Home » Eclipse Projects » Remote Application Platform (RAP) » Bug 192146
Bug 192146 [message #70592] Thu, 17 January 2008 18:07 Go to next message
Any News on on below Bug?
https://bugs.eclipse.org/bugs/show_bug.cgi?id=192146
Can i hope that it will be fixed soon?
Imagine people are entering data by copying and pasting it in a
web-application, they press "save" just to discover in some distant future
that no data is there!
This is serious and it is not a Priority 3 Bug, at least not for a
database centric web-application.
I hope i will be heard.
Andrej
Re: Bug 192146 [message #70719 is a reply to message #70592] Fri, 18 January 2008 08:58 Go to previous messageGo to next message
Originally posted by: benjamin.wolff.web.de
hm, maybe you should place a small if clause in your app, for example:
if (...#getText().isEmpty) {
so you can at least tell the user that the data won't be saved as long as
the bug isn't fixed.
just a suggestion from me to avoid the problem you mentioned.
Re: Bug 192146 [message #70825 is a reply to message #70719] Fri, 18 January 2008 11:00 Go to previous messageGo to next message
Originally posted by: admin.kabe-farben.ch
Hi Ben
thanks for the hint. I didn't think that far...
Andrej
Re: Bug 192146 [message #72085 is a reply to message #70592] Tue, 29 January 2008 13:23 Go to previous messageGo to next message
Originally posted by: rsternberg.innoopract.com
Hi Andrej,
I totally agree. The bad thing about this bug is that I cannot reproduce it,
which makes it hard to tackle. I tried again today with IE and FF on Linux
and Windows but I just don't see it. So any additional descriptions how to
reproduce it (environment, versions, code snippet, exact steps ...) are
very welcome.
Best,
Ralf
Re: Bug 192146 [message #72120 is a reply to message #72085] Tue, 29 January 2008 16:15 Go to previous messageGo to next message
Hello Ralf
i will try to give you as much information as possible:
Our environment is IE 7 and Firefox 2.0.0.11 on windows.The problem
happens on both browsers.
we tried every release since RAP 1.0 M4 and the problem remains with every
release.
steps to reproduce (from memory)
Create an SWT-APP with the following features
create a Text-Widget, i.e Text t = new Text(...
create a Button-Widget that executes a getText() on t, i.e t.getText()
run SWT-APP in Debugger and set breakpoint on t.getText()
now do the following:
1. open Windows-Editor (notepad.exe) and type any text.
2. mark that text and press Ctrl-C
3. switch to the SWT-Application and click into the Text-Field. (do not
type anything on the keyboard!)
4. Press Ctrl-V (do not type anything on the keyboard!)
5. Press the Button
Eclipse (or whatever you use) should now stop at t.getText().
t.getText() delivers null instead the text pasted with Ctrl-V.
Please tell me if you still can not reproduce the problem. I will then
make a snippet.
Andrej
Re: Bug 192146 [message #73266 is a reply to message #72085] Fri, 08 February 2008 15:00 Go to previous messageGo to next message
Hi Ralf
were you able to reproduce Bug 192146 with the descripton i gave you?
If not:
a) do you need a snippet?
b) do you see any chance that it is a qooxdoo problem which will go away
with release 0.73?
Andrej
Re: Bug 192146 [message #73320 is a reply to message #73266] Fri, 08 February 2008 19:09 Go to previous messageGo to next message
Originally posted by: jkrause.innoopract.com
Hi Andrej,
We are now able to reproduce the problem and are working on a solution.
Jochen
Andrej Dimic wrote:
> Hi Ralf
> If not:
> with release 0.73?
> Thanks
> Andrej
Re: Bug 192146 [message #81882 is a reply to message #73320] Mon, 07 April 2008 16:06 Go to previous messageGo to next message
Hi Ralf
just downloaded RAP 1.1 M3 and Bug 192146 is still there...
Andrej
Re: Bug 192146 [message #81925 is a reply to message #81882] Tue, 08 April 2008 05:51 Go to previous message
Originally posted by: fappel.innoopract.com
sorry for that but we are currently working behind schedule. We had to
postpone a lot of the bugfix-work due to limited resources. Hopefully we
will be able to fix the problem in M4, but honestly the schedule for M4
is already very thight, so I will not promise too much.
Ciao
Frank
-----Ursprüngliche Nachricht-----
Von: Andrej Dimic [mailto:adiinfo@bluewin.ch]
Bereitgestellt: Montag, 7. April 2008 22:06
Bereitgestellt in: eclipse.technology.rap
Unterhaltung: Bug 192146
Betreff: Re: Bug 192146
Hi Ralf
Andrej
Previous Topic:freeing memory resources after closing the browser
Next Topic:ActivateEvent verses ShellEvent?
Current Time: Sat Jul 19 02:47:13 EDT 2025
Powered by FUDForum. Page generated in 0.03097 seconds
