Home » Archived » B3 » [b3 0.2.0] "Registry Directory not available..."
[b3 0.2.0] "Registry Directory not available..." [message #721245] Thu, 01 September 2011 04:42 Go to next message
Originally posted by: Ralf Zozmann
just after updating from 0.1 to 0.2 i cannot longer build any
aggregation site from a given *.b3aggr file. I replaced the old
'aggreate' command by 'validationSet' and leave all other options
untouched. My headless command to start b3 is:
<eclipse.launch app="b3" failonerror="true">
<args>
<arg value="-data" />
<arg value="${basedir}/.tmpWS" />
<arg value="-application" />
<arg value="org.eclipse.b3.cli.headless" />
<arg value="validationSet" />
<arg value="--buildModel" />
<arg value="@{b3file}" />
<arg value="--action" />
<arg value="CLEAN_BUILD" />
<arg value="--buildRoot" />
<arg value="${basedir}/_b3mirror" />
</args>
</eclipse.launch>
I got the message:
Build failed! Exception was java.lang.IllegalStateException: Registry
Directory not available: <my
path>/_b3mirror/p2/org.eclipse.equinox.p2.engine/profileRegistry.
The directory .../_b3mirror is not existing, but created while executing
of command. The stacktrace is:
java.lang.IllegalStateException: Registry Directory not available: <my
at
org.eclipse.equinox.internal.p2.engine.SimpleProfileRegistry.restore(SimpleProfileRegistry.java:419)
at
org.eclipse.equinox.internal.p2.engine.SimpleProfileRegistry.getProfileMap(SimpleProfileRegistry.java:277)
at
org.eclipse.equinox.internal.p2.engine.SimpleProfileRegistry.getProfiles(SimpleProfileRegistry.java:259)
at org.eclipse.b3.aggregator.engine.Builder.run(Builder.java:1613)
at org.eclipse.b3.aggregator.engine.Builder.run(Builder.java:1688)
at org.eclipse.b3.cli.AbstractCommand.run(AbstractCommand.java:133)
at org.eclipse.b3.cli.Headless.run(Headless.java:161)
at org.eclipse.b3.cli.Headless.start(Headless.java:197)
at
org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
at
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
at org.eclipse.equinox.launcher.Main.main(Main.java:1386)
Any hints?
Ralf
Re: [b3 0.2.0] &quot;Registry Directory not available...&quot; [message #721266 is a reply to message #721245] Thu, 01 September 2011 05:38 Go to previous messageGo to next message
Ok, looking into the buglist i found
https://bugs.eclipse.org/bugs/show_bug.cgi?id=354321. Changing my option
CLEAN_BUILD into BUILD does it. Now i have another problem...
On 09/01/2011 10:42 AM, Ralf Zozmann wrote:
> <args>
> </args>
> </eclipse.launch>
> I got the message:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at java.lang.reflect.Method.invoke(Method.java:597)
> Any hints?
> Regards
> Ralf
Re: [b3 0.2.0] &quot;Registry Directory not available...&quot; [message #721297 is a reply to message #721266] Thu, 01 September 2011 07:32 Go to previous messageGo to next message
You seem to be using an old version. The current version on our update sites:
http://download.eclipse.org/modeling/emft/b3/headless-3.7
http://download.eclipse.org/modeling/emft/b3/updates-3.7
has no 'validationSet' command and bug 354321 is fixed. Our update sites were updated on August 18.
- thomas
>> Hi,
>> <args>
>> </args>
>> </eclipse.launch>
>> I got the message:
>> Directory not available:<my
>> java.lang.IllegalStateException: Registry Directory not available:<my
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> at
>> at
>> Any hints?
>> Regards
>> Ralf
Re: [b3 0.2.0] &quot;Registry Directory not available...&quot; [message #721299 is a reply to message #721297] Thu, 01 September 2011 07:44 Go to previous message
> sites:
I have the requirement to setup a b3 headless aggregator with only local
artefacts, meaning i need a update site as zip archive. Using the
existing update sites i had have to built my own archive, what i didn't
like.
Looking to find a workaround for
https://bugs.eclipse.org/bugs/show_bug.cgi?id=354248 (see my other
posting for "Unable to load repository...") i have found an more actual
archive (org.eclipse.b3.site.eclipse.headless_0.2.0.v20110818-1257.zip)
solving my problems.
Ralf
Previous Topic:[b2 0.2.0] &quot;Unable to load repository...&quot;
Next Topic:CCE when running demo build
Current Time: Mon Jul 21 22:32:15 EDT 2025
Powered by FUDForum. Page generated in 0.14075 seconds
