Home » Archived » BIRT » Help!!! Issue with flat data file(Birt doesn't show correct chart when use flat data file)
Help!!! Issue with flat data file [message #723663] Fri, 09 September 2011 01:51 Go to next message
I'm using BIRT 2.6 in eclipse helios. I use flat data file to show a scatter chart. These are steps:
1) create a data source with flat data file with dynamic sub folder and file name, sub folder and file name are passed as report parameters.
2) if I set x-axis range from -1000 to 1000, then data only show on x-axis with x>0. So I have to do a calculation on x-axis with row[X]+1000
3) data not showing up correct with more than 20 points. Please see attached for detailed setting and result.
This is urgent! Please help!
Wendy
Re: Help!!! Issue with flat data file [message #723802 is a reply to message #723663] Fri, 09 September 2011 10:17 Go to previous messageGo to next message
I'm guessing you're having a grouping issue since the last 21st row's x value is the same as an x value from another row. In your chart editor, if you go to the select data tab and click on the grouping and sorting button next to the x-axis category and unselect the check box for grouping, you'll probably get the desired results.
Michael
Contributor on
http://www.birt-exchange.org
icon14.gif  Re: Help!!! Issue with flat data file [message #723818 is a reply to message #723802] Fri, 09 September 2011 11:00 Go to previous messageGo to next message
Hi Michael,
You are absolutely right! Now it's working.
Thanks a lot,
Wendy
Very Happy
Re: Help!!! Issue with flat data file [message #723849 is a reply to message #723818] Fri, 09 September 2011 12:38 Go to previous message
Not a problem! Smile
Previous Topic:Show summary so far on each detail line
Next Topic:Calculate a row value in a script
Current Time: Thu Jul 24 23:13:15 EDT 2025
Powered by FUDForum. Page generated in 0.04085 seconds
