Home » Eclipse Projects » EclipseLink » Logging sql with logback(Logging sql with logback)
Logging sql with logback [message #718154] Tue, 23 August 2011 08:37 Go to next message
Weblogic 10.3.0.0
Eclipselink 2.1.0
logback 0.9.21
slf4j 1.6.0
I would like to log the jpa sql using the logback configuration.
And be able to change the eclipselink log level on the fly.
Anyone knows how to do that ???
Re: Logging sql with logback [message #720498 is a reply to message #718154] Tue, 30 August 2011 13:58 Go to previous messageGo to next message
You can implement your own logger to integrate with a third party logging service.
See,
http://wiki.eclipse.org/EclipseLink/Examples/JPA/CustomLogger
http://wiki.eclipse.org/EclipseLink/Examples/Foundation/Logging
(no subject) [message #720499 is a reply to message #718154] Tue, 30 August 2011 13:58 Go to previous messageGo to next message
See,
James : http://wiki.eclipse.org/EclipseLink : http://en.wikibooks.org/wiki/Java_Persistence : http://java-persistence-performance.blogspot.com/
Re: Logging sql with logback [message #890115 is a reply to message #718154] Thu, 21 June 2012 03:49 Go to previous message
A nice developer (Miguel Angel Sosvilla Luis) has written a class to do this. I can't post links as I'm new but search for
gist: 1325764
And you'll find it on github.
And configure it something like this in your persistence.xml
<properties>
	<property name="javax.persistence.jdbc.driver" value="com.mysql.jdbc.Driver" />
	<property name="javax.persistence.jdbc.url"  value="jdbc:mysql://localhost:3306/dbname" />
	<property name="javax.persistence.jdbc.user" value="root" />
	<property name="javax.persistence.jdbc.password" value="" />
	<property name="eclipselink.target-database" value="MySQL"/>
	<property name="eclipselink.logging.level" value="FINE"/>
	<property name="eclipselink.logging.parameters" value="true"/>
	<property name="eclipselink.logging.timestamp" value="false"/>
	<property name="eclipselink.logging.logger" value="yourpackage.Slf4jSessionLogger"/>
</properties>
Previous Topic:fixed timestamp for start/end values for historical data
Next Topic:exclude-unlisted-classes=false in Equinox OSGI
Current Time: Sat Jul 19 01:13:18 EDT 2025
Powered by FUDForum. Page generated in 0.04624 seconds
