Home » Language IDEs » C / C++ IDE (CDT) » setting breakpoint while program runs
setting breakpoint while program runs [message #72039] Wed, 28 May 2003 14:15 Go to next message
Originally posted by: andrayk.futurewayNOSPAM.com
my program was running under debugger's control when I attempted to set
breakpoint in the code line that I was interested in. I tried to set
breakpoint in regular fashion, i.e. by double clicking on the left margin
in the Editor. The following has happened: program immediately got
suspended at random point in it's text segment (i.e. not on the line that
I attempted to set breakpoint on); the fat dot appear on the left margin
of
the code line that I double clicked on. That fat dot resembled regular
breakpoint sign, but it was actually different - it didn't have the short
stick (as regular breakpoint has). I went to "Breakpoint" tab in "Debug"
view, and found new breakpoint listed there. I checked it's properties;
they appear to be pretty much like those of regular breakpoints (i.e. it
was
enabled, had ignore count of zero, and no conditions attached). But when
I resumed execution, program didn't break on this breakpoint - it was
totally ignored. I tried enabling/diabling this "breakpoint", but it
made no difference - it was always ignored. My question is, what does
that fat blue dot means ?
Thanks in advance,
Andray
Re: setting breakpoint while program runs [message #72076 is a reply to message #72039] Wed, 28 May 2003 14:30 Go to previous messageGo to next message
Originally posted by: mikhailk.qnx.com
Fat blue dot is a regular image for a breakpoint. If breakpoint is set at
some debug session CDT adds the check sign (you called it "short stick") to
this image.
Which version of CDT are you using? The problem you are describing is a bug
and it is supposed to be fixed in 1.1.
"Andray Kaganovsky" <andrayk@futurewayNOSPAM.com> wrote in message
news:bb2ubf$gpt$1@rogue.oti.com...
> Hello,
> of
> was
> Thanks in advance,
> Andray
Re: setting breakpoint while program runs [message #72197 is a reply to message #72076] Wed, 28 May 2003 16:55 Go to previous messageGo to next message
Thanks for the quick answer, Mikhail. I use CDT 1.0.1. I actually came
across
this problem when I was using latest QNX Momentcis 6.2.1 PE, and decided
to check it on my RH 9.0 box, where I encountered this bug as well. I hope
it is indeed fixed in CDT 1.1.
Should I post problem report about this bug at QDN as well ?
regards, Andray
> this image.
> > Hello,
> > of
> > was
> > Thanks in advance,
> > Andray
Re: setting breakpoint while program runs [message #72214 is a reply to message #72197] Wed, 28 May 2003 17:56 Go to previous messageGo to next message
I don't think it is necessary. The CDT part of QNX Momentcis 6.3 is based on
1.1.
Thanks for trying CDT.
Mikhail
news:bb37ns$pqg$1@rogue.oti.com...
> across
> regards, Andray
at
to
> > this image.
bug
> > > Hello,
set
margin
that
margin
> > > of
short
"Debug"
properties;
it
> > > was
when
> > > Thanks in advance,
> > > Andray
Re: setting breakpoint while program runs [message #72251 is a reply to message #72076] Wed, 28 May 2003 19:13 Go to previous message
This bug is indeed fixed in CDT 1.1.
Andray
> some debug session CDT adds the check sign (you called it \"short stick\") to
> this image.
> \"Andray Kaganovsky\" <andrayk@futurewayNOSPAM.com> wrote in message
> > Hello,
> > my program was running under debugger\'s control when I attempted to set
> > suspended at random point in it\'s text segment (i.e. not on the line that
> > of
> > breakpoint sign, but it was actually different - it didn\'t have the short
> > stick (as regular breakpoint has). I went to \"Breakpoint\" tab in
\"Debug\"
> > view, and found new breakpoint listed there. I checked it\'s properties;
> > was
> > I resumed execution, program didn\'t break on this breakpoint - it was
> > totally ignored. I tried enabling/diabling this \"breakpoint\", but it
> > Thanks in advance,
> > Andray
Previous Topic:can't add global variable to "Expressions" view
Next Topic:how do I install new version of CDT
Current Time: Sun Nov 09 03:33:07 EST 2025
Powered by FUDForum. Page generated in 0.07857 seconds
