Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Create Control Dynamically
Create Control Dynamically [message #720484] Tue, 30 August 2011 13:09 Go to next message
I want to dynamically create 'n' number of control(say TextBox or Label) and want to have an action to all Controls.
Example
1. Dynamically Create 10 Textbox
2. On CARRIAGE return of it perform some operation (addKeyListener)
(Edited)
My Question
How to I add action to those created controls?
Is there any Control Array(same as VB)
[Updated on: Tue, 30 August 2011 22:59] by Moderator
Re: Create Control Dynamically [message #720728 is a reply to message #720484] Wed, 31 August 2011 02:52 Go to previous messageGo to next message
Originally posted by:
On 2011-08-30 19:09, Balaji wrote:
> Hi I want to dynamically create 'n' number of control(say TextBox or
1) There is no 'TextBox' in SWT, do you mean the
org.eclipse.swt.widgets.Text widget?
2) You don say what kind of "actions" you are referring to. Do you want
to register a SelectionListener or a generic Listener?
> Example
> 2. Specific 5 TextBox has to perform some action on CARRIAGE RETURN and
> other 5 perform some action on ESCAPE key
> My Question
I don't understand the question. If you are writing a loop to generate
the control, why is there there a problem to add the listeners within
the loop?
I don't know, what a Control Array is, but you can simply create a
java.util.List<org.eclipse.swt.widgets.Control> if you really need to.
HTH & Greetings from Bremen,
- Daniel Krügler
Re: Create Control Dynamically [message #721889 is a reply to message #720728] Sat, 03 September 2011 07:56 Go to previous messageGo to next message
Thanks.
Here is the sample code, where I want to create a 'n' Label and want to perform a move operation on selected Label.
Example
  Label label;
  Listener listener = new Listener () {
    public void handleEvent (Event event) {
       // MY HANDLER HERE
  for(...)
     label = new Label(composite, SWT.NONE);
     label.addListener (SWT.MouseDown, listener);
Please correct me if anything is wrong.
My Doubt
In the above case, in the handler how do I know on which Label its operating?
Re: Create Control Dynamically [message #722333 is a reply to message #721889] Mon, 05 September 2011 08:06 Go to previous messageGo to next message
On 2011-09-03 13:56, Balaji wrote:
> Hi
> Thanks.
> Example
> Label label;
> // MY HANDLER HERE
> for(...) { label = new Label(composite, SWT.NONE);
> My Doubt
> operating?
The event handler function provides an Event object. Look at the member
"widget" to get access to the widget that had caused the event to fire.
- Daniel Krügler
Re: Create Control Dynamically [message #723168 is a reply to message #722333] Wed, 07 September 2011 18:01 Go to previous message
You're probably better off using a Typed Listener as apposed to an Untyped Listener.
You could use a general MouseListener like so:
MouseListener listener = new MouseListener() {
	public void mouseUp(MouseEvent e) {}
	public void mouseDown(MouseEvent e) {}
	public void mouseDoubleClick(MouseEvent e) {
		Object o = e.getSource();
		if (o instanceof Label) {
			Label label = (Label) o;
			if (label.getText().equals("...")) {
label.addMouseListener(listener);
Or you can use the MouseAdapter:
MouseAdapter adapter = new MouseAdapter() {
			Label source = (Label) o;
			if (source.getText().equals("...")) {
label.addMouseListener(adapter);
All I'm doing here is using the name of the label to identify which label was clicked on.
Hope this helps.
(no subject) [message #723170 is a reply to message #722333] Wed, 07 September 2011 18:01 Go to previous message
Hope this helps.
Previous Topic:Flat button inside toolbar
Next Topic:Background image on Composite
Current Time: Thu Nov 06 12:23:26 EST 2025
Powered by FUDForum. Page generated in 0.04575 seconds
