Home » Archived » BIRT » event handle class problem(class WordPackage.LabeleventHandle not found)
event handle class problem [message #721274] Thu, 01 September 2011 06:03 Go to next message
Hi, I create a new java project in Birt with some class as here:
publib.boulder.ibm.com/infocenter/rsasehlp/v7r5m0/index.jsp?topic=/org.eclipse.birt.doc/birt/ScriptingWithJava.html
But when I preview my report in Web Viewer, in bottom of the document I see this error:
The following items have error:
Label (id=169):
+Class WordPackage.LabelEventHandler not found.
Why he can not see a path?
For earlier thanks to all.
[Updated on: Thu, 01 September 2011 06:12] by Moderator
Re: event handle class problem [message #721403 is a reply to message #721274] Thu, 01 September 2011 12:38 Go to previous messageGo to next message
Take a look at this blog:
http://birtworld.blogspot.com/2009/12/birt-designer-classpath-changes.html
Jason
> see this error:
> Label (id=169):
> Because of what he can not see a path?
Re: event handle class problem [message #721628 is a reply to message #721403] Fri, 02 September 2011 07:05 Go to previous messageGo to next message
Thanks Jason Weathersby. But I not find there any solution of problem Sad
Re: event handle class problem [message #721691 is a reply to message #721628] Fri, 02 September 2011 11:12 Go to previous messageGo to next message
Do you have one java project and one Birt report project in your
workspace. If you look at the classpath setting in the preferences for
Report Design, you should be able to add the java project to your classpath.
Jason
On 9/2/2011 7:05 AM, Spatial_Man wrote:
> Thanks Jason Weathersby. But I not find there any solution of problem :(
Re: event handle class problem [message #722264 is a reply to message #721691] Mon, 05 September 2011 04:01 Go to previous message
Thank You very much Jason Weathersby! Without your help I was hardly have done.
Even though I don't speak English very well, I will describe how I did it.
I click in my report and go to Window -> Preferences in menu. Then choose "Report Design" -> "Classpath" and the button "Add Class Folder...".
Then I preview my report and my method in the java class is worked!
Now I will to apply there own class, to transfer money in words.
Thanks to all.
Previous Topic:PieChart: All zero/null values
Next Topic:Dataset Row Limit
Current Time: Fri Jul 25 23:56:46 EDT 2025
Powered by FUDForum. Page generated in 0.28586 seconds
