Home » Modeling » Graphiti » Editor marked dirty after loading default diagramm on startup
Editor marked dirty after loading default diagramm on startup [message #721673] Fri, 02 September 2011 09:56 Go to next message
I have a RCP which loads the graphiti Editor post startup and initializes it with a default diagram. The resources of the diagram are also saved to disk. Everything works fine, except the editor is marked dirty
(and probably due to this a emf exception after creating a new model object and saving afterwards -> java.lang.IllegalStateException: Cannot modify resource set without a write transaction).
here are some code snippets for better understanding.
within the postStartup method in my ApplicationWorkbenchAdvisor:
URI uri = URI.createPlatformResourceURI(diagramFile.getFullPath().toString(), true);
TransactionalEditingDomain domain = FileService.createEmfFileForDiagram(uri, diagram);
String providerId = GraphitiUi.getExtensionManager().getDiagramTypeProviderId(diagram.getDiagramTypeId());
editorInput = new DiagramEditorInput(EcoreUtil.getURI(diagram), domain, providerId, true);
try {
	PlatformUI.getWorkbench().getActiveWorkbenchWindow().getActivePage().openEditor(editorInput, editorID);
} catch (PartInitException e) {
	LOG.error("Error while opening diagram editor", e);
The method createEmfFileForDiagram
public static TransactionalEditingDomain createEmfFileForDiagram(URI diagramResourceUri, final Diagram diagram) {
	final TransactionalEditingDomain editingDomain = DiagramEditorFactory.createResourceSetAndEditingDomain();
	final ResourceSet resourceSet = editingDomain.getResourceSet();
	URI modelResourceUri = diagramResourceUri.trimFragment().
		trimFileExtension().appendFileExtension(OtxPackage.eNS_PREFIX);
	final Resource modelResource = resourceSet.createResource(modelResourceUri);
	final Resource diagramResource = resourceSet.createResource(diagramResourceUri);
	final CommandStack commandStack = editingDomain.getCommandStack();
	commandStack.execute(new RecordingCommand(editingDomain) {
		protected void doExecute() {
			modelResource.setTrackingModification(true);
			diagramResource.setTrackingModification(true);
			diagramResource.getContents().add(diagram);
			try {
				EObject rootObject = OtxUtil.createDefaultOtxSkeleton();
				modelResource.getContents().add(rootObject);
				Map<Object, Object> options = new HashMap<Object, Object>();
				options.put(XMLResource.OPTION_ENCODING, "UTF-8");
				modelResource.save(options);
				diagramResource.save(Collections.EMPTY_MAP);
			} catch(IOException ioe) {
				ioe.printStackTrace();
			} catch (DatatypeConfigurationException e) {
	return editingDomain;
So what do i have to do for not marking the editor dirty)?
thx!
[Updated on: Fri, 02 September 2011 09:56] by Moderator
Re: Editor marked dirty after loading default diagramm on startup [message #721676 is a reply to message #721673] Fri, 02 September 2011 10:12 Go to previous messageGo to next message
Not sure about your issue but:
I guess your FileService class is copied from the examples.common jar (as I did)
Then, didn't you try to call the save() method of that class, after createEmfFileForDiagram(),
instead of doing the save inside it?
Re: Editor marked dirty after loading default diagramm on startup [message #721681 is a reply to message #721676] Fri, 02 September 2011 10:41 Go to previous messageGo to next message
thanks, that resolved the "marked dirty" issue! (see new createEmfFileForDiagram () method below)
But the other problem was not solved.
After creating a new model object and saving afterwards, i get:
But i think this is another issue and i will open another thread, if i cannot figure it out myself.
			.trimFileExtension().appendFileExtension(OtxPackage.eNS_PREFIX);
	final Map<Resource, Map<?, ?>> resourceOptionsMap = new HashMap<Resource, Map<?, ?>>();
			try {
				resourceOptionsMap.put(modelResource, options);
				resourceOptionsMap.put(diagramResource, Collections.EMPTY_MAP);
	save(editingDomain, resourceOptionsMap);
Re: Editor marked dirty after loading default diagramm on startup [message #722265 is a reply to message #721681] Mon, 05 September 2011 03:41 Go to previous message
You need to do perform every change operation to your model inside an EMF
transaction, that will solve this issue.
HTH,
Michael
"buschcobolt" schrieb im Newsbeitrag news:j3qp9e$23g$1@news.eclipse.org...
get:java.lang.IllegalStateException: Cannot modify resource set without a
write transactionBut i think this is another issue and i will open another
..createResourceSetAndEditingDomain();
..trimFileExtension().appendFileExtension(OtxPackage.eNS_PREFIX);
..createResource(modelResourceUri);
..createResource(diagramResourceUri);
Map<?, ?>>();
try {
Previous Topic:Implementing features on which level?
Next Topic:creating nested shapes
Current Time: Sun Jul 27 08:57:57 EDT 2025
Powered by FUDForum. Page generated in 0.04165 seconds
