Home » Language IDEs » C / C++ IDE (CDT) » Eclipse hangs on startup
Eclipse hangs on startup [message #723313] Thu, 08 September 2011 06:04 Go to next message
Today I have a problem with my Eclipse...
It hangs on startup with a couple of threads in the "Progress" view.
Please see the attached screenshot.
The progress bars keep endlessly running with no obvious progress.
Hitting the "Cancel" buttons writes a "Cancel requested", but the request is never fulfilled.
The project files are out of sync, the editor shows a "Press 'F5' to refresh" message.
Doing so adds a "Refresh (waiting)" thread to the progress view.
I killed and restarted Eclipse several times, but the issue is always re-occurring.
Exiting normally from Eclipse is not possible because of the hanging threads.
PLEASE HELP!
  • Attachment: eclipse.png
    (Size: 14.56KB, Downloaded 271 times)
[Updated on: Thu, 08 September 2011 06:07] by Moderator
Re: Eclipse hangs on startup [message #723758 is a reply to message #723313] Fri, 09 September 2011 07:36 Go to previous messageGo to next message
Restarting eclipse with "-clean" option sometimes could help in such cases.
Andrew
Re: Eclipse hangs on startup [message #723765 is a reply to message #723758] Fri, 09 September 2011 08:19 Go to previous messageGo to next message
http://wiki.eclipse.org/How_to_report_a_deadlock
Re: Eclipse hangs on startup [message #724513 is a reply to message #723765] Mon, 12 September 2011 10:03 Go to previous message
Thanks to both of you.
Probably the "-clean" would have helped.
I re-installed Eclipse, created a new workspace and imported the project...
Now it works again.
Thomas
Previous Topic:Can't debug c++ code using Eclipse on Windows 7
Next Topic:Setting up Windows/Linux hybrid dev environment - Unresolved types in CDT 8.0?
Current Time: Fri Aug 29 19:21:47 EDT 2025
Powered by FUDForum. Page generated in 0.03561 seconds
