Home » Eclipse Projects » Virgo » Can I use multiple Host entries in tomcat-server.xml(Question on how virgo applications get mapped to a host)
Can I use multiple Host entries in tomcat-server.xml [message #723419] Thu, 08 September 2011 10:01 Go to next message
In Virgo is it possible to specify multiple host entries in tomcat-server.xml? I've tried, but cannot reach applications in any host other than the default "localhost". Basically I don't see how I could for example deploy an application to the pickup directory, and associate it with a particular host.
What I'd like to do is deploy applications in Virgo such that:
www.domainA.com - serves WAB A that uses application in Plan S
www.domainB.com - serves WAB B that uses application in Plan S
where Plan S defines a shared application providing services that all domains use.
Jack
Re: Can I use multiple Host entries in tomcat-server.xml [message #723440 is a reply to message #723419] Thu, 08 September 2011 10:50 Go to previous messageGo to next message
can you see whether this enhancement (https://bugs.eclipse.org/bugs/show_bug.cgi?id=310775) is what you asked for?
Re: Can I use multiple Host entries in tomcat-server.xml [message #723458 is a reply to message #723440] Thu, 08 September 2011 11:35 Go to previous messageGo to next message
Thanks Violeta, yes that describes exactly what I'm asking for. The note about having virtual hosts using different WARs to server "/" context is particularly relevant.
It appears that configuration of virtual hosts in Tomcat isn't currently supported by VTS. If so, should it be noted in the User Guide?
Re: Can I use multiple Host entries in tomcat-server.xml [message #723516 is a reply to message #723458] Thu, 08 September 2011 13:49 Go to previous message
here it is https://bugs.eclipse.org/bugs/show_bug.cgi?id=357129
Previous Topic:Hot deployer activated too early
Next Topic:An artifact in a non-atomic plan fails to start, VWS stops all other artifacts
Current Time: Sat Jul 26 09:02:37 EDT 2025
Powered by FUDForum. Page generated in 0.05351 seconds
