Home » Archived » M2M (model-to-model transformation) » [QVTo] How models from QVT conforms to models from EMF ?
[QVTo] How models from QVT conforms to models from EMF ? [message #721644] Fri, 02 September 2011 08:17 Go to next message
Hi everybody Smile
I would like to know how the "mapping" from EMF models to "QVT models" is done. I mean - I would like to know exactly how to make an EMF model for using it in QVT like something like this:
metamodel ABC {
  class A {
    b_elems : Sequence(B);
    contains c_elemnt : Sequence(C);
  class B {
    str: String;
    int: Integer;
    bool : Boolean;
  class C extends B {
    a_set : Set(A);
(this is QVT-like metamodel description)
1. How to implement "sequence" in EMF ?
2. How to implement "set" in EMF ?
(exactly: could you show me an example of EMF metamodel that conforms to my example ?)
Edit:
I will have to use dynamic models and metamodels if it makes a difference (I mean: created from scratch in my Java code).
Thanks in advance Smile
Greetings,
Piotr Zajączkowski
[Updated on: Fri, 02 September 2011 08:18] by Moderator
(no subject) [message #722079 is a reply to message #721644] Sun, 04 September 2011 05:37 Go to previous message
Hi Piotr
Understanding this is currently aggravated by an OCL/UML inconsistency,
that may be resolved in the next version.
UML: T[*]{ordered, unique} == OCL: OrderedSet(T)
UML cannot declare nested collections, OCL can; Sequence(Set(String)).
OCL cannot declare bounded collections, UML can; String[2..4] {ordered}.
Ecore and UML are similar (except that Ecore has EString rather than
String etc and in practice all collections are realised by EList<T>).
You can see the EMF types by creating a simple Ecore model, so for
Sequence, create
class X
property names : String[*] { ordered, !unique }
and then genmodeling to produce Java code.
You may find the OCLinEcore editor convenient for textual model definition.
Ed Willink
On 02/09/2011 13:17, Piotr aj?czkowski wrote:
> Hi everybody :)
> metamodel ABC {
> class A {
> class B {
> str: String;
> int: Integer;
> bool : Boolean;
> class C extends B {
> a_set : Set(A);
> to my example ?)
> Thanks in advance :)
> Greetings,
> Piotr Zajączkowski
Previous Topic:[ATL] Check for duplicate target objects.
Next Topic:About ATL transformations and classes in the target model
Current Time: Fri Jul 18 17:56:26 EDT 2025
Powered by FUDForum. Page generated in 0.03865 seconds
