Home » Archived » Sapphire » WIKI Article - Extending Sapphire Wizards(Extending Sapphire Wizards)
WIKI Article - Extending Sapphire Wizards [message #721918] Sat, 03 September 2011 11:36 Go to next message
I have posted an WIKI article on to extend Sapphire Wizard and register them using plugin.xml @ http://wiki.eclipse.org/Extending_Sapphire_Wizard
Hope it helps someone and also allows the community to add any additional information/knowledge that I might have missed.
~Kamesh
[Updated on: Sat, 03 September 2011 11:38] by Moderator
Re: WIKI Article - Extending Sapphire Wizards [message #721980 is a reply to message #721918] Sat, 03 September 2011 17:52 Go to previous messageGo to next message
Hi Kamesh,
Thats a really good start. I've tried the same and came up with a bit another approach, due to the fact that IModelElement cannot be hook up to a Resource after its creation (see: http://www.eclipse.org/forums/index.php/t/237700/)
I really like the support here, so if there's any interest in my code, you can use it:
https://github.com/knowing/Knowing/blob/sapphire-model/de.lmu.ifi.dbs.knowing.ui/src/de/lmu/ifi/dbs/knowing/ui/wizard/SapphireCreateWizard.java
and a reference implementation
https://github.com/knowing/Knowing/blob/sapphire-model/de.lmu.ifi.dbs.knowing.ui/src/de/lmu/ifi/dbs/knowing/ui/wizard/NewDPUWizard.java
cheers,
Muki
Re: WIKI Article - Extending Sapphire Wizards [message #722057 is a reply to message #721980] Sun, 04 September 2011 02:48 Go to previous messageGo to next message
thanks for the references Muki, please feel free to update the WIKI page with your updates.
[Updated on: Sun, 04 September 2011 02:49] by Moderator
Re: WIKI Article - Extending Sapphire Wizards [message #722073 is a reply to message #722057] Sun, 04 September 2011 05:23 Go to previous messageGo to next message
I mentioned it in my class and on the Wiki Page, that SapphireWizard<M> declares addPages and performFinish as final, which keeps me of extending this class.
Is it possible to change these declarations in the next release? I'll open a enhancement ticket for this.
[Update]
I choose to comment on this report: https://bugs.eclipse.org/bugs/show_bug.cgi?id=353252
cheers,
Muki
[Updated on: Sun, 04 September 2011 05:29] by Moderator
Re: WIKI Article - Extending Sapphire Wizards [message #722085 is a reply to message #722073] Sun, 04 September 2011 07:22 Go to previous messageGo to next message
Hi Muki,
Before we go ahead and open the ticket did you try using the postPerformFinish() and just use the super.addPage(page) method to add any additional pages that might be required.
Let us know if that solves the problem.
I personally believe that we can remove the modifiers and the subclasses can overide these methods and add their pages either to the front of sdef defined pages or to the back of sdef defined pages, right now if we add our page using super.addPage it will be added only after the sdef wizard pages.
I leave this topic for further brainstrom, and we can decide based on Konstantin's reply as to why they were made final ?
~Kamesh
Re: WIKI Article - Extending Sapphire Wizards [message #722086 is a reply to message #722085] Sun, 04 September 2011 07:25 Go to previous messageGo to next message
Hi Kamesh,
super.addPages(..) won't really fix it, because in my option you first choose your resource and
than configure it. So as you mentioned
..,right now if we add our page using super.addPage it will be added only after the sdef wizard pages.
IMHO the final declaration isn't really needed here.
cheers,
Muki
Re: WIKI Article - Extending Sapphire Wizards [message #722088 is a reply to message #722086] Sun, 04 September 2011 07:33 Go to previous messageGo to next message
yeah i too feel the same, if we can remove the final modifer on the addPages of the SapphireWizard it can help us to place the pages either before Sapphire Wizard or after the Sapphire Wizard pages. It will give us the deal of extensibility.
I feel good if you can open the ticket for this where we need to remove the final modifiers on "peformFinish" and "addPages" and lets track it to closure. this will also allow Konstantin's view on the same.
An one more correction or suggestion from your Wizard class, if you are using a Model class for Wizard then then model class should be IExcutableModelElement and not just IModel element, please refer to the EZbug sample.
[Updated on: Sun, 04 September 2011 07:35] by Moderator
Re: WIKI Article - Extending Sapphire Wizards [message #722097 is a reply to message #722088] Sun, 04 September 2011 08:23 Go to previous messageGo to next message
I opend a ticket: https://bugs.eclipse.org/bugs/show_bug.cgi?id=356674
I thought about that. IMHO there's nothing to execute, when you create a file.
However I will change it in my class, because I'm not that deep into sapphire.
Re: WIKI Article - Extending Sapphire Wizards [message #722130 is a reply to message #722097] Sun, 04 September 2011 11:28 Go to previous message
A wizard represents an operation rather than a file. You might be gathering data to create a file, but you are still gathering that data into the state of an operation that will create a file when user clicks on Finish button... which will execute the operation.
Hope that is more clear. If you take a look at the EzBug sample, IBugReport is the model element that's re-used for file editor, wizard, etc., for the wizard IFileBugReportOp represents an operation that holds an IBugReport.
- Konstantin
Previous Topic:Extending Sapphire Wizards
Next Topic:Dynamic combobox content generated out of the model
Current Time: Fri Jul 25 08:48:33 EDT 2025
Powered by FUDForum. Page generated in 0.06675 seconds
