Home » Archived » Jubula » AUT Agend does not start
AUT Agend does not start [message #705151] Fri, 29 July 2011 09:57 Go to next message
I try to start the AUT Agend but it alwasy fails with the following error message.
'The JVM could not be started. Them maximum heap size (-Xmx) might to be too large or an antivirus or firewall tool could block the execution.'
Win XP 32 Bit SP 3 on VMWare
Intel Xenon (E5440) with 2GB ram.
No antivirus tool.
Windows firewall disabled.
Any ideas ?
Andreas
Re: AUT Agend does not start [message #707281 is a reply to message #705151] Mon, 01 August 2011 08:35 Go to previous messageGo to next message
That configuration matches our nightly test environment for XP almost exactly. No idea what is going on.
Could you please check the log files (in your home directory in a .jubula sub directory) and attach them to this thread.
Achim
Re: AUT Agend does not start [message #707292 is a reply to message #707281] Mon, 01 August 2011 09:02 Go to previous messageGo to next message
The log file is empty Sad
....\.jubula\logs\aut_agent.log
Could I start a debug mode ? Or run it via the command shell ?
Andreas
Re: AUT Agend does not start [message #707888 is a reply to message #705151] Tue, 02 August 2011 03:24 Go to previous messageGo to next message
To change the heap size you have to insert -J-Xmx following the autaugent.exe command and insert a specific value (64, 128, 256 etc.)
I hope this solves your problem.
Best regards
Oliver
Re: AUT Agend does not start [message #707908 is a reply to message #707888] Tue, 02 August 2011 03:54 Go to previous messageGo to next message
Hi Andreas,
recently I had this error message, too. At this point I was logged in with user rights. When I logged in with admin-rights, the AUTAgent started correctly.
Later I installed JDK 1.6 Update 26 on my machine, now the AUTAgent starts correctly when I'm logged in as a user.
At first appearance I have no idea, why this happens this way, but it's what I observed.
Deviating from your configuration I'm running a virus scanner, but in both as user as well as as admin account.
Niels
Re: AUT Agend does not start [message #709330 is a reply to message #707908] Wed, 03 August 2011 15:58 Go to previous messageGo to next message
Still no luck ...
@Niels
I allways work as admin on my test maschine, and have already java 1.6 fp 26 installed.
@Oliver
Starting autaugent.exe -J-Xmx 64 (or 128...) brings still up the error.
Starting autaugent.exe -J-Xmx64 (or 128...) shows no error but the agent doesn't start.
Also the aut_agent.log is still empty. Nothing in the event/application log
Andreas
[SOLVED] AUT Agend does not start [message #723339 is a reply to message #709330] Thu, 08 September 2011 07:20 Go to previous message
Typing autaugent.exe -J-Xmx64m brings up the agent.
So the little 'm' was missing.
Thaks all for help.
Andreas
Previous Topic:Editing AUT Configuration in New Project wiz is very slow
Next Topic:testexec and MySQL
Current Time: Sun Jul 27 09:01:23 EDT 2025
Powered by FUDForum. Page generated in 0.05322 seconds
