Home » Archived » BIRT » Gantt chart: cannot have several entries in a serie
Gantt chart: cannot have several entries in a serie [message #724547] |
Mon, 12 September 2011 11:11  |
I'm trying to generate a Gantt chart programmatically:
The chart has two axes:
- vertical axis (base axis): Name of my elements
- horizontal axis (that is the orthogonal axis to be filled with dates): dates
I create a chart, and a GanttSerie like this:
GanttDataSet phase1 = GanttDataSetImpl.create( new GanttEntry[]{
new GanttEntry( new CDateTime( 2009, 1, 1), new CDateTime( 2009, 1,15),"Name" )});
GanttSeries seriePhase1 = (GanttSeries) GanttSeriesImpl.create( );
taskPhase1.setDataSet( phase1);
SeriesDefinition sdY = SeriesDefinitionImpl.create( );
sdY.getSeriesPalette( ).shift( 2 );
sdY.getSeries( ).add( taskPhase1 );
xAxisPrimary.getSeriesDefinitions( ).add( sdY );
All is OK.
I would like to add GanttEntry in my DataSett "phase1":
new GanttEntry( new CDateTime( 2009, 1, 1), new CDateTime( 2009, 1,15), "Name" ),
new GanttEntry( new CDateTime( 2009, 1, 17), new CDateTime( 2009, 1,23),"Name2")
It generates an exception:
org.eclipse.birt.chart.exception.ChartException
at org.eclipse.birt.chart.factory.Generator.render(Generator.java:1306)
at ganttreport.ChartCanvas.drawToCachedImage(ChartCanvas.java:135)
at ganttreport.ChartCanvas$1.paintControl(ChartCanvas.java:66)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:229)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1258)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1282)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1267)
at org.eclipse.swt.widgets.Control.gtk_expose_event(Control.java:2961)
at org.eclipse.swt.widgets.Composite.gtk_expose_event(Composite.java:701)
at org.eclipse.swt.widgets.Canvas.gtk_expose_event(Canvas.java:167)
at org.eclipse.swt.widgets.Widget.windowProc(Widget.java:1739)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:5016)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4408)
at org.eclipse.swt.internal.gtk.OS._gtk_main_do_event(Native Method)
at org.eclipse.swt.internal.gtk.OS.gtk_main_do_event(OS.java:8394)
at org.eclipse.swt.widgets.Display.eventProc(Display.java:1245)
at org.eclipse.swt.internal.gtk.OS._g_main_context_iteration(Native Method)
at org.eclipse.swt.internal.gtk.OS.g_main_context_iteration(OS.java:2258)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3207)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2696)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2660)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2494)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:674)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:667)
at ganttreport.Application.start(Application.java:20)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:616)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
at org.eclipse.equinox.launcher.Main.main(Main.java:1386)
at org.eclipse.birt.chart.extension.render.Gantt.renderSeries(Gantt.java:133)
at org.eclipse.birt.chart.render.AxesRenderer.renderPlot(AxesRenderer.java:2284)
at org.eclipse.birt.chart.render.AxesRenderer.render(AxesRenderer.java:335)
at org.eclipse.birt.chart.factory.Generator.render(Generator.java:1301)
... 40 more
I don't understand why I could not add entry in the dataset.
Have you got an idea ?
Thanks in advance.
[Updated on: Mon, 12 September 2011 11:15] by Moderator
Re: Gantt chart: cannot have several entry in a serie [message #724585 is a reply to message #724547] |
Mon, 12 September 2011 11:25   |
Can you try this one from the chart examples view?
package org.eclipse.birt.chart.examples.view.models;
import org.eclipse.birt.chart.extension.datafeed.GanttEntry;
import org.eclipse.birt.chart.model.Chart;
import org.eclipse.birt.chart.model.ChartWithAxes;
import org.eclipse.birt.chart.model.attribute.AttributeFactory;
import org.eclipse.birt.chart.model.attribute.AxisType;
import org.eclipse.birt.chart.model.attribute.DateFormatDetail;
import org.eclipse.birt.chart.model.attribute.DateFormatSpecifier;
import org.eclipse.birt.chart.model.attribute.DateFormatType;
import org.eclipse.birt.chart.model.attribute.IntersectionType;
import org.eclipse.birt.chart.model.attribute.LegendItemType;
import org.eclipse.birt.chart.model.attribute.Orientation;
import org.eclipse.birt.chart.model.attribute.TickStyle;
import org.eclipse.birt.chart.model.attribute.impl.ColorDefinitionImpl;
import org.eclipse.birt.chart.model.component.Axis;
import org.eclipse.birt.chart.model.component.Series;
import org.eclipse.birt.chart.model.component.impl.SeriesImpl;
import org.eclipse.birt.chart.model.data.BaseSampleData;
import org.eclipse.birt.chart.model.data.DataFactory;
import org.eclipse.birt.chart.model.data.GanttDataSet;
import org.eclipse.birt.chart.model.data.NumberDataSet;
import org.eclipse.birt.chart.model.data.OrthogonalSampleData;
import org.eclipse.birt.chart.model.data.SampleData;
import org.eclipse.birt.chart.model.data.SeriesDefinition;
import org.eclipse.birt.chart.model.data.impl.DateTimeDataElementImpl;
import org.eclipse.birt.chart.model.data.impl.GanttDataSetImpl;
import org.eclipse.birt.chart.model.data.impl.NumberDataSetImpl;
import org.eclipse.birt.chart.model.data.impl.SeriesDefinitionImpl;
import org.eclipse.birt.chart.model.impl.ChartWithAxesImpl;
import org.eclipse.birt.chart.model.layout.Legend;
import org.eclipse.birt.chart.model.layout.Plot;
import org.eclipse.birt.chart.model.type.GanttSeries;
import org.eclipse.birt.chart.model.type.impl.GanttSeriesImpl;
import org.eclipse.birt.chart.util.CDateTime;
public class Gantt
public final static Chart createGantt( )
ChartWithAxes cwaGantt = ChartWithAxesImpl.create( );
cwaGantt.setType( "Gantt Chart" ); //$NON-NLS-1$
cwaGantt.setSubType( "Standard Gantt Chart" ); //$NON-NLS-1$
cwaGantt.setOrientation( Orientation.HORIZONTAL_LITERAL );
// Plot
cwaGantt.getBlock( ).setBackground( ColorDefinitionImpl.WHITE( ) );
cwaGantt.getBlock( ).getOutline( ).setVisible( true );
Plot p = cwaGantt.getPlot( );
p.getClientArea( ).setBackground( ColorDefinitionImpl.create( 255,
255,
225 ) );
// Title
cwaGantt.getTitle( ).getLabel( ).getCaption( ).setValue( "Gantt Chart"
); //$NON-NLS-1$
// Legend
Legend lg = cwaGantt.getLegend( );
lg.setItemType( LegendItemType.CATEGORIES_LITERAL );
// X-Axis
Axis xAxisPrimary = cwaGantt.getPrimaryBaseAxes( )[0];
xAxisPrimary.setCategoryAxis( true );
xAxisPrimary.getMajorGrid( ).setTickStyle( TickStyle.BELOW_LITERAL );
xAxisPrimary.getOrigin( ).setType( IntersectionType.MIN_LITERAL );
// Y-Axis
Axis yAxisPrimary = cwaGantt.getPrimaryOrthogonalAxis( xAxisPrimary );
yAxisPrimary.setType( AxisType.DATE_TIME_LITERAL );
yAxisPrimary.getMajorGrid( ).setTickStyle( TickStyle.LEFT_LITERAL );
yAxisPrimary.getScale( ).setMin( DateTimeDataElementImpl.create( new
CDateTime(2008,1,1) ) );
yAxisPrimary.getScale( ).setMax( DateTimeDataElementImpl.create( new
CDateTime(2009,1,1) ) );
DateFormatSpecifier dfs =
AttributeFactory.eINSTANCE.createDateFormatSpecifier( );
dfs.setDetail( DateFormatDetail.DATE_LITERAL );
dfs.setType( DateFormatType.MEDIUM_LITERAL );
yAxisPrimary.setFormatSpecifier( dfs );
// Data Set
NumberDataSet categoryValues = NumberDataSetImpl.create( new double[]{
1, 2, 3
new GanttEntry( new CDateTime( 2008, 1, 9 ),
new CDateTime( 2008, 6, 9 ),
"Task A" ), //$NON-NLS-1$
new GanttEntry( new CDateTime( 2008, 3, 9 ),
new CDateTime( 2008, 8, 9 ),
"Task B" ), //$NON-NLS-1$
new GanttEntry( new CDateTime( 2008, 5, 24 ),
new CDateTime( 2008, 9, 9 ),
"Task C" ) //$NON-NLS-1$
GanttDataSet phase2 = GanttDataSetImpl.create( new GanttEntry[]{
new GanttEntry( new CDateTime( 2008, 6, 12 ),
new CDateTime( 2008, 9, 23 ),
new GanttEntry( new CDateTime( 2008, 8, 9 ),
new GanttEntry( new CDateTime( 2008, 9, 9 ),
new CDateTime( 2008, 12, 9 ),
SampleData sd = DataFactory.eINSTANCE.createSampleData( );
BaseSampleData sdBase = DataFactory.eINSTANCE.createBaseSampleData( );
sdBase.setDataSetRepresentation( "" );//$NON-NLS-1$
sd.getBaseSampleData( ).add( sdBase );
OrthogonalSampleData sdOrthogonal1 =
DataFactory.eINSTANCE.createOrthogonalSampleData( );
sdOrthogonal1.setDataSetRepresentation( "" );//$NON-NLS-1$
sdOrthogonal1.setSeriesDefinitionIndex( 0 );
sd.getOrthogonalSampleData( ).add( sdOrthogonal1 );
cwaGantt.setSampleData( sd );
// X-Series
Series seCategory = SeriesImpl.create( );
seCategory.setDataSet( categoryValues );
SeriesDefinition sdX = SeriesDefinitionImpl.create( );
sdX.getSeriesPalette( ).shift( 0 );
xAxisPrimary.getSeriesDefinitions( ).add( sdX );
sdX.getSeries( ).add( seCategory );
// Y-Series
GanttSeries taskPhase1 = (GanttSeries) GanttSeriesImpl.create( );
taskPhase1.setDataSet( phase1 );
taskPhase1.getLabel( ).setVisible( false );
GanttSeries taskPhase2 = (GanttSeries) GanttSeriesImpl.create( );
taskPhase2.setDataSet( phase2 );
taskPhase2.getLabel( ).setVisible( false );
sdY.getSeriesPalette( ).shift( 0 );
yAxisPrimary.getSeriesDefinitions( ).add( sdY );
sdY.getSeries( ).add( taskPhase2 );
return cwaGantt;
Jason
On 9/12/2011 11:11 AM, val.dupin wrote:
> Hello,
> I'm trying to generate a Gantt chart programmatically: The chart has two
> axes:
> dates
> 1,15),"Name" )});
> All is OK.
> "Name" ), new GanttEntry( new CDateTime( 2009, 1, 17), new CDateTime(
> at
> at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
> at
> org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
> at
> at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
> at
> org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
> at
> at
> at
> at
> sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
> at
> at
> ... 40 more
> Thanks in advance.
Current Time: Fri Jul 25 23:01:52 EDT 2025
Powered by FUDForum. Page generated in 1.06538 seconds
