Home » Language IDEs » ServerTools (WTP) » NewXMLGenerator.createCMDocument() returns null
NewXMLGenerator.createCMDocument() returns null [message #723478] Thu, 08 September 2011 12:20 Go to next message
Hi all,
Just found out that NewXMLGenerator would be a great solution for me to create empty xml skeletons based on schemas.
However, the code snippet below returns cmDocument = null no matter what I do. Am I missing something really obvious here, or is this a bug?
schemaFileName = "file:///home/.../workspace3/xmlgeneratorplugin/myxsd.xsd";
CMDocument cmDocument = NewXMLGenerator.createCMDocument(schemaFileName, errorInfo);
The errorInfo[0] is empty, which strangely implies that all went fine.
I've tried different ways of passing the path including the IFile way...
Georg
Re: NewXMLGenerator.createCMDocument() returns null [message #723784 is a reply to message #723478] Fri, 09 September 2011 09:08 Go to previous messageGo to next message
i found the problem. forgot to add the required plugins in the dependencies section...
my bad..
Re: NewXMLGenerator.createCMDocument() returns null [message #878608 is a reply to message #723784] Tue, 29 May 2012 11:45 Go to previous messageGo to next message
Please, could you tell me, which are those plugins dependencies?
Thanks!
Re: NewXMLGenerator.createCMDocument() returns null [message #879168 is a reply to message #878608] Wed, 30 May 2012 12:43 Go to previous messageGo to next message
I have the same problem and I added this plugin dependencies
org.eclipse.core.runtime,
org.eclipse.core.resources;
org.eclipse.wst.common.uriresolver;
org.eclipse.wst.sse.core;
org.eclipse.wst.xml.core;
org.eclipse.wst.xml.ui;
org.eclipse.xsd;
com.ibm.icu;
org.eclipse.wst.xsd.core;
org.eclipse.wst.xsd.ui;
org.eclipse.emf.ecore;
Please, could you tell me if I am forgetting something? The CMDocumentFactoryRegistryReader.java:43 is returning null, when I'm creating the CMDocument cmDocument = NewXMLGenerator.createCMDocument(schemaFileName, null);
at org.eclipse.wst.xml.core.internal.contentmodel.factory.CMDocumentFactoryRegistryReader.readRegistry(CMDocumentFactoryRegistryReader.java:43)
at org.eclipse.wst.xml.core.internal.contentmodel.ContentModelManager.getCMDocumentFactoryRegistry(ContentModelManager.java:63)
at org.eclipse.wst.xml.core.internal.contentmodel.ContentModelManager.createCMDocument(ContentModelManager.java:55)
Re: NewXMLGenerator.createCMDocument() returns null [message #879409 is a reply to message #879168] Thu, 31 May 2012 03:10 Go to previous messageGo to next message
Hello Maria,
Unfortunately, I don't remember which plugins I added. It's been a long time since I had the problem. My approach has changed as well. I now modify the original eclipse xsd plugin to serve my purposes. In this approach all dependencies are solved when importing the plugin. Maybe this is the easiest way out for you too?
Really sloppy of me not to list the plugin dependencies that solved my problem. Sorry about that! Embarrassed
Here is the list on my dependencies tab.
org.eclipse.ui.ide;bundle-version="[3.5.0,4.0.0)",
org.eclipse.ui.views;bundle-version="[3.4.0,4.0.0)",
org.eclipse.jface.text;bundle-version="[3.5.0,4.0.0)",
org.eclipse.ui.workbench.texteditor;bundle-version="[3.5.0,4.0.0)",
org.eclipse.wst.sse.ui;bundle-version="[1.2.0,1.4.0)",
org.eclipse.wst.sse.core;bundle-version="[1.1.500,1.2.0)",
org.eclipse.ui;bundle-version="[3.5.0,4.0.0)",
org.eclipse.core.resources;bundle-version="[3.5.0,4.0.0)",
org.eclipse.core.runtime;bundle-version="[3.5.0,4.0.0)",
org.eclipse.wst.common.uriresolver;bundle-version="[1.1.301,1.2.0)",
org.eclipse.wst.xml.core;bundle-version="[1.1.500,1.2.0)",
org.eclipse.wst.common.ui;bundle-version="[1.1.400,1.2.0)",
org.eclipse.wst.validation;bundle-version="[1.2.100,1.3.0)",
org.eclipse.core.expressions;bundle-version="[3.4.100,4.0.0)",
org.eclipse.core.filesystem;bundle-version="[1.3.0,2.0.0)",
Good luck!
Re: NewXMLGenerator.createCMDocument() returns null [message #879455 is a reply to message #879409] Thu, 31 May 2012 05:00 Go to previous message
Thanks a lot!!! Now it is working correctly!!!
Previous Topic:JSF - More tool support
Next Topic:Plain Java Project Web Service Client
Current Time: Sun Jul 27 11:28:31 EDT 2025
Powered by FUDForum. Page generated in 0.08050 seconds
