problem opening Application.e4xmi in e4 windows 64bit [message #571185] |
Fri, 19 March 2010 15:14  |
I've installed 2 versions of e4 on my Vista 64 bit:
eclipse-e4-SDK-incubation-I20100318-2100-win32-x86_64
eclipse-e4-SDK-incubation-1.0M4-win32-x86_64
I've tried sample e4 projects and creating new e4 projects on both installations, but whenever I try to open the Application.e4xmi file using the e4 Workbench Designer it just opens with a blank white interface (doesn't look like the screenshots of other OSes with the gui layout stuff).
Is this a known issue or is there a newer plugin I need on 64 bit for it to behave like the screenshots from the mac and 32 bit versions I've seen?
Todd
Re: problem opening Application.e4xmi in e4 windows 64bit [message #721011 is a reply to message #721000] |
Wed, 31 August 2011 12:56   |
Thank you for the very fast response. I use eclipse 4.1 with e4 0.11. I have added the .e4xmi in the attachements.
The full exception is:
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl$1DiagnosticWrappedException: org.eclipse.emf.ecore.xmi.IllegalValueException: Value 'org.eclipse.e4.ui.model.application.ui.basic.impl.PartSashContainerImpl@1ed5c93a (elementId: null, tags: null, contributorURI: null) (widget: null, renderer: null, toBeRendered: true, onTop: false, visible: true, containerData: null, accessibilityPhrase: null) (horizontal: true)' is not legal. (platform:/resource/de.kvg-gymnasium.mobi.manager/Application.e4xmi, -1, -1)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.handleDemandLoadException(ResourceSetImpl.java:315)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoadHelper(ResourceSetImpl.java:274)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResource(ResourceSetImpl.java:397)
at org.eclipse.e4.tools.emf.ui.common.XMIModelResource.<init>(XMIModelResource.java:67)
at org.eclipse.e4.tools.emf.editor3x.XMIResourceFunction.compute(XMIResourceFunction.java:21)
at org.eclipse.e4.core.internal.contexts.ValueComputation.get(ValueComputation.java:122)
at org.eclipse.e4.core.internal.contexts.EclipseContext.internalGet(EclipseContext.java:247)
at org.eclipse.e4.core.internal.contexts.EclipseContext.internalGet(EclipseContext.java:255)
at org.eclipse.e4.core.internal.contexts.EclipseContext.get(EclipseContext.java:208)
at org.eclipse.e4.core.internal.contexts.ContextObjectSupplier.fillArgs(ContextObjectSupplier.java:181)
at org.eclipse.e4.core.internal.contexts.ContextObjectSupplier.get(ContextObjectSupplier.java:165)
at org.eclipse.e4.core.internal.di.InjectorImpl.resolveArgs(InjectorImpl.java:411)
at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:303)
at org.eclipse.e4.core.internal.di.InjectorImpl.make(InjectorImpl.java:237)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.make(ContextInjectionFactory.java:153)
at org.eclipse.e4.tools.compat.internal.PartHelper.creatComponent(PartHelper.java:76)
at org.eclipse.e4.tools.compat.parts.DIEditorPart.createPartControl(DIEditorPart.java:92)
at org.eclipse.e4.tools.emf.editor3x.E4WorkbenchModelEditor.createPartControl(E4WorkbenchModelEditor.java:43)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.createPartControl(CompatibilityPart.java:122)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityEditor.createPartControl(CompatibilityEditor.java:45)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.create(CompatibilityPart.java:256)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:56)
at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:828)
at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:808)
at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:108)
at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:310)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.createFromBundle(ReflectionContributionFactory.java:90)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.doCreate(ReflectionContributionFactory.java:64)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.create(ReflectionContributionFactory.java:53)
at org.eclipse.e4.ui.workbench.renderers.swt.ContributedPartRenderer.createWidget(ContributedPartRenderer.java:141)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createWidget(PartRenderingEngine.java:858)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:612)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:714)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.access$2(PartRenderingEngine.java:685)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$7.run(PartRenderingEngine.java:679)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:664)
at org.eclipse.e4.ui.workbench.renderers.swt.StackRenderer.showTab(StackRenderer.java:686)
at org.eclipse.e4.ui.workbench.renderers.swt.LazyStackRenderer$1.handleEvent(LazyStackRenderer.java:66)
at org.eclipse.e4.ui.services.internal.events.UIEventHandler$1.run(UIEventHandler.java:41)
at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.java:180)
at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchronizer.java:150)
at org.eclipse.swt.widgets.Display.syncExec(Display.java:4610)
at org.eclipse.e4.ui.internal.workbench.swt.E4Application$1.syncExec(E4Application.java:182)
at org.eclipse.e4.ui.services.internal.events.UIEventHandler.handleEvent(UIEventHandler.java:38)
at org.eclipse.equinox.internal.event.EventHandlerWrapper.handleEvent(EventHandlerWrapper.java:197)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:197)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)
at org.eclipse.equinox.internal.event.EventAdminImpl.dispatchEvent(EventAdminImpl.java:135)
at org.eclipse.equinox.internal.event.EventAdminImpl.sendEvent(EventAdminImpl.java:78)
at org.eclipse.equinox.internal.event.EventComponent.sendEvent(EventComponent.java:39)
at org.eclipse.e4.ui.services.internal.events.EventBroker.send(EventBroker.java:81)
at org.eclipse.e4.ui.internal.workbench.UIEventPublisher.notifyChanged(UIEventPublisher.java:58)
at org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify(BasicNotifierImpl.java:380)
at org.eclipse.e4.ui.model.application.ui.impl.ElementContainerImpl.setSelectedElement(ElementContainerImpl.java:171)
at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.showElementInWindow(ModelServiceImpl.java:357)
at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.bringToTop(ModelServiceImpl.java:311)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.bringToTop(PartServiceImpl.java:273)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.showPart(PartServiceImpl.java:912)
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(WorkbenchPage.java:2729)
at org.eclipse.ui.internal.WorkbenchPage.access$19(WorkbenchPage.java:2654)
at org.eclipse.ui.internal.WorkbenchPage$7.run(WorkbenchPage.java:2636)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2632)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2612)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2603)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:651)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:610)
at org.eclipse.jdt.internal.ui.javaeditor.EditorUtility.openInEditor(EditorUtility.java:355)
at org.eclipse.jdt.internal.ui.javaeditor.EditorUtility.openInEditor(EditorUtility.java:164)
at org.eclipse.jdt.ui.actions.OpenAction.run(OpenAction.java:249)
at org.eclipse.jdt.ui.actions.OpenAction.run(OpenAction.java:228)
at org.eclipse.jdt.ui.actions.SelectionDispatchAction.dispatchRun(SelectionDispatchAction.java:275)
at org.eclipse.jdt.ui.actions.SelectionDispatchAction.run(SelectionDispatchAction.java:251)
at org.eclipse.jdt.internal.ui.packageview.PackageExplorerActionGroup.handleOpen(PackageExplorerActionGroup.java:376)
at org.eclipse.jdt.internal.ui.packageview.PackageExplorerPart$4.open(PackageExplorerPart.java:538)
at org.eclipse.ui.OpenAndLinkWithEditorHelper$InternalListener.open(OpenAndLinkWithEditorHelper.java:48)
at org.eclipse.jface.viewers.StructuredViewer$2.run(StructuredViewer.java:866)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:49)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:175)
at org.eclipse.jface.viewers.StructuredViewer.fireOpen(StructuredViewer.java:864)
at org.eclipse.jface.viewers.StructuredViewer.handleOpen(StructuredViewer.java:1152)
at org.eclipse.jface.viewers.StructuredViewer$6.handleOpen(StructuredViewer.java:1256)
at org.eclipse.jface.util.OpenStrategy.fireOpenEvent(OpenStrategy.java:275)
at org.eclipse.jface.util.OpenStrategy.access$2(OpenStrategy.java:269)
at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrategy.java:309)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4125)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1457)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1480)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1465)
at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:1270)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3971)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3610)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:969)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:885)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:87)
at org.eclipse.ui.internal.Workbench$3.run(Workbench.java:539)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:519)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:123)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
Caused by: org.eclipse.emf.ecore.xmi.IllegalValueException: Value 'org.eclipse.e4.ui.model.application.ui.basic.impl.PartSashContainerImpl@1ed5c93a (elementId: null, tags: null, contributorURI: null) (widget: null, renderer: null, toBeRendered: true, onTop: false, visible: true, containerData: null, accessibilityPhrase: null) (horizontal: true)' is not legal. (platform:/resource/de.kvg-gymnasium.mobi.manager/Application.e4xmi, -1, -1)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.setFeatureValue(XMLHandler.java:2663)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.handleForwardReferences(XMLHandler.java:1149)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.endDocument(XMLHandler.java:1228)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.endDocument(AbstractSAXParser.java:737)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanDocument(XMLDocumentFragmentScannerImpl.java:516)
at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.java:808)
at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.java:737)
at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(XMLParser.java:119)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.parse(AbstractSAXParser.java:1205)
at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSAXParser.parse(SAXParserImpl.java:522)
at javax.xml.parsers.SAXParser.parse(SAXParser.java:395)
at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl.java:181)
at org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doLoad(XMLResourceImpl.java:242)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1511)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1290)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoad(ResourceSetImpl.java:255)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoadHelper(ResourceSetImpl.java:270)
... 126 more
Caused by: java.lang.IllegalArgumentException: The selected element org.eclipse.e4.ui.model.application.ui.basic.impl.PartSashContainerImpl@1ed5c93a (elementId: null, tags: null, contributorURI: null) (widget: null, renderer: null, toBeRendered: true, onTop: false, visible: true, containerData: null, accessibilityPhrase: null) (horizontal: true) is not a child of this container
at org.eclipse.e4.ui.model.application.ui.impl.ElementContainerImpl.setSelectedElement(ElementContainerImpl.java:158)
at org.eclipse.e4.ui.model.application.ui.impl.ElementContainerImpl.eSet(ElementContainerImpl.java:234)
at org.eclipse.e4.ui.model.application.ui.basic.impl.WindowImpl.eSet(WindowImpl.java:749)
at org.eclipse.e4.ui.model.application.ui.basic.impl.TrimmedWindowImpl.eSet(TrimmedWindowImpl.java:121)
at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eSet(BasicEObjectImpl.java:1081)
at org.eclipse.emf.ecore.xmi.impl.XMLHelperImpl.setValue(XMLHelperImpl.java:1210)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.setFeatureValue(XMLHandler.java:2658)
... 142 more
I hope you can help me thank you.
Chrisitan
[Updated on: Wed, 31 August 2011 16:12] by Moderator
Re: problem opening Application.e4xmi in e4 windows 64bit [message #728384 is a reply to message #728373] |
Fri, 23 September 2011 03:16  |
Like stated in the error message the product can't be found. I guess the
reason is that the plugin.xml is missing in the build.properties.
There's been a bug in the project-wizard which didn't included necessary
files in the build.properties [1]
Tom
[1]https://bugs.eclipse.org/bugs/show_bug.cgi?id=351421
Am 23.09.11 08:56, schrieb Parvez Ahmad Hakim:
> I get bellow error while running exported product file.
> Can you help me. I tried bot features as well as plugin based approach,
> but no luck
> Parvez Ahmad Hakim
> Srinagar Kashmir http://www.abobjects.com
> !SESSION 2011-09-23 11:07:40.531
> eclipse.buildId=unknown
> java.version=1.6.0_11
> java.vendor=Sun Microsystems Inc.
> BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
> Command-line arguments: -os win32 -ws win32 -arch x86
> !ENTRY org.eclipse.equinox.app 0 0 2011-09-23 11:07:50.609
> !MESSAGE Product org.cord.client.dms.mainapp.e4.product could not be found.
> !ENTRY org.eclipse.osgi 4 0 2011-09-23 11:07:50.625
> !MESSAGE Application error
> !STACK 1
> at
> org.eclipse.e4.ui.internal.workbench.swt.E4Application.start(E4Application.java:126)
> at
> org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
> at
> at
FUDForum. Page generated in 0.06365 seconds
