Home » Eclipse Projects » Technology Project and PMC » Out of Memory
Out of Memory [message #72140] |
Tue, 23 May 2006 02:30  |
I am using Eclipse 3.1 to code some very large projects (about 3.000
files, most of them .java, but some .xml, .xlst etc., too). To compile,
I am running a very complex ANT script.
Unfortunatley, every one or two hours, the IDE runs out of memory (even
I am running a 1 GB machine, having set "-Xmx 512M" when starting
eclipse.exe). It seems like the IDE is not taking respect of the "-Xmx
512M" because if I remove the switch, its not better and not worse!
When I'm taking a look at Windows' task manager it tells me, eclipse is
not nearly using the 512 megs!
So how can I convince eclipse IDE to really take that 512M I am willing
to reserve for it?
Re: Out of Memory [message #72191 is a reply to message #72140] |
Wed, 24 May 2006 04:33   |
> compile, I am running a very complex ANT script.
> (even I am running a 1 GB machine, having set "-Xmx 512M" when
> starting eclipse.exe). It seems like the IDE is not taking respect of
> the "-Xmx 512M" because if I remove the switch, its not better and not
> worse!
Make sure you use -vmargs -Xmx512M
Dani
> is not nearly using the 512 megs!
> willing to reserve for it?
Re: Out of Memory [message #72209 is a reply to message #72191] |
Wed, 24 May 2006 06:15   |
>> worse!
Actually I am doing this already:
C:\eclipse\eclipse.exe -vmargs -Xmx512M
So what to do now?
BTW, OS is Windows XP Pro SP 2, Java is Sun JDK 1.5.0_06.
> Dani
Re: Out of Memory [message #72226 is a reply to message #72209] |
Wed, 24 May 2006 09:39   |
You may run out of PermGen space.
You can increase the PermGen space limit with -vmargs
-XX:MaxPermSize=<megabytes>m (default = 64m)
>>> not worse!
> So what to do now?
>> Dani
Re: Out of Memory [message #72318 is a reply to message #72226] |
Mon, 29 May 2006 03:35  |
Indeed sometimes it posted the word "PermGen".
Why isn't the VM adopting more "PermGen" when I add -Xmx512M...?
Okay, I'll give it a try!
Markus
>>>> of the "-Xmx 512M" because if I remove the switch, its not better
>>>> and not worse!
>> So what to do now?
>>> Dani
Re: Out of Memory [message #600531 is a reply to message #72140] |
> worse!
Dani
Re: Out of Memory [message #600539 is a reply to message #72191] |
>> worse!
So what to do now?
> Dani
Re: Out of Memory [message #600544 is a reply to message #72209] |
>>> not worse!
> So what to do now?
>> Dani
Re: Out of Memory [message #600604 is a reply to message #72226] |
Markus
>>>> and not worse!
>> So what to do now?
>>> Dani
Current Time: Sun Jul 27 10:08:59 EDT 2025
Powered by FUDForum. Page generated in 0.07562 seconds
