Home » Archived » Jubula » Put character "=" in a textarea
Put character "=" in a textarea [message #708015] Tue, 02 August 2011 06:38 Go to next message
I would like to write into a Textarea the next code (for exemple):
PROGRAM cha
a_string:=REPRESENTATION(a_number);
END_PROGRAM
To do that I use <ub_cti_inputText> in my Test_case. When I input the code into the Text parameter, Jubula creates a new parameter "REPRESENTATION" for the Test_case. Is it normal?
What can I do to be able to do what I want? I have tried to put a space between the "=" and "REPRESENTATION" but Jubula want not accept it.
How can I delete the new parameter, because I haven't the possibility to click on "edit parameter".
Michel
Re: Put character "=" in a textarea [message #708019 is a reply to message #708015] Tue, 02 August 2011 06:49 Go to previous messageGo to next message
Hi Michel,
have you tried to use backslashes to prevent Jubula from creating a parameter?
Hope this helps.
Oliver
Re: Put character "=" in a textarea [message #708060 is a reply to message #708019] Tue, 02 August 2011 08:07 Go to previous messageGo to next message
Thanks! Smile
And how can I delete parameter if I can't access to the "Edit parameter"?
Re: Put character "=" in a textarea [message #708122 is a reply to message #708015] Tue, 02 August 2011 09:39 Go to previous messageGo to next message
Hi Michel,
to edit the parameters you have to right click the parent test case and select "Edit Parameters".
Oliver
Re: Put character "=" in a textarea [message #708155 is a reply to message #708122] Tue, 02 August 2011 10:12 Go to previous messageGo to next message
Thanks for the answer.
When I do that I can't select "Edit Parameters" because he is disable.
Michel
Re: Put character "=" in a textarea [message #708189 is a reply to message #708015] Tue, 02 August 2011 10:50 Go to previous messageGo to next message
Hello Michel,
it´s strange that "Edit Parameters" is disabled even when selecting the parent test case. Ususally "Edit Parameters" is enabled even when there are no parameters in the parent test case. Could you provide more information e.g. a screenshot? Typically the context menu looks like the one in the screenshot when selecting the parent test case (check attachment).
Oliver
Re: Put character "=" in a textarea [message #708765 is a reply to message #708189] Wed, 03 August 2011 02:42 Go to previous messageGo to next message
Hi Oliver,
Thanks to reply.
In attachement, a screenshot where you can see that "edit parameters" is disable.
Michel
Re: Put character "=" in a textarea [message #708773 is a reply to message #708765] Wed, 03 August 2011 02:52 Go to previous messageGo to next message
I have the same problem to delete a test case in the browser, "Delete" in the context menu is disable, is it normal?
In attachement a screenshot for this thing.
Michel
Re: Put character "=" in a textarea [message #708893 is a reply to message #708773] Wed, 03 August 2011 05:08 Go to previous messageGo to next message
Hi Michel,
It sounds like you have set the project as "protected", which means that parameters can not be edited and Test Cases cannot be deleted.
Have a look here for project protection and changing the protection status:
http://help.eclipse.org/indigo/topic/org.eclipse.jubula.client.ua.help/html/manual/node51.html
Alex
Re: Put character "=" in a textarea [message #708904 is a reply to message #708893] Wed, 03 August 2011 05:16 Go to previous messageGo to next message
Thank you very much Smile
That was the problem!
Michel
Re: Put character "=" in a textarea [message #720235 is a reply to message #708904] Tue, 30 August 2011 03:54 Go to previous messageGo to next message
Hello!
I have a similar problem. I want to input the character "\" into a textfield. But the backslash has another meaning in Jubula. How it is possible to have the usual meaning?
Best regards
Juliane
Re: Put character "=" in a textarea [message #720251 is a reply to message #720235] Tue, 30 August 2011 04:38 Go to previous messageGo to next message
Either use
or
literally.
Achim
Re: Put character "=" in a textarea [message #720283 is a reply to message #720251] Tue, 30 August 2011 06:15 Go to previous messageGo to next message
Thank you for your answer.
I have tried this already. It does not work either.
Do you have any other ideas?
Juliane
Re: Put character "=" in a textarea [message #720295 is a reply to message #720283] Tue, 30 August 2011 06:34 Go to previous messageGo to next message
Just to check - did you try entering the backslash surrounded by single quotes?
If so, what kind of error are you getting, what system (Win, Lin, Mac) are you on, and what toolkit (RCP, Swing etc.) are you using?
Alex
Re: Put character "=" in a textarea [message #720302 is a reply to message #720295] Tue, 30 August 2011 06:41 Go to previous messageGo to next message
I don't get any errors. The only thing is that no "\" appears in the textfield by executing the test but a "ß". Also no "/" but a "7".
The system I use is Windows 7 and the toolkit is RCP.
Thank you for your reply.
Juliane
[Updated on: Tue, 30 August 2011 06:41] by Moderator
Re: Put character "=" in a textarea [message #720305 is a reply to message #720302] Tue, 30 August 2011 06:47 Go to previous messageGo to next message
The problem is that your keyboard layout is false. The keyboard layout has to be specified for RCP AUTs:
http://help.eclipse.org/indigo/topic/org.eclipse.jubula.client.ua.help/html/manual/node267.html
Alex
Re: Put character "=" in a textarea [message #720325 is a reply to message #720305] Tue, 30 August 2011 07:29 Go to previous message
Thank you for that efficient answer. Now it functions.
Cheers
Juliane
Previous Topic:Problem starting html-AUT
Next Topic:How can I check wether a Figure is selected or not?
Current Time: Fri Jul 25 18:13:15 EDT 2025
Powered by FUDForum. Page generated in 1.26138 seconds
