Re: 'Workbench has not yet been created' issue [message #723427 is a reply to message #720622] |
Thu, 08 September 2011 10:22  |
The Activator will be called when the plugin is activated. This is basically an OSGI function and is not directly related to the Workbench state!
If your plugin wants to invoked any GUI functions you need to wait until the Workbench is fully loaded!
You can monitor the state of the application via a WorkbenchWindowAdvisor. This class defines multiple callback methods.
The relevant methods in this case are:
postWindowCreate - called after the window has been created, either from an initial state or from a restored state; used to adjust the window
openIntro - called immediately before the window is opened in order to create the introduction component, if any.
postWindowOpen - called after the window has been opened; use to hook window listeners, etc.
FUDForum. Page generated in 0.03650 seconds
