Home » Newcomers » Newcomers » newbie The public type Hello must be defined in its own
newbie The public type Hello must be defined in its own [message #720480] Tue, 30 August 2011 13:05 Go to next message
The public type Hello must be defined in its own file.
This is the error message I'm getting when I try to do
Chapter09 Part3 from itextpdf.com/examples
I got the "HelloWorld " to work correctly.
Suggestions?
TIA
Steve
Re: newbie The public type Hello must be defined in its own [message #720506 is a reply to message #720480] Tue, 30 August 2011 13:53 Go to previous messageGo to next message
Steve,
There can be at most one public class in a given .java file and its name
must match that of the file.
> Suggestions?
> TIA Steve
Re: newbie The public type Hello must be defined in its own [message #720516 is a reply to message #720506] Tue, 30 August 2011 14:39 Go to previous messageGo to next message
I think I have it SOLVED.
I had a file called hello.java
and
public class Hello extends HttpServlet {
when I got the error. When I changed it to:
public class hello extends HttpServlet {
my error went away.
Thanks a lot.
Re: newbie The public type Hello must be defined in its own [message #720549 is a reply to message #720516] Tue, 30 August 2011 15:04 Go to previous message
Of course using a lower case name for a class name goes against the
recommended Java style guidelines so better to change the file to
Hello.java.
> and
> my error went away.
> Thanks a lot.
Previous Topic:[CLI] Installation with p2.director
Next Topic:error message on start
Current Time: Mon Sep 22 09:31:31 EDT 2025
Powered by FUDForum. Page generated in 0.06358 seconds
