Home » Language IDEs » C / C++ IDE (CDT) » Can't display memory(Memory Monitor)
Can't display memory [message #723513] Thu, 08 September 2011 13:43 Go to next message
When entering a (valid) address by hand or by right clocking on a pointer variable & selecting View Memory, I get:
Unable to load memory from specified address: 0x....
I'm running on 64-bit Linux (RHEL 6.1) w/ the vanilla Helios CDT linux 64 build (eclipse-linuxtools-helios-SR2-incubation-linux-gtk-x86_64)
Version: Helios Service Release 2
Build id: 20110218-0911
I am able to display memory in the gdb command console window. The gdb-traces console isn't any help (nothing shows up when I add the memory monitor).
Re: Can't display memory [message #723673 is a reply to message #723513] Fri, 09 September 2011 02:41 Go to previous messageGo to next message
Does this sound familiar?
https://bugs.eclipse.org/bugs/show_bug.cgi?id=309222
EDIT:
I think that is rather https://bugs.eclipse.org/bugs/show_bug.cgi?id=309576
I encountered the same buggy behavior on my machine (Ubuntu, gdb 7.2, Eclipse Indigo) for 64 bit executables.
[Updated on: Fri, 09 September 2011 04:08] by Moderator
Re: Can't display memory [message #723832 is a reply to message #723673] Fri, 09 September 2011 11:46 Go to previous messageGo to next message
Yes. I'm also running gdb 7.2. And it definitely is a 64-bit limitation:
I can get a memory monitor display for addresses <= 0xffff_ffff (with errors in gdb trace since the random address is invalid).
Above 0xffff_ffff I get the "Unable to load memory from specified address: 0x...." error (with nothing in gdb trace).
Guess it's command line gdb for now.
Re: Can't display memory [message #724344 is a reply to message #723832] Mon, 12 September 2011 02:54 Go to previous message
Please add your vote to the above mentioned bug.
You can always use the gdb console inside Eclipse to display memory addresses (not very convenient but better than nothing).
(no subject) [message #724349 is a reply to message #723832] Mon, 12 September 2011 02:54 Go to previous message
Before you ask
- search this forum
- see the FAQ http://wiki.eclipse.org/CDT/User/FAQ
Previous Topic:Debugging problem in Helios
Next Topic:Using a VC++ DLL in Eclipse?
Current Time: Wed Jul 30 17:12:16 EDT 2025
Powered by FUDForum. Page generated in 0.29123 seconds
