Home » Eclipse Projects » WindowBuilder » Help(WindowsBuilder initialization problem)
Help [message #719734] Sun, 28 August 2011 13:24 Go to next message
Hello all,
I couldn't start the WindowBuilder even for a single application window, it always returns a error message:
"WindowBuilder was not able to show the GUI. (...)".
There is a "Internal Error" section that says:
"java.lang.NoClassDefFoundError: Could not initialize class java.awt.Frame".
I'm using Ubuntu 10.04 and Eclipse Galileo (3.5), with JDK 1.6.0_20, but I also tried to use newer version of Eclipse (Indigo 3.7) and JDK (1.7.0) without sucess, I get the same error. I'm not Java expert, so I'm asking for some help, please.
Below is the stack trace extracted from .log file.
Thanks in advance.
Leo
!ENTRY org.eclipse.wb.core 4 4 2011-08-28 14:00:18.250
!MESSAGE Designer [1.1.0.r35x201107161440.201108281353]: Could not initialize class java.awt.Frame
!STACK 0
at sun.misc.Unsafe.ensureClassInitialized(Native Method)
at sun.reflect.UnsafeFieldAccessorFactory.newFieldAccessor(UnsafeFieldAccessorFactory.java:43)
at sun.reflect.ReflectionFactory.newFieldAccessor(ReflectionFactory.java:140)
at java.lang.reflect.Field.acquireFieldAccessor(Field.java:936)
at java.lang.reflect.Field.getFieldAccessor(Field.java:917)
at java.lang.reflect.Field.get(Field.java:376)
at org.eclipse.wb.internal.core.model.property.editor.StaticFieldPropertyEditor.initialize(StaticFieldPropertyEditor.java:218)
at org.eclipse.wb.internal.core.model.property.editor.StaticFieldPropertyEditor.configure(StaticFieldPropertyEditor.java:190)
at org.eclipse.wb.internal.core.model.description.internal.AbstractConfigurableDescription.configure(AbstractConfigurableDescription.java:65)
at org.eclipse.wb.internal.core.model.description.internal.PropertyEditorDescription.getConfiguredEditor(PropertyEditorDescription.java:47)
at org.eclipse.wb.internal.core.model.description.rules.PropertyEditorRule.end(PropertyEditorRule.java:58)
at org.apache.commons.digester.Digester.endElement(Digester.java:1332)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.endElement(AbstractSAXParser.java:604)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanEndElement(XMLDocumentFragmentScannerImpl.java:1759)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl$FragmentContentDriver.next(XMLDocumentFragmentScannerImpl.java:2915)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl.next(XMLDocumentScannerImpl.java:625)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanDocument(XMLDocumentFragmentScannerImpl.java:488)
at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.java:812)
at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.java:741)
at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(XMLParser.java:123)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.parse(AbstractSAXParser.java:1208)
at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSAXParser.parse(SAXParserImpl.java:525)
at org.apache.commons.digester.Digester.parse(Digester.java:1887)
at org.eclipse.wb.internal.core.model.description.helpers.ComponentDescriptionHelper.getDescription0(ComponentDescriptionHelper.java:388)
at org.eclipse.wb.internal.core.model.description.helpers.ComponentDescriptionHelper.getDescription0(ComponentDescriptionHelper.java:288)
at org.eclipse.wb.internal.core.model.description.helpers.ComponentDescriptionHelper.getDescription(ComponentDescriptionHelper.java:257)
at org.eclipse.wb.internal.core.model.JavaInfoUtils.createJavaInfo(JavaInfoUtils.java:386)
at org.eclipse.wb.internal.swing.parser.ParseFactory.getRootContext(ParseFactory.java:128)
at org.eclipse.wb.internal.core.parser.JavaInfoParser.prepareParseContext(JavaInfoParser.java:1185)
at org.eclipse.wb.internal.core.parser.JavaInfoParser.parse(JavaInfoParser.java:244)
at org.eclipse.wb.internal.core.parser.JavaInfoParser.access$9(JavaInfoParser.java:240)
at org.eclipse.wb.internal.core.parser.JavaInfoParser$1.runObject(JavaInfoParser.java:153)
at org.eclipse.wb.internal.core.parser.JavaInfoParser$1.runObject(JavaInfoParser.java:1)
at org.eclipse.wb.internal.core.utils.execution.ExecutionUtils.runDesignTime(ExecutionUtils.java:153)
at org.eclipse.wb.internal.core.parser.JavaInfoParser.parse(JavaInfoParser.java:151)
at org.eclipse.wb.internal.core.editor.DesignPage.internal_refreshGEF(DesignPage.java:513)
at org.eclipse.wb.internal.core.editor.DesignPage.access$9(DesignPage.java:501)
at org.eclipse.wb.internal.core.editor.DesignPage$8$1.run(DesignPage.java:434)
at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.java:179)
at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchronizer.java:150)
at org.eclipse.swt.widgets.Display.syncExec(Display.java:4113)
at org.eclipse.wb.internal.core.editor.DesignPage$8.run(DesignPage.java:431)
at org.eclipse.jface.operation.ModalContext.runInCurrentThread(ModalContext.java:464)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.java:372)
at org.eclipse.jface.dialogs.ProgressMonitorDialog.run(ProgressMonitorDialog.java:507)
at org.eclipse.wb.internal.core.editor.DesignPage.internal_refreshGEF_withProgress(DesignPage.java:450)
at org.eclipse.wb.internal.core.editor.DesignPage.internal_refreshGEF(DesignPage.java:400)
at org.eclipse.wb.internal.core.editor.UndoManager.refreshDesignerEditor(UndoManager.java:381)
at org.eclipse.wb.internal.core.editor.UndoManager.activate(UndoManager.java:90)
at org.eclipse.wb.internal.core.editor.DesignPage.handleActiveState_True(DesignPage.java:248)
at org.eclipse.wb.internal.core.editor.DesignPage.handleActiveState(DesignPage.java:226)
at org.eclipse.wb.internal.core.editor.multi.DefaultMultiMode.showPage(DefaultMultiMode.java:125)
at org.eclipse.wb.internal.core.editor.multi.DefaultMultiMode$1.widgetSelected(DefaultMultiMode.java:63)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:228)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1176)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1200)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1185)
at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:1025)
at org.eclipse.swt.custom.CTabFolder.setSelection(CTabFolder.java:3256)
at org.eclipse.swt.custom.CTabFolder.onMouse(CTabFolder.java:2045)
at org.eclipse.swt.custom.CTabFolder$1.handleEvent(CTabFolder.java:323)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3493)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3112)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2405)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2369)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2221)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:500)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:493)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:113)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:194)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:368)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:616)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:559)
!ENTRY org.eclipse.wb.core 4 4 2011-08-28 14:00:25.295
!STACK 0
at org.eclipse.wb.internal.core.editor.DesignPage.refreshGEF(DesignPage.java:377)
at org.eclipse.wb.internal.core.editor.actions.RefreshAction.run(RefreshAction.java:46)
at org.eclipse.wb.internal.core.editor.actions.DesignPageAction.run(DesignPageAction.java:34)
at org.eclipse.wb.internal.core.editor.errors.JavaExceptionComposite.doRefresh(JavaExceptionComposite.java:87)
at org.eclipse.wb.internal.core.editor.errors.ExceptionComposite$3.widgetSelected(ExceptionComposite.java:129)
Re: Help [message #719738 is a reply to message #719734] Sun, 28 August 2011 13:47 Go to previous messageGo to next message
Looks like your JDK does not include AWT/Swing support.
Try to install and use Sun JDK 1.6.0_25 instead of 1.7.0.
Re: Help [message #719759 is a reply to message #719738] Sun, 28 August 2011 16:15 Go to previous message
Hi Scheglov,
thanks for your answer.
It is weird because I can compile and run the initial code generated by WindowBuilder that shows a blank window. The code has a class that extends JFrame (which is part of Swing and that extends awt's Frame class). The problem appears when I try to switch from 'Source' (code) view to the 'Design' view in the Editor.
Anyway, I will try your suggestion.
Thanks for the attention.
Leo
Previous Topic:Cannot complete install Window Builder Pro
Next Topic:Look and Feel.
Current Time: Fri Jul 18 19:45:24 EDT 2025
Powered by FUDForum. Page generated in 0.23238 seconds
