[solved] RCP Build fails [message #723771] |
Fri, 09 September 2011 08:35  |
I am trying to build an RCP with buckminster following Ralf Eberts Blog.
I am able to build a p2 update site, but when trying to build an RCP product I end up with an error:
org.eclipse.core.runtime.CoreException: C:\UserData\Workspaces\Eclipse_3.7_Workspace\Tag Studio RCP Full Featured\build\product.ant:22: Java returned: 13
I am running the create.product action from the custom cspex file.
First thing to do for me would be to access some logs to get detailed error information. Does anybody know where buckminster stores its logs to?
product.ant:
<project>
<pathconvert property="equinox.launcher.jar">
<first count="1">
<sort>
<fileset dir="${eclipse.home}/plugins" includes="**/org.eclipse.equinox.launcher_*.jar"/>
<reverse xmlns="antlib:org.apache.tools.ant.types.resources.comparators">
<date/>
</reverse>
</sort>
</first>
</pathconvert>
<target name="create.product">
<property name="destination" location="${sp:destination}"/>
<delete dir="${destination}"/>
<makeurl property="repository" file="${sp:repository}"/>
<mkdir dir="${destination}"/>
<echoproperties/>
<echo message="${equinox.launcher.jar}"/>
<echo message="${repository}"/>
<echo message="${destination}"/>
<java jar="${equinox.launcher.jar}" fork="true" failonerror="true" >
<arg value="-application"/>
<arg value="org.eclipse.equinox.p2.director"/>
<arg value="-repository"/>
<arg value="${repository}"/>
<arg value="-destination"/>
<arg value="${destination}"/>
<arg value="-profile"/>
<arg value="${profile}"/>
<arg value="-profileProperties" />
<arg value="org.eclipse.update.install.features=true" />
<arg value="-installIU"/>
<arg value="${iu}"/>
<arg value="-p2.os" />
<arg value="${target.os}" />
<arg value="-p2.ws" />
<arg value="${target.ws}" />
<arg value="-p2.arch" />
<arg value="${target.arch}" />
<arg value="-consoleLog"/>
<!-- jvmarg value="-agentlib:jdwp=transport=dt_socket,address=8000,server=y,suspend=y"/ -->
</java>
</target>
</project>
buckminster.properties:
# Where all the output should go
buckminster.output.root=C:/UserData/Build/Tag Studio Full
# Where the temp files should go
buckminster.temp.root=C:/UserData/temp/Buckminster
# How .qualifier in versions should be replaced
qualifier.replacement.*=generator:lastRevision
target.os=win32
target.ws=win32
target.arch=x86
[Updated on: Wed, 14 September 2011 08:26] by Moderator
Re: RCP Build fails [message #867640 is a reply to message #725281] |
Tue, 01 May 2012 07:58  |
Got the same error, but found the fix to be in the antscript that builds the product.
When I used the script that Ralf refers directly to in the tutorial the build works fine, but if you use the script in his example project on github (referred to at the end of the tutorial) I get org.eclipse.core.runtime.CoreException: D:\Projects\Buckminster_2\com.example.mail.site\build\product.ant:22: Java returned: 13
I suspect it might have to do with the fact, that I'm on newer versions of everything (Buckminster Plugin 1.4.0, Eclipse 3.7.2 and Java 1.7) and eg. the commands have changed. Don't know if there's a brighter head out there, that can see or knows why.
Working
<project>
<first count="1">
<sort>
<date/>
</reverse>
</sort>
</first>
</pathconvert>
<echoproperties/>
</java>
</target>
</project>
Not Working
<project>
<first count="1">
<sort>
<date/>
</reverse>
</sort>
</first>
</pathconvert>
<delete dir="${destination}"></delete>
<echoproperties ></echoproperties>
<arg value="-artifactRepository"/>
<arg value="file:${repository}"/>
<arg value="-metadataRepository"/>
<arg value="-bundlepool"/>
<jvmarg value="-Declipse.p2.data.area=${destination}/p2"/>
<jvmarg value="-Declipse.p2.profile=${profile}"/>
</java>
</target>
</project>
FUDForum. Page generated in 0.04186 seconds
