Home » Modeling » Epsilon » Method 'getContainmentReferences' not found (190:38)
Method 'getContainmentReferences' not found (190:38) [message #510493] |
Wed, 27 January 2010 11:19  |
hi all
i installed eugenia yesterday (from update site) and tried to follow the screencast for "GMF editor development with eugenia". besides the fact that the emfatic code seen in the example is wrong (as well as the code at the eugenia main page, finally found the working code here: http://www.eclipse.org/gmt/epsilon/doc/articles/eugenia-gmf- tutorial/), the example worked for me.
in the next step i tried eugenia on the model i'm currently working with. i already have both an .ecore and a .genmodel, so i tried to "generate tool graph and map models" from the .ecore file. at this point i got the following exception:
at org.eclipse.epsilon.eol.execute.PointExecutor.executeOperati on(PointExecutor.java:190)
at org.eclipse.epsilon.eol.execute.PointExecutor.execute(PointE xecutor.java:67)
at org.eclipse.epsilon.eol.execute.PointExecutor.execute(PointE xecutor.java:37)
at org.eclipse.epsilon.eol.execute.PointExecutor.execute(PointE xecutor.java:123)
at org.eclipse.epsilon.eol.execute.ExecutorFactory.executeAST(E xecutorFactory.java:185)
at org.eclipse.epsilon.eol.execute.ForStatementExecutor.execute (ForStatementExecutor.java:44)
at org.eclipse.epsilon.eol.execute.StatementBlockExecutor.execu te(StatementBlockExecutor.java:33)
at org.eclipse.epsilon.eol.EolModule.execute(EolModule.java:57)
at org.eclipse.epsilon.eugenia.EolTransformationActionDelegate. runImpl(EolTransformationActionDelegate.java:124)
at org.eclipse.epsilon.eugenia.EolTransformationActionDelegate$ 1.run(EolTransformationActionDelegate.java:61)
i have no idea what exactly is going wrong here, maybe someone can help me with that?
im running galileo, epsilon version is 0.8.8.200910281243.
thanks in advance
marco
Re: Method 'getContainmentReferences' not found (190:38) [message #521621 is a reply to message #521603] |
Thu, 18 March 2010 06:10   |
Hi Marin,
Unfortunately, we've not used Eugenia with XSD-generated Ecore models
before so you're breaking new ground here :) In any case, even if
something is not natively supported by the built-in annotations, if you
figure out how to do it in plain GMF, you can then use the approach
discussed in
http://eclipse.org/gmt/epsilon/doc/articles/eugenia-polishin g/ to
reproduce it within Eugenia.
Dimitris
Marin Orlić wrote:
> Hi Dimitrios,
> you're right, I was missing some annotations, now it's working.. There
> are some things I'm not sure how to specify - my model is created from
> XSD so the structure isn't what you'd normally expect. For instance, the
> model uses a separate class for labels and stores the labels in a mixed
> attribute which is a EFeatureMapEntry, to have it stored as XML element
> CDATA content.
> Do you have any pointers how to handle such stuff?
> Marin
Spread the word: http://www.eclipse.org/gmt/epsilon/spreadtheword
Follow Epsilon on Twitter: http://twitter.com/epsilonews
Re: Method 'getContainmentReferences' not found (190:38) [message #521634 is a reply to message #521621] |
Thu, 18 March 2010 07:02   |
Dimitrios Kolovos wrote on Thu, 18 March 2010 06:10 | Unfortunately, we've not used Eugenia with XSD-generated Ecore models
Ah, lovely
Ok, thanks, I'll see what I can make of it!
Marin.
Quote: |
Marin Orlić wrote:
> Hi Dimitrios,
> CDATA content.
> Marin
Re: Method 'getContainmentReferences' not found (190:38) [message #587555 is a reply to message #587550] |
Hi Marin,
discussed in
Dimitris
Marin Orlić wrote:
> Hi Dimitrios,
> CDATA content.
> Marin
Re: Method 'getContainmentReferences' not found (190:38) [message #587565 is a reply to message #521621] |
Ah, lovely :)
> In any case, even if something is not natively supported by the built-in annotations, if you
> discussed in
Ok, thanks, I'll see what I can make of it! :)
Marin.
> Marin Orlić wrote:
> > Hi Dimitrios,
> > CDATA content.
> > Thanks,
> > Marin
Current Time: Thu Jul 24 23:34:07 EDT 2025
Powered by FUDForum. Page generated in 0.10821 seconds
