Home » Archived » M2M (model-to-model transformation) » [QVT] Adding element to feature
[QVT] Adding element to feature [message #723721] Fri, 09 September 2011 05:13 Go to next message
Is it possible to add an element to a reference with a multiplicity larger then 1?
The goal is to add an element to a feature which is not known at forehand but dynamically computed. So in the end, I end up with the following helper:
helper setObjectInSingleFeature(e: EObject, f: EStructuralFeature, a: Element)
   e.eSet(f, a);
This works in case the feature has an upper bound of 1. What if the feature represents a collection? One would like to be able to do something like:
helper setObjectInMultiFeature(e: EObject, f: EStructuralFeature, a: Element)
   var entries := e.eGet(f);
   var newEntries := entries->asSequence().insertAt(0,a);
   e.eSet(f, newEntries);
However, this is not possible due to the fact that eSet expects an EJavaObject (or OclAny). I don't know how to make a sequence look like an EJavaObject, OclAny or EObject. A simple cast (oclAsType) doesn't seem to work?
Any ideas?
Re: [QVT] Adding element to feature [message #725142 is a reply to message #723721] Wed, 14 September 2011 00:56 Go to previous message
Using eSet and eGet in QVTo ignores the capabilities of QVTo to
transform rather than poke and peek. Occasionally you want to fold
multiple passes into a single transforation, so QVTo's List and Dict may
come in helpful.
However if you really want to treat QVTo as a wrapper for the EMF Java
API, you should learn to use EMF, then you will understand that EMF
collection manipulation uses .get().add()...
Ed Willink
On 09/09/2011 10:13, Wilbert Alberts wrote:
> larger then 1?
> following helper:
> Element)
> e.eSet(f, a);
> something like:
> Element)
> seem to work?
> Any ideas?
Previous Topic:How to handle references?
Next Topic:[QVT] undeterministic behaviour - sometimes classifiers disappear
Current Time: Tue Sep 16 19:58:14 EDT 2025
Powered by FUDForum. Page generated in 0.02813 seconds
