Build Error [message #723401] |
Thu, 08 September 2011 09:23  |
I checked out the latest code form Sapphire CVS repository and when I executed the
ant clean-start -Ddownloads=.....
I got the following build failure
Quote:BUILD FAILED
/home/kamesh/sapphire/sources/org.eclipse.sapphire/build.xml:50: The following error occurred while executing this line:
/home/kamesh/sapphire/sources/org.eclipse.sapphire/build.xml:1192: The following error occurred while executing this line:
/home/kamesh/sapphire/sources/org.eclipse.sapphire/build.xml:907: The following error occurred while executing this line:
/home/kamesh/sapphire/sources/org.eclipse.sapphire/build.xml:867: The following error occurred while executing this line:
/home/kamesh/sapphire/sources/org.eclipse.sapphire/build.xml:869: The following error occurred while executing this line:
/home/kamesh/sapphire/sources/org.eclipse.sapphire/build.xml:1108: The following error occurred while executing this line:
/home/kamesh/sapphire/sources/org.eclipse.sapphire/build.xml:1072: Failed to download /eclipse/downloads/drops4/I20110824-1000/eclipse-4.2-I20110824-1000-repository.zip from Eclipse Foundation.
Any idea how to resolve this ?
Also couple of questions, I see the latest head is tuned for juno-42, so when we develop or contribute code with this it will work form heilos to juno-42 ?
~Kamesh
FUDForum. Page generated in 0.51818 seconds
