Home » Modeling » M2T (model-to-text transformation) » [Acceleo 3] select() work on Acceleo 2 but not on Acceleo 3
[Acceleo 3] select() work on Acceleo 2 but not on Acceleo 3 [message #719854] Mon, 29 August 2011 04:36 Go to next message
I try to migrate a projet from Acceleo 2.6 to Acceleo 3.1 and i have a problem with
requests.
in my acceleo 2 project i have this code ( ownedParameter[direction=="in"])
<%for (ownedOperation){%>
    <% common_signature%>(<%ownedParameter[direction=="in"].nSort().common_parameter.sep(", ")%>) throws GenericException{
then with this code, request filter only on parameter with direction = "in" that is good.
on acceleo 3 i write this :
[for (ownedOperation)]
[javadoc_method()/]
    [common_signature()/]([ownedParameter->select(direction = 'in')->sortedBy(toString()).common_parameter()->sep(', ')/]) throws GenericException{
then ownedParameter->select(direction = 'in') return always nothing.
Could you help me to find my mistakes
thanks
Re: [Acceleo 3] select() work on Acceleo 2 but not on Acceleo 3 [message #719907 is a reply to message #719854] Mon, 29 August 2011 08:27 Go to previous messageGo to next message
You should change your code for something like this:
ownedParameter->select(direction = DirectionKind::IN)
Since I'm pretty sure that the direction in your metamodel is an enumeration and enumerations are manipulated differently in Acceleo 3 (MyObject.myEnumValue = MyEumeration::myEnumerationLiteral).
For more information, you can have a look at the Acceleo user guide which contains videos and tons of screenshots, the best practices guide (where you can find lot of information to create a good generator and where we are often adding new recommendations). the FAQ or even an open source example of UML to Java generator that you can fork as you want.
Stephane Begaudeau, Obeo
Twitter: @sbegaudeau
Google+: stephane.begaudeau
Blog: http://stephanebegaudeau.tumblr.com
Acceleo Documentation: http://docs.obeonetwork.com/acceleo
Re: [Acceleo 3] select() work on Acceleo 2 but not on Acceleo 3 [message #719990 is a reply to message #719907] Mon, 29 August 2011 11:57 Go to previous message
Thansk for your answer.
The good enumeration for metamodel UML2 is ParameterDirectionKind
Previous Topic:[Acceleo 3.x] Problem exporting Acceleo project as plugin
Next Topic:[Acceleo]
Current Time: Thu Jul 17 08:02:31 EDT 2025
Powered by FUDForum. Page generated in 0.32807 seconds
