>> preview
>> > Any suggestions?
Re: Report Preview Problems in Eclipse Designer 3.7 [message #724631 is a reply to message #724628] |
Mon, 12 September 2011 13:32   |
Nope
Jason Weathersby wrote on Mon, 12 September 2011 12:54Is the oracle driver already in the drivers directory of the jdbc plugin?
Jason
> Jason:
> workspace;
> 2. log4j
> 3. Spring
> 4. oracle driver
> 5. commons dbcp
> 6. commons-pool
>> John,
>> Jason
>> > Hi:
>> preview
>> > Any suggestions?
Re: Report Preview Problems in Eclipse Designer 3.7 [message #724666 is a reply to message #724631] |
Mon, 12 September 2011 14:42   |
So you are not writing any reports directly against oracle, correct?
The reason I ask this, this type of error usually happens when two jars
are in the engine classpath.
Jason
On 9/12/2011 1:33 PM, John Roberts wrote:
> Nope
>> Jason
>> > Jason:
>> > workspace;
>> > 2. log4j
>> > 3. Spring
>> > 4. oracle driver
>> > 5. commons dbcp
>> > 6. commons-pool
>> >> John,
>> >> Jason
>> >> > Hi:
>> designer. I
>> is a
>> >> preview
>> Spring-related.
>> one I
>> just
>> >> > Any suggestions?
Re: Report Preview Problems in Eclipse Designer 3.7 [message #724687 is a reply to message #724666] |
Mon, 12 September 2011 16:10   |
Good question - I checked and it is not in the WEB-INF/lib or scriptLib; none of the jars are repeated.
Jason Weathersby wrote on Mon, 12 September 2011 14:42So you are not writing any reports directly against oracle, correct?
Jason
> Nope
>> Jason
>> > Jason:
>> > workspace;
>> > 2. log4j
>> > 3. Spring
>> > 4. oracle driver
>> > 5. commons dbcp
>> > 6. commons-pool
>> >> John,
>> >> Jason
>> >> > Hi:
>> designer. I
>> is a
>> >> preview
>> Spring-related.
>> one I
>> just
>> >> > Any suggestions?
Re: Report Preview Problems in Eclipse Designer 3.7 [message #725009 is a reply to message #724687] |
Tue, 13 September 2011 13:55  |
John,
Any chance you add a Java project to your workspace that calls the
spring stuff and then in the birt project classpath add this new Java
project. Make sure to remove the other references.
Jason
>> jars are in the engine classpath.
>> Jason
>> > Nope
>> plugin?
>> >> Jason
>> >> > Jason:
>> same
>> >> > workspace;
>> >> > 2. log4j
>> >> > 3. Spring
>> >> > 4. oracle driver
>> >> > 5. commons dbcp
>> >> > 6. commons-pool
>> >> >> John,
>> workspace as
>> >> >> Jason
>> >> >> > Hi:
>> >> designer. I
>> Deployed to
>> >> is a
>> >> >> preview
>> >> Spring-related.
>> loader
>> Project
>> >> one I
>> Spring
>> >> just
>> >> >> > Any suggestions?
Current Time: Sat Jul 26 08:40:20 EDT 2025
Powered by FUDForum. Page generated in 0.06622 seconds
