Home » Eclipse Projects » Virgo » Failure invoking bundle.loadClass(String clazz) in version M06 and higher
Failure invoking bundle.loadClass(String clazz) in version M06 and higher [message #722390] Mon, 05 September 2011 11:50 Go to next message
Hello community,
I have developed a custom servlet inside a Fragment Bundle and when i execute the following command:
return (Class<? extends Application>) bundle.loadClass(className);
or the following snippet to retrieve a Spring bean (when i want to get the same object but through the ApplicationContext registered as service by Spring DM):
 final Application application = (Application) springContext.getBean(beanParam);
And exception is triggered :
org.eclipse.virgo.kernel.osgi.framework.ExtendedClassNotFoundException: com.vaadin.osgi.spring.MyVaadinApplication in KernelBundleClassLoader: [bundle=com.vaadin.osgi.spring_0.0.1.SNAPSHOT]
org.eclipse.virgo.kernel.userregion.internal.equinox.KernelBundleClassLoader.loadClass(KernelBundleClassLoader.java:138)
I thing the source of the problem is the invoking of the loadClass method from the Bundle Interface from the OSGi framework. I only reproduce this failure in versions equal or higher than M06. In lower version all is correct and the servlet works.
Thank you.
[Updated on: Mon, 05 September 2011 11:51] by Moderator
Re: Failure invoking bundle.loadClass(String clazz) in version M06 and higher [message #722415 is a reply to message #722390] Mon, 05 September 2011 13:59 Go to previous messageGo to next message
Virgo Tomcat 3 now conforms strictly with RFC 66 and therefore some manifest headers are no longer set to default values. For more details see the Migration Notes / Web.
Can you please check if setting the WABHeaders to defaulted will help?
Re: Failure invoking bundle.loadClass(String clazz) in version M06 and higher [message #722607 is a reply to message #722415] Tue, 06 September 2011 06:30 Go to previous message
Hi Hristo,
you were right, finally i needed to add explicitly the Bundle-Classpath: WEB-INF/classes to the webapp´s MANIFEST. But also i have tested the edition of the org.eclipse.virgo.web.properties setting the defaulted value in the WABHeaders KEY, as u asked me, without the Bundle-ClassPath header and even it works.
So now it runs in any Virgo version.
Now i am able to show my Vaadin+Virgo example in the following OSGi ALLIANCE COMMUNITY EVENT
Thank you very much.
Previous Topic:Can't create plan project as described in Programmer Guide
Next Topic:Preventing double bundle start when developing plan in Eclipse tooling
Current Time: Fri Jul 25 23:35:02 EDT 2025
Powered by FUDForum. Page generated in 0.27065 seconds
