Can't commit in Git because of XPCOM error -2147467262 [message #719233] |
Fri, 26 August 2011 09:43  |
Hello all.
Tried everything! and still can't solving this problem.
now i use Arch Linux x86_64, kernel 3.0.0, eclipse with Pydev, Aptana and JGit (1.0.0.201106090707-r)
Quote:eclipse.buildId=M20110210-1200
java.version=1.6.0_22
BootLoader constants: OS=linux, ARCH=x86_64, WS=gtk, NL=ru_RU
Command-line arguments: -os linux -ws gtk -arch x86_64
# xulrunner -v => Mozilla XULRunner 6.0 - 20110823172340
wrote a lot variants of eclipse.ini,
tried to use many option combination, like this:
-Dorg.eclipse.swt.browser.UseWebKitGTK=true - fail
-Dorg.eclipse.swt.browser.XULRunnerPath=/usr/lib/xulrunner-6.0/xulrunner - fail
-Dorg.eclipse.swt.browser.XULRunnerPath=/usr/lib/xulrunner-6.0 - fail
-Dorg.eclipse.swt.browser.XULRunnerPath=/usr/lib/xulrunner-5.0 - fail
-Dorg.eclipse.swt.browser.XULRunnerPath=/usr/lib/firefox-6.0/
-Dorg.eclipse.swt.browser.XULRunnerPath=/dev/null - fail
..and much more
tried to use OpenJDK and OracleJDK, no results Every time:
org.eclipse.swt.SWTError: XPCOM error -2147467259
at org.eclipse.swt.browser.Mozilla.error(Mozilla.java:2414)
at org.eclipse.swt.browser.Mozilla.initXULRunner(Mozilla.java:2377)
at org.eclipse.swt.browser.Mozilla.create(Mozilla.java:641)
at org.eclipse.swt.browser.Browser.<init>(Browser.java:119)
at com.aptana.git.ui.internal.actions.CommitDialog.createDiffArea(CommitDialog.java:214)
at com.aptana.git.ui.internal.actions.CommitDialog.createDialogArea(CommitDialog.java:135)
at org.eclipse.jface.dialogs.Dialog.createContents(Dialog.java:760)
at org.eclipse.jface.window.Window.create(Window.java:431)
at org.eclipse.jface.dialogs.Dialog.create(Dialog.java:1089)
at org.eclipse.jface.dialogs.StatusDialog.create(StatusDialog.java:203)
at com.aptana.git.ui.internal.actions.CommitDialog.create(CommitDialog.java:179)
at org.eclipse.jface.window.Window.open(Window.java:790)
at com.aptana.git.ui.internal.actions.CommitHandler.doExecute(CommitHandler.java:27)
at com.aptana.git.ui.internal.actions.AbstractGitHandler.execute(AbstractGitHandler.java:94)
at org.eclipse.ui.internal.handlers.HandlerProxy.execute(HandlerProxy.java:293)
at org.eclipse.core.commands.Command.executeWithChecks(Command.java:476)
at org.eclipse.core.commands.ParameterizedCommand.executeWithChecks(ParameterizedCommand.java:508)
at org.eclipse.ui.internal.handlers.HandlerService.executeCommand(HandlerService.java:169)
at org.eclipse.ui.internal.handlers.SlaveHandlerService.executeCommand(SlaveHandlerService.java:241)
at org.eclipse.ui.menus.CommandContributionItem.handleWidgetSelection(CommandContributionItem.java:820)
at org.eclipse.ui.menus.CommandContributionItem.access$19(CommandContributionItem.java:806)
at org.eclipse.ui.menus.CommandContributionItem$5.handleEvent(CommandContributionItem.java:796)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1258)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3540)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3161)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2640)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2604)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2438)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:671)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:664)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:115)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:369)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:616)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:620)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:575)
at org.eclipse.equinox.launcher.Main.run(Main.java:1408)
at org.eclipse.equinox.launcher.Main.main(Main.java:1384)
I really need to solve this problem, but I see no exit.
I would be very grateful for any help
Mihail
Re: Can't commit in Git because of XPCOM error -2147467262 [message #720648 is a reply to message #719948] |
Tue, 30 August 2011 22:24  |
Eclipse 3.7 works!) here, it's different implemented and no problem now.
Quote:I'm guessing you're using EGit
yes it is
Quote:You should log a report with them to let them know that fallback functionality should be provided for the case of Browser instantiation failing.
it would be right, but they know this problem probably.
thanks all for help)
FUDForum. Page generated in 0.03905 seconds
