Home » Eclipse Projects » WindowBuilder » Setting orientation
Setting orientation [message #718596] Wed, 24 August 2011 15:34 Go to next message
I noticed that on several controls (in SWT Designer) the "orientation" property is shown only as an integer, instead of showing the RIGHT_TO_LEFT/LEFT_TO_RIGHT constants.
The textbox control shows it properly, but the Button and Label (and others), do not.
Re: Setting orientation [message #718607 is a reply to message #718596] Wed, 24 August 2011 16:12 Go to previous messageGo to next message
OK, Eclipse 3.7 adds this property for Control, so we should declare it there too.
Fixed in trunk.
Re: Setting orientation [message #719560 is a reply to message #718607] Sat, 27 August 2011 16:46 Go to previous messageGo to next message
By the way, there seems to be a drawing issue with RTL shells using GridLayout.
I set shell.setOrientation(SWT.RIGHT_TO_LEFT); in the source, and then added some buttons, and i noticed that the grid itself is still being drawn on the left side of the screen. The controls on the other hand, were placed correctly.
Re: Setting orientation [message #719668 is a reply to message #719560] Sun, 28 August 2011 05:56 Go to previous messageGo to next message
And another interesting problem, try adding a Composite to that RTL shell, and add a button the that composite. Moving the button around seems to be moving it to the opposite direction.
Re: Setting orientation [message #720161 is a reply to message #719668] Mon, 29 August 2011 22:28 Go to previous messageGo to next message
Do you use absolute layout?
Try to use GridLayout instead.
Re: Setting orientation [message #720205 is a reply to message #718596] Tue, 30 August 2011 02:12 Go to previous messageGo to next message
GridLayout inside the main RTL shell and AbsoluteLayout inside the LTR composite will trigger the bug.
GridLayout in RTL shell and GridLayout in LTR composite will be ok.
But don't forgot the other bug I reported - when using a GridLayout on an RTL shell, the grid in WindowBuilder is being drawn as if it's LTR.
Re: Setting orientation [message #720945 is a reply to message #720205] Wed, 31 August 2011 10:18 Go to previous messageGo to next message
Can you please open bugs in Bugzilla, so that I did not forget them?
Yes, it seems that for GridLayout drop feedbacks are OK for RTL, but grid is displayed as for LTR.
Re: Setting orientation [message #721056 is a reply to message #720945] Wed, 31 August 2011 15:45 Go to previous messageGo to next message
Bugs created:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=356398 - Controls in an RTL composite with AbsoluteLayout move to opposite direction
https://bugs.eclipse.org/bugs/show_bug.cgi?id=356399 - Grid drawn on the left side for RTL composites
Thanks!
Btw, when are you expecting to release an update?
Re: Setting orientation [message #721079 is a reply to message #721056] Wed, 31 August 2011 16:35 Go to previous messageGo to next message
Caleb wrote on Wed, 31 August 2011 15:45
We have been releasing new integration builds rolling up all bug fixes pretty much every week.
Our next release build will come out when Eclipse 3.7.1 comes out.
Re: Setting orientation [message #721176 is a reply to message #721079] Thu, 01 September 2011 02:10 Go to previous messageGo to next message
Eric, so to get the weekly builds I just have to open up Eclipse's "Install New Software" and choose "Eclipse 3.7 WindowBuilder Repo - http://download.eclipse.org/windowbuilder/WB/integration/3.7" ?
I noticed that you still offer to download WB from Google. Is "http://www.eclipse.org/windowbuilder/" the new home for WB?
Re: Setting orientation [message #721326 is a reply to message #721176] Thu, 01 September 2011 09:31 Go to previous messageGo to next message
Caleb wrote on Thu, 01 September 2011 02:10
Yes.
That download also includes GWT Designer. The Eclipse download does not.
Yes. That has been the case for the last six months or so.
Re: Setting orientation [message #721340 is a reply to message #718607] Thu, 01 September 2011 10:08 Go to previous messageGo to next message
Konstantin Scheglov wrote on Wed, 24 August 2011 16:12
Fixed in trunk.
I've just updated to the latest build, and it seems that changing the orientation field once makes the combo box of the property remain stuck in the same position, no matter which other control you select.
Re: Setting orientation [message #721428 is a reply to message #721340] Thu, 01 September 2011 14:05 Go to previous message
Can not reproduce.
Do you have any exceptions in "Error Log" view?
Previous Topic:Exposing Shell's Styles by default
Next Topic:Component access from event methods (Anonymous class)
Current Time: Sat Jul 26 00:26:08 EDT 2025
Powered by FUDForum. Page generated in 0.05312 seconds
