Home » Eclipse Projects » WindowBuilder » wbp-meta folder not in classpath?
wbp-meta folder not in classpath? [message #722287] Mon, 05 September 2011 05:04 Go to next message
I have an issue with my library of components: the wbp-meta folder is ignored if my library project is not imported in the Eclipse workspace.
Here is my test case:
* change your target platform to reference the attached bundle com.sneda.wb.issue1_1.0.0.201109051047.jar
* create a new Plug-in Project
* Add com.sneda.wb.issue1 as a plugin dependency
* Add the component com.sneda.wb.issue1.api.MyComponent1 to the palette
Here you should see a purple square icon as the image of MyComponent1 in the palette. You should also have a property "myProperty" with true as default, in the Properties part of the WB editor (defined in MyComponent1.wbp-component.xml).
Thanks a lot for your help.
--andiqo
Re: wbp-meta folder not in classpath? [message #722441 is a reply to message #722287] Mon, 05 September 2011 15:30 Go to previous messageGo to next message
1. No need to put wbp-meta into plugin classpath, none of WB standard plugins does this.
2. It is enough just to have wbp-meta folder in jar which is in project classpath, because you explicitly stated that you want to use this jar. However in case of plugin you have to tell WB that this plugins wants to contribute to some toolkit. WB can not look up hundreds of plugins for wbp-meta folder.
So, you need at least.
	<extension point="org.eclipse.wb.core.toolkits">
		<toolkit id="org.eclipse.wb.swing">
		</toolkit>
	</extension>
Re: wbp-meta folder not in classpath? [message #722603 is a reply to message #722441] Tue, 06 September 2011 05:58 Go to previous messageGo to next message
Thanks a lot for your answer. But I still need help I'm afraid..
Thus I added the lines you suggested in the plugin.xml of my bundle: com.sneda.wb.issue1. Then I regenerate the plugin archive and reference it from another project in order to add MyComponent1 to the WB palette again. But then, I get this error message in the Eclipse Problems view:
Archive for required library: '/home/SNEDA-N-DOM/nio/dev/eclipse/ws-temp/.metadata/.plugins/org.eclipse.pde.core/.external_libraries/com.sneda.wb.issue1_1.0.0.201109061145/wbp-meta' in project 'com.sneda.test.wb' cannot be read or is not a valid ZIP file
Indeed:
nio@lxnio:~/dev/eclipse/ws-temp/.metadata/.plugins/org.eclipse.pde.core/.external_libraries/com.sneda.wb.issue1_1.0.0.201109061145$ ll
total 8
drwxr-xr-x 2 nio utilisa.^du^domaine 4096 2011-09-06 11:45 ./
drwxr-xr-x 3 nio utilisa.^du^domaine 4096 2011-09-06 11:45 ../
-rw-r--r-- 1 nio utilisa.^du^domaine    0 2011-09-06 11:45 wbp-meta
You could find attached my very simple components library: com.sneda.wb.issue1, with only one component: MyComponent1
Thanks again.
--andiqo
Re: wbp-meta folder not in classpath? [message #722669 is a reply to message #722603] Tue, 06 September 2011 09:08 Go to previous messageGo to next message
I don't know.
You archive looks good.
http://code.google.com/javadevtools/wbpro/NewComponentsTutorial.pdf
See item 1.3, you need library element, if you want not just describe component, but also allow dropping it from palette.
Re: wbp-meta folder not in classpath? [message #724845 is a reply to message #722669] Tue, 13 September 2011 06:42 Go to previous messageGo to next message
Hummhh, my archive must also be copied in the dropins folder...
Thus, if I have com.sneda.wb.issue1_1.0.0.201109061145.jar in the dropins folder of my running instance of Eclipse and in the target definition file for my projects (I use a file named myproduct.target which is the TP used to develop our plugins) all is fine. Unfortunately, this is not a viable solution as my "real" bundle (the one which defines all the components to be visible in the palette) has lots of other dependencies. And I don't want to copy everything in the dropins folder.
So for me, a solution would be to have a plugin in the dropins folder which would tell WindowBuilder that another bundle have a wbp-meta folder to be scanned... I tried using a ToolkitDescription for that but without success.
Or perhaps a better solution would be that WindowBuilder does not need the plugin from the dropins folder anymore?
Any idea appreciated.
Thanls a lot.
++andiqo
[Updated on: Tue, 13 September 2011 06:42] by Moderator
Re: wbp-meta folder not in classpath? [message #724853 is a reply to message #722287] Tue, 13 September 2011 07:00 Go to previous messageGo to next message
Thanls a lot.
++andiqo
Re: wbp-meta folder not in classpath? [message #724919 is a reply to message #724853] Tue, 13 September 2011 09:44 Go to previous message
I found a solution which looks OK. Have 2 plug-ins:
(1) com.sneda.wb.issue1.jar which contains the components classes
(2) com.sneda.wb.issue1.wbp.jar which uses the extension point org.eclipse.wb.core.toolkits and contains the wbp-meta folder.
1 goes in the target platform definition
2 in the dropins folder of my Eclipse instance
Thanks again for you help.
++andiqo
Previous Topic:NPE in org.eclipse.wb.internal.swt.support.AbstractSupport$1 after adding a getter
Next Topic:ResourceManager class
Current Time: Fri Jul 25 22:55:35 EDT 2025
Powered by FUDForum. Page generated in 0.08999 seconds
