Home » Language IDEs » PHP Development Tools (PDT) » PHP Not showing up in Project list
PHP Not showing up in Project list [message #72339] Tue, 03 June 2008 09:28 Go to next message
Originally posted by: jeff.php.gmail.com
I have installed the latest release of PDT All In One. The problem is
that PHP is not showing up when I select New Other in the Project Explorer
I can't see it in the preferences section either to change editor stuff. I
only see Java
Re: PHP Not showing up in Project list [message #72359 is a reply to message #72339] Tue, 03 June 2008 10:19 Go to previous messageGo to next message
This is a very common problem. Ensure you are using at least Java 5.0 to run PDT. You are most
likely using Java 1.4.2.
To check go to help-->About Eclipse and click on Configuration Details. You should be able to
determine the version of java you are using from that, look for something like
java.version=1.5.0
which in my case shows that it is Java 5.0
Dave Kelsey
> Explorer I can't see it in the preferences section either to change
> editor stuff. I only see Java
Re: PHP Not showing up in Project list [message #72377 is a reply to message #72359] Tue, 03 June 2008 12:32 Go to previous messageGo to next message
Originally posted by: codeslave.ca.ibm.com
See also:
http://wiki.eclipse.org/IRC_FAQ#How_do_I_start_Eclipse.3F
http://wiki.eclipse.org/PDT/Installation#PDT_All-In-One
http://wiki.eclipse.org/PDT/Installation#Eclipse_3.3_.2F_Eur opa_.2F_PDT_1.0
Assaf, Guy, Roy, (others)... do you think we could avoid these FAQ
questions if we improved the installation instructions on the
website/downloads page to point to these more current wiki docs?
If so, show some love for bug 231851.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=231851
Nick
> run PDT. You are most likely using Java 1.4.2.
> You should be able to determine the version of java you are using from
> java.version=1.5.0
> Dave Kelsey
Nick Boldt :: Release Engineer, IBM Toronto Lab
Eclipse Modeling :: http://www.eclipse.org/modeling
http://wiki.eclipse.org/index.php/User:Nickb
Re: PHP Not showing up in Project list [message #72395 is a reply to message #72377] Tue, 03 June 2008 14:34 Go to previous message
Nick,
Thanks for raising this.
We'll review your proposals and update the documentation.
Guy.
-----Original Message-----
Posted At: Tuesday, June 03, 2008 7:33 PM
Posted To: eclipse.tools.pdt
Conversation: PHP Not showing up in Project list
Subject: Re: PHP Not showing up in Project list
See also:
1.0
Nick
to
Details.
> java.version=1.5.0
> Dave Kelsey
is
Previous Topic:PHP Perspectives
Next Topic:Lost project builder
Current Time: Sat Nov 22 07:47:24 EST 2025
Powered by FUDForum. Page generated in 0.04441 seconds
