Help menu in RCP application not displaying [message #721516] |
Thu, 01 September 2011 21:05  |
I am trying to add a Help menu to my Eclipse 3.6.2 RCP application. I have the following code in my ApplicationActionBarAdvisor:
protected void makeActions(final IWorkbenchWindow window) {
showHelpAction = ActionFactory.HELP_CONTENTS.create(window);
register(showHelpAction);
searchHelpAction = ActionFactory.HELP_SEARCH.create(window);
register(searchHelpAction);
dynamicHelpAction = ActionFactory.DYNAMIC_HELP.create(window);
register(dynamicHelpAction);
protected void fillMenuBar(final IMenuManager menuBar) {
final MenuManager helpMenu = new MenuManager("&Help", IWorkbenchActionConstants.M_HELP);
helpMenu.add(showHelpAction);
helpMenu.add(searchHelpAction);
helpMenu.add(dynamicHelpAction);
helpMenu.add(new Separator());
However, no Help menu is displayed when I run the application.
How can I get the Help menu to work?
-sbs
Re: Help menu in RCP application not displaying [message #722300 is a reply to message #722276] |
Mon, 05 September 2011 05:06   |
Originally posted by:
On 2011-09-05 10:30, SBS wrote:
> Thanks, I have read those tutorials but I *still* can't get it to work.
> Absolutely nothing happens when I choose an option from the Help menu.
> No errors, no messages, just nothing. This is driving me nuts, it
> shouldn't be this hard!
> I have:
> 1. Created a plug-in to contain the help content.
> 2. Added in the plug-in dependencies required to display help to my
> product.
> 3. Added the help plug-in as a dependency in my product.
> 4. Created and successfully displayed the help menu.
> 5. Created a helpData.xml file to specify the help content sequencing.
> 6. Added the following to my plugin customisation file:
> org.eclipse.help/HELP_DATA=helpData.xml
> org.eclipse.help.base/help_home=/Help/html/toc.html
> where "Help" is the name of the help content plug-in.
> But still, nothing happens.
> What am I missing??? I have no idea how to even debug this.
You did not describe what UI action you performed and what feedback you
expected. Does you action Help/Help Contents work, i.e. does the help
window open? If not, you probably missed to add all dependencies
necessary for presenting the help. See
http://wiki.eclipse.org/RCP_FAQ#Which_plug-ins_are_needed_for_the_Eclipse_Help_system.3F
for some tips. I think, you need com.ibm.icu as well.
If your dependencies are OK, the help contents should be presented. If
this is the case, you may not have assigned the help ids to the
corresponding controls. How to do this, should be explained in the
references I quoted.
HTH & Greetings from Bremen,
Daniel Krügler
Re: Help menu in RCP application not displaying [message #722541 is a reply to message #722456] |
Tue, 06 September 2011 01:48  |
On 2011-09-05 22:29, SBS wrote:
> When I try Help->Help Contents I get nothing.
OK, this is a clear evidence that your dependencies aren't yet satisfied.
> Now, about dependencies, do I need to add the help-related dependencies
> just to my *product* or also to the MANIFEST.MF file for the project
> plug-in that *uses* the help (i.e. not the plug-in that defines the
> help)?
Since you are not using any programmatic help API (I assume), you don't
need to add plugin dependencies, but it is of course important that the
missing dependencies are part of your product.
> I have just tried adding these dependencies to the main plug-in
> MANIFEST.MF in addition to the product and this is the result when I run
> the application:
> !ENTRY org.eclipse.osgi 2 0 2011-09-06 06:12:40.203
> !MESSAGE One or more bundles are not resolved because the following root
> constraints are not resolved:
> !SUBENTRY 1 org.eclipse.osgi 2 0 2011-09-06 06:12:40.203
> !MESSAGE Bundle initial@reference:file:../../../../Workspace/MyProject/
> was not resolved.
What is this? This looks definitively wrong, because this does not look
like a "normal" bundle dependency.
> When I do this it appears that even the help plug-ins cannot be found
> although I get no such problems when I only add them into the product's
> dependencies. Does this mean that I need to add even more dependencies
> to my plug-in's MANIFEST.MF or that I shouldn't be adding *any*
> help-related plug-ins to it?
I don't know, but above error message about some
looks wrong. If you want to find out your dependencies, I recommend to
start your launcher within the Eclipse IDE (Run>Run Configurations...)
and all your dependencies there. There also exists a button "Select
Required" on the tab "Plug-ins", but this can only recognize *explicit*
dependencies, so you probably need to add the aforementioned plugins
manually to this list.
Daniel Krügler
FUDForum. Page generated in 0.03850 seconds
