Home » Archived » Buckminster » (no subject)
(no subject) [message #723324] Thu, 08 September 2011 06:06 Go to next message
Hi all,
I have a problem regarding some plugins which are not accepted because of
the versioning.
A plugin-based PDE export from inside Eclipse does work. Now I am trying to
cope with a feature-based build using Buckminster.
During materialisation for a feature-based build job I get messages like:
org.eclipse.dltk.core[3.0.0.v20110609-1525,3.0.0.v20110609-1525]: Version
3.0.0.qualifier rejected: Not designated by
I searched for this error, but it revealed not much information. In the
class
org.eclipse.buckminster.core/src/java/org/eclipse/buckminster/core/version/AbstractSCCSVersionFinder.java
I found this code which might be related:
if (!(versionRange == null || versionRange.isIncluded(version))) {
// Discriminated by our designator
logDecision(ResolverDecisionType.VERSION_REJECTED, version,
NLS.bind(Messages.Not_designated_by_0, versionRange));
continue;
So it searches for the replaced qualifier, compares it with qualifier as
string? My main problem is that I can't really understand the cause of the
problem preventing me from searching solutions.
For example let's take the plugin
org.eclipse.dltk.launching[3.0.0.v20110423,3.0.0.v20110423]
My feature includes it like:
<import plugin="org.eclipse.dltk.launching" version="3.0.0"
match="greaterOrEqual"/>
Here is the log Buckminster has shown for it:
Using resolver Local resolver
Trying provider local(materialized)
No materialization found for
Trying provider local(workspace)
No open workspace project found that corresponds to
Trying provider local(target)
Rejecting provider eclipse.platform(plugin/org.eclipse.dltk.launching): No
component match was found
Using resource map
file:/var/lib/jenkins/jobs/DLTK_test/workspace/scm/dltktest.build/build.rmap
Using search path dltk.helpers
Trying provider local({0}/scm/{1}
[/var/lib/jenkins/jobs/DLTK_test/workspace/scm/org.eclipse.dltk.launching])
Found match
Using provider local({0}/scm/{1}
Version 3.0.0.qualifier rejected: Not designated by
No provider was found that could resolve the request
Redirecting to resource map
file:/var/lib/jenkins/jobs/DLTK_test/workspace/scm/dltktest.build/build/build_eclipse.rmap
Using search path eclipse.platform
Trying provider
p2(http://download.eclipse.org/eclipse/updates/3.7[http://download.eclipse.org/eclipse/updates/3.7])
Rejecting provider
p2(http://download.eclipse.org/eclipse/updates/3.7[http://download.eclipse.org/eclipse/updates/3.7]):
No component match was found
Using search path eclipse.main
Trying provider
p2(http://download.eclipse.org/releases/indigo[http://download.eclipse.org/releases/indigo])
Found match 3.0.0.v20110423
Using provider
I also wondered from where the version 3.0.0.v20110423 is taken from - and
why it is considered in my feature-based build. I searched the whole
workspace for this particular version number, but found nothing. Seems like
this version is required by another plugin of Eclipse. As written above the
feature includes "3.0.0". The plugin manifest contains "3.0.0.qualifier".
Any idea how to let Buckminster not block the newer version? Maybe a version
converter is the way to go?
Thank you very much for reading this.
Axel
(no subject) [message #723333 is a reply to message #723324] Thu, 08 September 2011 06:58 Go to previous messageGo to next message
Hi Axel,
A component with a version like 3.0.0.qualifier is either in source form or has been incorrectly built. A version
requirement like [3.0.0.v20110609-1525,3.0.0.v20110609-1525] seems to be asking for an explicit version of that
component. So question is, where does this requirement stem from? Who added the qualifier?
Buckminster can add a qualifier during a build, but never during a resolution so if you see versions with expanded
qualifiers during resolution, then you can be certain that somewhere such a requirement exists. Somewhere, some
component in the transitive scope of your resolution, is requesting
org.eclipse.dltk.launching[3.0.0.v20110423,3.0.0.v20110423].
- thomas
On 2011-09-08 12:06, Axel Guckelsberger wrote:
> Hi all,
> the versioning.
> class
> continue;
> Using resource map
> Found match
> Trying provider
> Rejecting provider
> Trying provider
> Using provider
> Regards,
> Axel
(no subject) [message #724040 is a reply to message #723333] Sat, 10 September 2011 09:05 Go to previous message
Hi Thomas,
thanks for your explaination.
Axel
Previous Topic:Re: How to configure a reader to read from a target platform directory
Next Topic:can't update features in buckminster
Current Time: Thu Jul 24 00:36:38 EDT 2025
Powered by FUDForum. Page generated in 0.05669 seconds
