Headless build does not produce launcher [message #720814] |
Wed, 31 August 2011 05:38  |
i'm trying to follow the tutorial http://www.ralfebert.de/blog/eclipsercp/rcp_builds/ to create automated builds using buckminster and hudson. However, i'm already stuck at the manual installation of the product from a generated p2 repository using director.
When i run director it seems everything is properly created, except that the binary launcher (eclipse.exe on win32) is missing.
Director finishes without any errors and generates the following artifacts:
* configuration (folder)
* p2 (folder)
* plugins (folder)
* artifacts.xml
* eclipse.ini
In my product definition i have set a launcher name, launcher icons and selected "the product includes native launcher artifacts".
Has anyone a hint what can cause director to not create the launcher?
Re: Headless build does not produce launcher [message #722435 is a reply to message #722403] |
Mon, 05 September 2011 14:47  |
I'm fairly certain that the problem is this:
!MESSAGE Missing requirement for filter properties ~= $0:
com.diligentit.cctvnet.server.config.product.executable.win32.win32.x86 5.6.0 requires
'org.eclipse.equinox.launcher.win32.win32.x86 0.0.0' but it could not be found
which would indicate that either you don't have the launcher in your target platform or you didn't use '*' for the
target.os, target.ws, and target.arch when you resolved or performed site.p2.
- thomas
On 2011-09-05 18:47, Stephan wrote:
> Thank you, now I found the log and it contains:
> Command-line arguments: -application org.eclipse.equinox.p2.director -artifactRepository
> file:/C:/01_Build/buckybuild/CfgServer/com.diligentit.cctvnet.server.config.build_5.6.0-eclipse.feature/site.p2/
> -metadataRepository
> -destination
> C:\01_Build\buckybuild\CfgServer\com.diligentit.cctvnet.server.config.build_5.6.0-eclipse.feature\CfgServer.win32.win32.x86
> -bundlepool
> -profile CCTVnetCfgServerProfile -profileProperties org.eclipse.update.install.features=true -installIU
> com.diligentit.cctvnet.server.config.product -p2.os win32 -p2.ws win32 -p2.arch x86 -consoleLog -roaming
> !ENTRY org.eclipse.equinox.p2.director 4 1 2011-09-05 18:31:19.750
> !MESSAGE Cannot complete the install because one or more required items could not be found.
> !SUBENTRY 1 org.eclipse.equinox.p2.director 4 0 2011-09-05 18:31:19.750
> !MESSAGE Software being installed: CfgServer 5.6.0 (com.diligentit.cctvnet.server.config.product 5.6.0)
> !SUBENTRY 1 org.eclipse.equinox.p2.director 4 1 2011-09-05 18:31:19.859
> !MESSAGE Cannot satisfy dependency:
> !SUBENTRY 2 org.eclipse.equinox.p2.director 4 0 2011-09-05 18:31:19.859
> !MESSAGE From: CfgServer 5.6.0 (com.diligentit.cctvnet.server.config.product 5.6.0)
> !MESSAGE To: toolingcom.diligentit.cctvnet.server.config.product.application [5.6.0]
> !SUBENTRY 2 org.eclipse.equinox.p2.director 4 0 2011-09-05 18:31:19.968
> !MESSAGE From: toolingcom.diligentit.cctvnet.server.config.product.application 5.6.0
> !MESSAGE To: toolingcom.diligentit.cctvnet.server.config.product.executable.win32.win32.x86 [5.6.0]
> !SUBENTRY 1 org.eclipse.equinox.p2.director 4 1 2011-09-05 18:31:19.968
> !MESSAGE From: toolingcom.diligentit.cctvnet.server.config.product.executable.win32.win32.x86 5.6.0
> !SUBENTRY 2 org.eclipse.equinox.p2.director 4 0 2011-09-05 18:31:20.078
> !MESSAGE To: com.diligentit.cctvnet.server.config.product.executable.win32.win32.x86 [5.6.0]
> The prefix "tooling" looks strange and I don't know where this is coming from but I don't know if this causes the
> problem...
> BTW, if I have several nested features, where should I put the buckminster.cspex with the dependency (at the moment I
> have added it to every feature)?
> Regards, Stephan
FUDForum. Page generated in 0.20538 seconds
