Home » Eclipse Projects » Standard Widget Toolkit (SWT) » huge polyline performance(best practices to plot a huge number of lines)
huge polyline performance [message #719461] Sat, 27 August 2011 06:17 Go to next message
I need to plot a sound file with many-many lines (for example, 30,000 lines for a 3sec phrase). I try to do the same thing I did previously in swing(awt).
- wav -> int []
- g2.scale # to fit into the client area
- g2.translate... #
- draw(int [])
In Swing, painting is pretty fast. I tried similar approach with SWT. The code works, but it is much slower (30k data points need 3sec to draw on AMD 945, onboard chip). Here are the steps.
- wav -> int[]
- new Transform(Display.getCurrent());
- transform.translate(...
- transform. scale(...
- e.gc.drawPolyline(int [])
In both cases the code is in the paint listener (Swing:paintComponent; SWT:PaintListener).
Is there better ways to plot a large number of connected dots - say, as in a sound file?
Any help is appreciated.
Re: huge polyline performance [message #719462 is a reply to message #719461] Sat, 27 August 2011 06:24 Go to previous messageGo to next message
Are you using double buffering on the Canvas?
Tom
Am 27.08.11 12:17, schrieb andzsinszan:
> swing(awt).
> - wav -> int []
> - g2.translate... # - draw(int [])
> - wav -> int[]
> SWT:PaintListener).
> in a sound file?
Re: huge polyline performance [message #719463 is a reply to message #719462] Sat, 27 August 2011 06:46 Go to previous messageGo to next message
Thanks for the fast reply.
I don't use any explicit settings related to double buffering.
Neither with Swing nor with SWT.
I'm on GTK (swt-3.7-gtk-linux-x86) by the way.
Haven't tested on Windows.
Some time reading around the painting code.
Swing 9.125116 ms
SWT 2609 ms
Also, in SWT the line width is also scaled...
Okay, commenting out 'e.gc.setlinewidth'
SWT 800 ms
Considerably faster, but the wave line is pretty difficult to see.
Re: huge polyline performance [message #719475 is a reply to message #719463] Sat, 27 August 2011 07:25 Go to previous messageGo to next message
Could you try creating your Canvas instance using SWT.DOUBLE_BUFFERED?
Tom
Am 27.08.11 12:46, schrieb andzsinszan:
> I don't use any explicit settings related to double buffering. Neither
> I'm on GTK (swt-3.7-gtk-linux-x86) by the way. Haven't tested on Windows.
> Swing 9.125116 ms
> SWT 2609 ms
> SWT 800 ms
Re: huge polyline performance [message #719600 is a reply to message #719475] Sun, 28 August 2011 00:03 Go to previous messageGo to next message
Tom,
Thanks for the advice.
I set double buffered (see code below). Paint duration is almost the same.
Time readings (repaint times) after resize events:
SWT (with setting linewidth) 2700ms
SWT (w/o setting linewidth) 790-830ms
AWT 2-20ms
I attached screenshots with and without setting linewidth.
Below is the code for reference.
public class WavPanel extends Composite{
	public WavPanel(Composite parent){
		super(parent, SWT.NONE);
		this.setLayout(new FillLayout());
		Canvas canvas = new Canvas(this, SWT.NONE|SWT.DOUBLE_BUFFERED);
  		canvas.addPaintListener(paintListener);
      PaintListener paintListener = new PaintListener() {
		public void paintControl(PaintEvent e) {
			long t0 = System.nanoTime();
			e.gc.setAdvanced(true);
//   			e.gc.setLineWidth(20); // faster if commented out
			Transform transform = new Transform(Display.getCurrent());
			transform.translate(...);
			transform.scale(...);
			e.gc.setTransform(transform);
			e.gc.drawPolyline(waveCoordinates); // waveCoordinates.length= ~60,000
			transform.dispose();
			e.gc.setTransform(null);
 			long t1 = System.nanoTime();
(no subject) [message #719601 is a reply to message #719475] Sun, 28 August 2011 00:03 Go to previous messageGo to next message
Tom,
AWT 2-20ms
MB5!.1PT*&@H````-24A$4@``!,T```%;"`(```!)3^Y6`````7-21T(`KLX<
MZ0````9B2T=$`/\`_P#_H+VGDP````EP2%ES```+$P``"Q,!`)J<&`````=T
M24U%!]L('`,?ZUO71L?>JZ[6"P:P>+.2W_G\-;A![__@P$`
M````````````5,9?_X>_OCR__)P>"((C'
M,<8(``````````!@^TBF23$O*A^5_4RR"
M5A`$1#(GHPGF%0``````````X&I(9IPDT^0;KWRCXO'?_OYO7Q2+;K^_]NEG7*=;+!9%42R*1;$HBJ)X^]&C__O?_S^0#```````
M````@.4PG\]?_]KK'_CN#W3=]^CU/_]7C#LS]6/P<```````````#JHC_L+XJJW*I_T#?9W'K.4#G6M3OH
M6AGE-WFFR1,;C<;O_\'_E::IZXR-1B-JMW_\[_Y$FF6@F0```````````$N#
MG7QU\QD;C0;1,76&5_Y>>(0B"\>7XY.V3=J_]W/N>"X+@_.0\
MF23/_V?/?_O?^O977G_%/(/FF>IAYO-Y$`1Q'#]\^%#=4+/9;(;-9J,9-()G
MGWTV"((LS9#;"0``````````L`+1#);CF4'CG9\89_CL__!9ZR\^\X\_\ZZK
M&&<@TCB^''_\AS]^Y_:=W_C<;YSWSH,@.'G>A\='!T
MH,^@>>:3_Z]#_\]&]^]I=5J#0^'Z@R:9RJ>2/0R2],\SX,@:#:;K5:KT6@TFXWP
MF_\V#03```````````@*5Y9K`LSPS>B7JUG>$S__@SZGAR<KZ+
M9SK.$$;AO_J?_M5H//JU_^;7/O/ISS2;S5NW;YV>GG>X,^O_<UKEF/,,P2+(`CN/G,W"((O_LD7_]E_]\_^
MR:_]DX.#@_.S\\_^QF=O/WOSJ=#I%2]7,```````````"@!EM\)V9UEL_J_I#HF.L,
MUA/*+\TSS&=S_O=/__1//_K1CQ[=.OK4+W^*#BOF!?W)/(/FF8I]4GYFEF6+
M15`4BS3-XDF<SW(^;_]W=\]'H]&%R/P3```````````@.51OUKL-],IR^)FK92URAFR)`N"8#:;
M?>`#'_BC/_JCCWWL8U$[^L5?_,67/_WRO_@?_T6CV1@<#/09%,^TU@$B1LND
MEM!NM^_>?>IK7_O:)S[Y"__^C^,,?_L,__,,?^9$?Z;0[/_=?_=SSSS__
M^NNO#X8#=0;-,ZU]38;#`_WPC<;=NT\]=?>I][__N_S59_@S!(@B"WJ`7!,%L-@O#,(JB[__^
MW_N]'_^)'W_E:Z]\_"<__OCD,;/(JGU-TBQ;+!;_X)?^H>NV_K?__7^]
M?_^-RV1\,;F$3````````````*Q&--]A9L4B"(+GGG_.<^R,__=-Q&K_XX1>+>1&VPG>=0?%,Y9P=
MC<>?^_QGBZ(HBF*Q6-"_[_
M@>K6\ADTSU3L\ZNOOXJ9!@``````````V`[FL_E+W_?2E_[5/_\G_^
MEY_XQ">*HIB.IQ_Z_@_Q&33/7*"2#P``````````P!4A2^^3]^
MN>)/7OS>%^?S>9\,?_7#%X^>S>9^\I_^M__T.S[P'>U.
MNQ$TPC!LMII%\2U_)GUH?.I3GGW,*````````````,"8S6:__6O
M?O7L]V>_YGN_YY"<_^2N_\BN?__SG+R\O7W_^<M_
M^9=_Z5'MH,D!P*Y@.!Q>^V?L=#H>VCD:C?AS4100"0``]AU^XQH``,!>X&,?
M^]@O_,(O?/"#'_S8QS[VXHLO?O[SGS\X./CPAS_\9W_V9TF2N'__NCH*`B"
MEU]^^1.?^,07OO"%+W_YRQ__^,<]OP7/!`!@@5M?^,(7?O(G?_*C'_UHO]\'SP0`
MX`J0IJGGK]UN%T,$`,`UQG0Z14DS``#V%V$8#@8#64BVT^G\T`_]T$<^\I$@
M"/K]?A1%X)D``.P3)I,)E#,``/8=2#4'`&#?(4DF_;?3Z:B*&U:@#A``7!F/
MPB!XL%@L,`@``.PB/TS`1V"9Z<$P``````P#,!`+@R(&8,V%]423X!`!,(5P$```#/!`!@
MJ_`T\PV"(`Q##!&PFXCC&(,`5,1X/,8@````@&<"P*-K_XPJ75-E,7FB:F_"X`!7!>FKM'8[]/OA`0``
M````SP2`W<6UU&65_;Y6^5DH^L!V(',OK8UM8>8``````/!,``"N`U2VJM7+
M!`!K@95;`@``````G@D`P'6#:EV(:I_`YB#CMR7GE&'>JJ(5``````#@F0``
M7!G6%>_::K4PF,"6.6>SB5<D<,VW5@```/!,``#V$OZ&F=71HCIVF*
M>=_'_7-=]!4````\$P"NU]JJM]NN(SW6>D0S`IL##!S`3DG1Y>5E
MZ3%YGF/,`0``SP0`X)MPI80!A/%X[/H3NE``F\,-]&<":\>M62=XF8#MP&4`ND0=A+Z%P+H@A<VUE;G";M'<%0``
M\$P```"GSK1<_)3*F>KCS9RU0!0
M:RR'*]E&7,YS%VO=YLMEC3TY49H(`,`S`0!8#Y9.0;R6GH1U6;)=?LO5#?SH
M8P$`P'JQH<U\Z9?+&CDP````>"8`0#79":CJNSOH+4%9EVL/JSMEC>X:`%#9
MDDML="Z!1*=E``#`,P$`^":N4Y^]M6/M-O+5O9&(Z;KVD!H\6W.6K@N-@M)`
MZ4:T!,]T&;SJ;G&>+L3K0MT<9NRQ``">"0#`>H"2?=N$-/8CT`NP@LO>)$G"
M@=Q+1W3?A$)!0%TH*K7&O:AN0^8M%-VI&P,"VRL`@&<"`+`IW.0,P&T6KH`V
M`UC!SJ4\SU<G`-<9_V
M5R_'!K4+:+5:UDW)91"16Y_+.E#%E;J*_!2A8@UN25D&P``\$P`
M`/8;C4:CAQGOW:\HR@J3<>M%2);)1E;WLGEY>4N#`ZHQ8[`91JK$M?JXIFN
M0!I@*@5(BOU[X.#@[7PTBU@N5J79>3&YW+Y^F*NU''PVP*
M``!X)@``5X^=JKXKU6O^O/;^%L`NH#3_5CK/:W'+&UM0&A:9U7'KUJUM7JYN
MOH:4;4]T"=)`````SP2`'<*-K:ZA-!+EL?0,RQ+]XJ5S";Z7&XY:66JUZIK<
M*"4;F9P>'!\?U_V)AE/U^G_TP?D_4%=;_!+:#T6B$YC=+KRET!E98W9@E'>FR`-6F@RP\='<3
M0,P(`(!G`@"P56RSA\=>>Y+MK#G24U4B:I%FC0`@&<"
M`+!9H$]`=4ACOV0"I?^K26^4QM?:[(<&DTJ<LS=]^V@@KA``">"0"`>_G=O-8F'FULN4PP
MJ3Q)MXS5(<#N*2M37<7>#^P:UI@`U9F8J]#K&E\H.S5KV%$!``#/!(!-
M`:DLU;&Y_MV29S*+D)XH#J;E>$BTH;^NL+K*I39\)<6B=F2CR+),LI1KV5UI
M0]A.A5@E)VL)%MWR7K>T:S1`Q2```,\$`$"BNJ*F7O85TPBO$XZ/CVMQ@^J0
M@UE1RT&VSW6"-;JUV^VR=\CE=:E%'E9T5>T(Y&+Q1/S>P`T*#'DM,(6J>CHK
M.NL``'@F``#?0O40)J6D+M$O>_?A=]IXU!U/K*-D\JXS+&&POZK^=<`F8%5D
MHR@J57"5Y/BM#QMUMER)E]7S1`BI]6-ST1E7LE]53^M0>V9*)WC:F-3M^QP
M`'8$VP_XE%Y3J617":K?\K;@*5F4)(E4Y:'6*WB")N2^I\9-^B&7V)&D:*VE
M`_/J'5DV&MH*IR4`@&<"`+`&(!%ETY`.!Y27N-Y8BPJ^-"2UD'ZA*JV,MNQ%
M]%.=IYYZ:HV$Y)K!$[GJ2H)0U+2BE/*K09GMSL@%>PGR@?E):S7!<D).YU.Z<8UF\U*
MA=\E7&'N\@KJ0"<$4Z
MNO;BI;M7SYI?_(S9'/
M=24U`0R9KB8Y)V=(UBVQD^?Y<@)0)71PL64/:D41RU9I2G>189"N<YK=P$NUPU(%$=FV^PX7.ZJX
M)*4<5C<8N<2FU/.3)`DSO2OW^:C88@&*U*4UPO7'6A*B8B2N&W^CQ=/5V7V&;K
MFDT1)0L`X)D``&P*15%8_1A7Q9VN$&LIWE#%NH^0JAL(Z=]8;V*MY`#RLU3N
M5XE9V$1X^7+\W,,>51S!#4P'N))I\I`TR?Q9X.,XYH4@5X2R=<K3RE1AZS.J
M5Y6K.R@```!X)@!<`5Q^C)N&I6/M7(WO7<>L'3<YR79?(.=H7<)`EA%2Z$WI
ME6RVKO)M#294"OV&'$'R*K=NW9)_JEZ=""MB:W!9UHZ.CLPOY0P.!@.7:UV:
M_.0QUEI9"+T!```\$P"`:XLJSJ+J#J4E\H76;BF`3V#MD*Q/JLNE7G2/&BV9
MGIRRBXN+%>]6GIF]B$HJ-M2\03ZO8K8>E]W:LP3W'179U^J%A57JIE7@E[XZ
M63&Q@UO6G<N7.GE-&M:RZ62]Q5+(XC44NE
M:VNU7CVM7U!VQ2\V+E.4)Q19_40:+S919DD*+7/4+,NL6]_J5:\\0+-B``#/
M!```/'/O,1Z/*U("R49,9K+VJB>U*O$"5;#]"J@R#7@\'EL)K=3"%8OSUY79
MFBZ.8E=5%:9F<4#.Z\QI&G`51*VED0M@2IGEF2/C^]VNZY`:%=,!PO\9#+A
M<YI>(*Y8/5EQ,IFP3F\-7`P<(9=77CPL21))W95E9&NAO%<+3\+J=HHV5915
M:T*RRY:1)(DTFLC#-E%-S?3TKJ5R%9/SMV[=TTBNCGX_7(NXJ3NC>_Y
M>L/C>3L_/W?M/^N->:Y"J$J9VWP^YTIIZH1\MTHPEB-RZ_7#+U$#"2D)``">
M"0#7%A4='8A5JXXEE&^K;T%2B"MQ5")W=Z=@M374LBR,QV/V\C4:#1=_J^XC
MVLZVL!;KB6J(<A.$9#@<>EJ`2*:W7E_T6L+XI]-IZ7D4J:MXW8T&>`\&`^NR
M\HPP4A(``#P3`&X<%,>83J>HA;`<I'KGLG9;Q[9Z*Q'6)MDTOHJ-G$DO9GRG
ML(JM@0DA"X;'P"1UXE([E!3IW;>*=<5
M=<TB%=WU``"`9P+`]8'),5#;?76X5(H5>_VQ19SUQ2441_Z)U2T`W^;NH'KG
M50:GS$FRZFH*(AE(:5JC%%W>(M8;"NAQ^%3W!<%HHOB/K!>4
MT;S@F6O'TO[)NK5/Y%*53JTJ0FLJP54XR7K]8Y*UJONI+OE+D/.]0/5R/JN,
M@,GG*S)\M;.QV8)W6GG_L@;5BF1,FA44IU46A^TXNCU7V8XS&0``\$P`V!54
M>?-=RP)"_HYS'GU%Y62ZE#^I\9?Z?*IKD&LINLB*(P^"53>"7VA=*(VO&PP&
M:TEUDU+]^/'C6HS1E($JF\/F0@%5K9?JD;J;*$RZ"U#5?3S;LI*E@X.#ZBS.
MW*PJ%MTI-4=6W$]</$UNO)YGEW]:5Z'=6AF_:/H*`."9``!\2P'U,R&A"_"Q6!\B3)T\PW6N!=;*D(#6;S77IQ"0AD\ED.]X;
MUF:T*KU=IF:JYTI<K/'DXK_#(VI!5W+14(JT@Q6UG>S?<WK]:HX$JM'
M=JR]T$!=.00O!0#P3```2G33:PE/E9&--F%3:M827LHE*@.9^M:*W5:`ZKJ[
MG"_7RF)Y4#8@IITT-4='1VF:DGQ6#URQ4NA/G
M\^!Z8KP=)#7!7%5;TZ5Q_YBD=6>?6H8?'L6NOUN);69RZ]50``
MP#,!X(8"14<9ZXTK9@7.Q0^98W0ZG=53M4`ZE*2:9#ZGIZ?+G62OO4:R9D^>Y]*AK9S;#QX\
MD$?*'U9<Z6H+DI/NB72P1
M^A:KZ.F%'Q(`P#,!`%@25C)S0WJ=KQ=5XK)8@7.5TV".$461V5&@;J2KWX+.
M?2BV6BU)1ZO$=+CL
M(,IS6\HS35&Q^GAA=04`\$P``):$4DKH17O]?%F*2FTB&K:NYW@M75A,K*7!8-T&C%<+18U4
M-*:<6441;]^^+?\KNYXHWZ9LRW%X>+C>J7FKO@``(`!)1$%4V33%DN2M>@BT
M?$;K?-EJ2?:A2J[I99[Q?2D
M6;UB30M6W"\O+RL2C<^S+?!<_/?NU='G8119%<
MJLHIK=R/DEO>O7M7_DF2-ZMG6XJ-E0MYIM5U_U:30>G>LL3FXY_NBLT_UPC/
M(_@31.$U!0#P3`#88]0R6B-F<D4<'Q^OBWY8:>'2-2VLJ9B0@>W#-1&>\$6/
M@8#DH<J4,=.8S^?2%U2]M*R'S:XQDTU%'%0W#.V7']48JNEB!TN,E[;PV+7^+HI##;CH;I9`H1J=L
M"H\>/7(=*6?3ZL]<2S->%]]K-!HR9X$W'N*N:-%4:AAV9RL>FX;
M(2$``)X)`(`3&TJ^NEK4>O=O(3VU;BH:Z6VF1EB19\H?FO-K5>-N0C^;2I>,B*1=3XK2?"01E*8_(JF)Z#1_T1H8;(U
M2$97JG-+CM?M=M7\\JGR/$_3E"@*<;!NM\O*<1S'S%AZO9[53>TADWY-79WM
M2CR-GC#1W8<B@7(\U6K4;R-8PA/H.B$)*FTR;%^3TU3%6":-"XI(
M+<MS;>5"76]WO@57\KK-2(```">
M"0`;A+4CXDV&/\A0:?R>^+VKJHZC**B50)H<F'47*X-EUF%5S3>1M74S4;W$
MSA*B6T5$Y?RZSE;JBK1F_15%L48CU`TLA2+CJ*7GN92WO_#""_*_,O]\.!Q*
M&2@MC"3W#1*#P6`@?\6Y
M=4#=!%&F.LJ*P31@C7F\FZO:LIM0IISY?.YQXJG!4;]UF<94+\VUO"SDM9@[
M%47A,E5(MZ&DB\0)JS##+,NLMC`SYD*-@WPTZ\ZV=$%:EZPNG8"-5S8`@&<"
MP-Y@1=.I5&(N+R^O966@?8%T7;+&9E6/6/5A:F'E`'[9>.NMMS#FZ\6Z\KND
MRXAGUC0NJ,NMTMHASW,7>6!&Q.)T5:[^QX\?JI/&_JMZMGQI*<
M5(G,=TF4HKXL#Z;\TY%^@9$QWDL;O^1>9WVTI:-5UQ
MQU9G&(_'I2'H2!8``/!,``#*834`6V.KJI1G-,N'U60YHDR9T[=V@J*^KZ;+`W6:M5:6-YL,I`K8:K0)5Y\8#)I&DA,MU!RJ*A
MM&?B#Z2R^R=1<@FY8\CX!3XY"97U6?B>U\M^9;REQ_6GI'>/>*8_3MCO
M/97_Y38VU;>LY3QR15'4)6.\]RKQD'LR_<G,V%PE?]+<\TOOW!JY4S=!VK7H
MKH&Y%@#`,P$`<*(Z.8RBR/^"!PE9+Z(H4D-:D5O*:"MV82E3,OJ$7PA]G<Q6<WSG*WI_"7K;5:>L`D/,%`%JW0'D<LVRS(EYW7SW"3/
MI!5D5BM)TY1%:SLR<WY^+O];U]VT.0"4TKN_96G-Q&FY(70Z';G,S0"'-9;V
ME;":F3Q.=9Z+7J]'G]7N)-\^69:I9^232`%S9?9*:FW.>ZO56GOYG.H)R>O%
M'IE+```\$P"`Y4%O;MFG>Q/L:\OPTV:/!VF]?3ZL7F+)%<,P]"CK9N05Z?U$
M98E4!'7,_.;]//744YOF##<!<J:D?ES7`Y-E&5,]GU<>T\;N"
MF95'HJ+>>?OV;;-$Y(8&ZJ9!:JMRD*W#Z]>&^:^LS9M6GGZ_SU'03!62).%5
MS"=9CI6UV^TJO2B6\`6Y+%9^=5]*>*_7NRH?5%U4)_E!$)R=G<EJKHK8RR5?
MW7B1IBGO(58WIKGM^R?"/_)^UNJ2)6E3*"T$8.YULD)2:2"WN1RVF5)1?1,`
M```\$P!V'=7K$"CESWSU"HW<*I1&D9G._
M=1$8CX]]L5BPD)"5H6I%>);5:#22TV%N
M.\O%RGHL(%78KW]2*C(T__;%$DN>3%.<)I/)>#RNNR-=;94@``#`,P'@VL(T
M+;L4WRB*2NMJ7(-8R@VU7J@+5L4D7J]BC)@KBFYR6M/YOSGFR276K$!W30``SP2`
M_88KH"0-#-XRY+RH.U?N337=:GBKQX@RF3<W!WE.
MZ_31F/MW%5<$N)_PUVW$Q1N@N:#NWKWK$BKU4%$4F=,,N$2+1
M;#9GLYDKD5B98'8J!"--4T^CCJ.C(\^=^)YE@A)D`_%Q$9&W4N^NMP(>'Q$KFA>=:%=;KDDNZ&:DZB6K9\F/??<<]4Y
M9T6RK4:X5K%6E?I;:W5TNUTY+/Q7:Q`*/1U?KB@*UXR7Q@Z8.Z%5_-9E5/6_
M-&'7`P#P3`#8#U37M.C=9CW>:B!GA?)Z^S.)\I7Z)#U$5(Y>E>DH;5CJ`FF0
MI)EY]"KIZOO4@YXCSSHIY+C8QGNY`6(CJ_RDLD
M\3"3M^4N,9O-^'ZJ5":3ST5B4+W,E:=IC<G->KV>O,\XCB4=??KIIZMS]8IL
M<%U)(GY/+_IG`@!X)@#L!TKKQZIWF_7])]_0S)18X=BOS&8WKV4I^M
MAY))56\+O49))>4I8P4QBJ(XCDW^Z6*DU!\%*VAU5!E&CQ)\?'QLZKA5")6D
M!/1;Q3/G\WDM8F;MB$-?TIIJM5K6$R[',ZV4U80K_777]AD3BDQZ-ADUJNHQ
M*T:4T&'6,F\\AG3,>#R6]Y8D"4\]$A
M<BC1>:3K7K)<?^,-J\E#ECLFM;LH"B(_)F_G):S&2IG`MAS^?7EYN339#L-0
M^@!51(F'>)<&B%K%@Z9/45":09(<Z2=,TW0\'N=Y7K$6\=*,M-/IT'5IUY)/
M+6]5RC;O9G3P\?&Q:]+K"H/'6K2NID2NZ2ZU4````)X)`'O#(>OZ)_<NNG*)
MJ"0S_$QJTC(@K0JI\$"R/JMBR@J624C4Q+DT3J::-''6H#O2([$B-J<URHF6
MBG@55ND)WAN/Q_+,5F7:10^J.`/Y6>;SN?E<+NV_XHJ3/S'%FY,_26V6)V-<K2-CW:YI*SL_/Y="0AR/=A4IEEF6F68%#^H.
MNSR^2IBN7`Z3R82>ET5N7;F.2VSL4115K\E4BYFCC!``@&<"P$S`*5B)9\V/%D6^,--I[]^XI
M_9((QG0Z/3@XR++,.G&D&+WQQAO5N0?@A^1U7,Y7#JRI-4I.4L5;(M5Q5Q46
MEAR7]B;0.ZSV;8VZ=!2GJW6YW.1=ZZ:Z[=%H9*K^9(9GSD_S
M9;7N\Q59[?B)(#D:BYMO>9(!L>3XL,;Z99<SEV
M:*ZE=8-4;3G[,K35-*`$[Q2>96%K-ILL[?/Y/$F2Q6+1[78EJ:@8,V6,Z+F5Y%266!)37==`L.FAVZW
MRZN>II+`_/X-OE/I6;=?>299NDC>MXD
M2123;+5:K`\UFTU_B&#U9"%2!_EL-$'T;ZO5LFI"-*=F+T%Z%OJOJ:&2VW,V
MFW6[79Y3[I2@J@H!2^OW+HYGA?P3N18/#P^M[AU>:%$467MCDE+.M%#Q,>()
MLL2QJ<$S'U9BL'01T24X29S:[]0=<*ZY&1%J`1IM25V
M.AUY>X/!0$OM]?['B;K?;;K=9%$EC5G=57&3=CH=:>_@_22.
M8_YY*6GT\.1:#&H\'G-K$Y),T\TN`S>L;Z5'CQ[)9\GSW-S&3T]/S7NV/F;%
M^_?34?]?Y_-Y:3@N\AT``#P3`*X,Q#&LE3.D)3NH5BK0FNZUA:KWFR8&-`Y<
M=)&U?*7_3:=3IF&DW`?O#HFL6%"'A]TD=2[=A55&JZ>+."J?K=_OR\.HN5RS
MV;3V2.`K0E]9+SQJ*$6HTI31S"Z16L;3/9_/\SQ728QT0BFB<GXE`Y&:KA0;
M]HVKN&LK<H!D2ME,!@H1N2OH]/O]\U<0169O&*-KA5AME&5?$89$<P`
MDPVMQ$ZGP_2;)K=6\((U$(;$S)1>)J(>NY7KQ6'=16G0Y$_DRTC&<7@$P"20
M?!(>\VZW:]X`-QR2)ZD8R.,/X?;GEP!Z_M9A+_-^Y<T=J3E)EEQJ&5&>C*"+EAL9D-!J-1B.7:W?U
M)FFL6/O]J*2UJ&GBGY#ZSO\E=4IU2@3;7`72^6"2)=9?^_T^B42C<<FN5JU7PM&)JM]NTX;=:+0K9H%W%L^?[
M&SN9)@\EA]7J])$E<-8=<ACQUO+RN)')<?6HVF]$]LQSR3ZSW+*]+
M/S'O9+F&R:6_*@TP6:*F.@"`9P(`L`Q,XRCI6RO6K)-Y/G7H]U4YI*-:'\6SH;J7KS^9PB
M0CM*:2/16J0Y"=DF\5H-.*_EGHRI]-I%75?
MV8Q<J]+5(\=:[,?DKBS_<1Q;HQL\E-A%'NC2),/<3%*2,7ZTP6"@5O3IZ2G)
MK?I^R_F9YL8B[S_+,CGL_7Y_Z5R#TII,TFQAFK>(D_1Z/1URK&EFOUU-1'OU^GW=(L^4FA:*0V)LQR2RES6;3(\SF#-(]
MF#_Q![(9!P``/!,`M@IZ:ZX8VLHZZW(FVQU'M]M5R+)&2A3'%Y-'4
ME67!9:)BD6BWVWP#<1R3?$H*(0F#)XK/5737KQY!
ML.)T*YXO9YGZQU1D7QY#AA7RS";#,:>`!DI&I:XK#T(:4.1GV@P]2<@5WS*3
MR81&E<9$F>=DZ++,+"TEL5QLN2@*,V+<T]/8M8[\4^8/5>AT.J79N:@0#@#@
MF0!PQ5C.Y<@O2'Y/6Y,#:N%I85:A6J\7DJM/IS.=S>9C4D#J=#FN!2E,D
MM9M#$UD_MHZ8-=+)5=R"E!NZI4ZG0P%OQ!C#,!P.ASP[15&HB:;BHJ2(Y'EN
M#28,PY`[/09+)0H"M8P^2A2EZB^55#D1?$QIC!R))1]&RK?2=%E@DB2ILC-T
M.AT23A)^R3"3)*&2L*Q_>PB>O'G*&9:0PLDWS.M(>M?YGCN=CNQV*T^RHE.N
M+DS'G8IWD,_N=V$I]Y3:$$K]M/*Z\K<TDC2PI@>,MS5%DY;K"6G=.=7Y/9)<
M,6QXL5AXXG2D8'NZ"IE#H7S1\KU`^SE]D"6[)2J:@:JCM&+3ED4=`,`S`0#0
MJ"FM1ULBWYY]_?F>?W6R*X.?)2;705)DO`4F'X,%C\I<F0X,$F"5,TKIF"UVVV:;D5[
M3+;`-UD4A>F!E&TP2"HXX+#?[\OG"L.0^[=(V43U;G"LU45J:%)&3U(@)E4N&J\.Z
MDZRRO<1Q7+T6@'P**W&=O`-U5U9O:A1%/(/T83*9R,1FM3]0`I*Z6)`DK+JQVL&(]G4Y58W13MV!5B3_S3Z;3Z6PV"\.0_B0?<#`8
MT'75X_!]2HUV/!Z'82A=H,J3V>_W4<EP"9L.+T-S/7)9X"B*^*^ER\>OFBLK
MR1(<P+R!/,^98,AS4J<?R5I-WN+Q@$GN9VXO]$VSV211IZU&/IU5LR^*0IZ6
M]OM]3]TFWH%E`'GIZX]_Y5H^15&PK$91Q#NM]951%(7Z7M%15XERSY<N
M@XLZ;6D$./(S`0`\$P"V@;K%?DS/@R1.OE+5I%GL]D2D4EL-IU.J8-BX(BRXU;CRBY@<H#)9.*I
MD;OCDDTO54T[Q2P@OV-EL9I;3K$YLS#LT2Y*<
MGY^K9WSVV6==IY7<+XYCM0KHHH/!0#XLKSA9@LO#P?B>MQS^?7IZZIFCS14E
MZG:*%.V-,HZC+N=I-!KR*N:NTFPVDR1QB2CQ4NO>
M2Z>E`R3QDV6<76FBGD7!W_.FW6@TU.8Y&`RD;9%I:MT2!J4>VM+*R=;4#```
MP#,!X"KIEO7U9JJYH]'(7Z=^/I_O<GZFO^`AX?+R4G7^<.DBTA*?Y@RE/04-K')T\Q"1WBQUQ,%@8/J=N!*/4M/-06;&Q9(F@WA5])VIM:LF
M-Y>7EZ;ST&,?L?H_/>`.HM:3CT8CU>!1FFD"X:12I(57S9;#O_O]OFKM*-U0
MP^'0?S]+>U^C*%+^+KE'>>(1;MVZY?J3BR&&6):FL,IG\X3).P*$*5=
MR-H,AD2(9$#90ZT#SB&FGIVMV^WRG?!)%%4.ZI1)R_/<XY,LG7J/<=.<<0``
MP#,!8"?HEI5GNEZ'_`JGJJ>FKK,CCVR(GY^?FZ*
MMV2>T^F4GXG4S'S-<:UTLQ*PM#K
M]21KNKBX\+"U8+5R.]6;;:KP9MD#21J>Y#2Y6!#]B@2@-+!SB:<K%2>_BUA-
M[F0R.3L2>U*GN]GE7VS)\G2>(ADZM,O9^?`P``G@D`F])QU\A.
MF\TFOV*M07%FI%">Y_M8!(_O679QH-PA3W03E>21RE88AJPG,?4UE1*I-_O!
M]5UH4LQ@2*F.TW])621MK-%H3"83J3Z:&O]@,#"%9]5K=5Q+>.JR2'53
M]??SA]O5#<:34\F?I6KNBACTE`,].#B0MR%EH]?K,8_R;$'6Q^>GZW0Z9M\=
MUL)'HQ%]5H3-M7Q,S5Z)9:F;J!;F\*T-.
MT]0E;_ZE724>!]D-``">"0#;TW%+]:?JF4ND5=32)$CE
M4F&6'EXG<T2C*&JWV[(#"BMPU^ENL]JE84OI]L;<MHGRYLL
MXD*_XA6DGH(C+-2^YQ?")$E6]`*IR\D6HW3_DH3D>>YQGYI1`R:H?7<+#4KH_SV:S-$WE85$4N5XN)N.B_;-4;OU^2\6W%6LU1XF$BM(6U(`W
MFTTRM_'3N01`_E`V(C:73ZU`'I?-SK_PJZ15HPX0`(!G`L#V8-4FI;K@SQ12
M1F+U*JT8F!K'\7*NL!7!&6YU56VS[20K,>J1[]V=FIUH9B:7KCY*6U!EL2B!EN\_29(LRTR&7Q0%EXSF
MKL5TD[)KJW5!T2R]+%8N'OC`(``'@F`*P3KJKT2C'J]_MF=F4?=AEYPRZ.D<>LI_3,YBSV6RYSJA7
MXLK>$4CUFJ9&%@J6E-*JLC-7X?8>'IBR3>>7&BU=A3R-9N<&18?Z_3ZWP6PV
MFZR%\R.P`U]ISY2WJ1R/54BX:],8C\?RZ8;#H;S5@X,#'KTLRXCKJJW)]*1)
MAM;O]Y64UO5:J\?DYB)6//?<<VKBU(;C(;WTI/SXZK;C.!Z/QW)#X`W*8R2Z
MO+SDT3`+1)'@T8#(69#=;I9@GLNA8G-(CU^4]CHR0<IAM]HUZ``:3PI4H9-G
M6<:#3`-K;I.1AG;9MDYJ9K/9S&.+M;[D9#:I4^WC\^#&-1JUPQ#S/51DD
M%1K'GTFM)_V`-`EJ<%_E*O*6.$F)Y]2L1TJ4E8H,M5HM5EPDY59%2I1RYM*P
M:R6P2;7'Q'BN#$D+/ZIO/Y](6TV@TE+8]G4YT.K+;"M^;V@:+
MHI#Y=7$<JYOQ.X"CQ,/@Q#5BM=/BY^
M<+XKJ9#)GBNF`BU5*`7K]U;#_-'1$<]X75?V-=.3>'S(LL`Q>'*BB82H@:IB
M]:`%6X7)*YU>74N:DQX_?JP47R7J2I)5=Q_^TKJ9R&U'"GF695)$BZ(@KQ$/
MA9(*L](U657R/"=?(IW-],'R":7<1E%4RQ!F!N6JR3+;=:B`3P_K\Q`D%ZA3
M4>F^K7*`63B?>>89>6]*-J1%C!^3\RU-LX@KIM>LJ>.B5=4'AZT/E(0I;\;,
M36`#3;O=EC-(P]+O]_GG<@3,K9A&3XHW/:E:AI[(;96OZV'.2Q#OW:GW#@#@
MF0!PXR`K']32DNGMI5ZEUH!/,QPNR[(K::+(S0\DY3/OI-?K24UN.!S2K\(P
MC*)(JHS6T&(ZTN3J4NEAO*P=CK]61Y
M*BE4/(9T?)JFUD%0"ZK3Z:ANM\J.I@9$51137D\=KUY5JCIN
MDB1<>HJZFRIQI>.M(V/6PZL+<H%:_U2:4EMJL;UF^?```)X)`/N$Q6)1*W_#
M[#RFWNBJO4;!-)DIA&=*4S]?M]4C)ZO9/I=#F3D'QVQ0:E1Y'FR(RM=0U=I]-1
MC^#*T369&/G/Y433!RFNZO@J,WAQ<<&W5#%89C:;^0/CKR0#!0#`,P$`L(.T
M!%F>D704TR%6O0(>O^I,RNH*A;(6*=DTH^CW^R(Q.!@,7$]*HLYW(JTS
M%.7.X17L_C4'QS.DG4Y'/G*_WY<473I7F5.ILREKFJ<`K(NDR47A<8Z9;4*[
MW:Z:A==>>TUN5BZ/EHL\NZ(8_+L6Y8*6\A^Z?U>W7H%G%EV
M7<^R;#P>J5?JM6.]PT:C
MP8>98<F!(Y/</)44;RFN@:U$C5H+:9JZ(CM4ZF.5I3V93$I+-1U6#3;KQH)2!JR2+EF_BH)6
M9.$?<T73J+)GM=5JT2RHFXRB:#:;Q7%,CG2Y#=*F:M)4?[$#3TQU:9)_K2H`
M``"`9P+`>F"2$*E)N`RHZGM91\&C<Y@O[':[;9)8;D>V1IA=]63_=;J5*S@=#KE3)?E_>`M_HEW";I5)3/2<??@P0/7UC$>CZWC(PD>7=T<
M!#-KU!1O%>]=%(5D;L/A4.U7:KJ5)W8RF?`!=)Z#@P.7N-GIDDB?0F95G&QE?9)5Y8@5YGA//['0Z)&#F=*B`V"`(3DY.
M%*EN-IOR\8?#H6)3ZK3*GSF93"0I*HK"0QN"=PK;5%^>01`<'Q^K*WI^KDXN
M+3N>;8$/D]'19L=7>6EKDJ'RO\G=3`HPGX>S897!3CT%GY;%;#@<DCCQRZL*
M+WX<&D#5OIB&B$]B
MSJSY^E"S.9_//8H:WQ0+`,P%@#V"J&E3147Y#;U9^;9,&$,<QO^U*
M>VEXX.I5;9;C)X=A19U8G5;>+6O)ZAA7Q7RIKZA7^&0RH?*`KM^2>B1]E>/Q
MN-%H6'4@5N/H,4U=G%5M]2Q6=Z*?KK@P&`R&P^%\/A\,!ORPK-5)U9`U0G5"
M%@;*X>3IX'N6U2Q<>J?+G[FS*49TP;%5.S
MVI8U9H_GI=UN2TGVZZQA&'+L*RTT5^]-J]8819&DRKU>S]J?@VZ);YMF@052
M11Q8G>JF=6DP&"B]7SYUN]WV!*B;WW262*ZC?-4OEDZG4Z2)"2Z-)5R<#AQ_>SLS'S?T6C+UP'?ZF*QD"9+
MZI-,LB0-!S1$M!;,X:(]V9-4(FFJ*985.Y#M"ZY3^7$`/!,`KB'B.#9M\](-
M9555^<5IOK3DV2HR'RM+C./8M/&'86B^=],T-0-B924&5AW,0"REKJGS6#G#
M8K&0YRF*PI\=1!JDTN&DA*>6/Y9RIBE4:>7(_;3786D7-DK?WC\N"I$K4NBD)CPJ5EZ>:5
M(*G*6\Q)K,^EOD_35(JHBILUE[.RLPP&`NO?$TPB
MJO9A=7N2MJGL2IDZRZ/--\]^PE()7*6-AY7<+@W3>DB;%5MP3&;8:K6R+)/)
MZG)"N7168#1PHI!:'D!KXL-H-)*BSG-!/VPVFYU.QVKK(5$Q.#DYD2]"\[7GTHGI;>?1JJN_MZQ*I^P/22_45WL.,I.ON"E@NCR3;F:_BEE6I5V<*EB+D>3>1*I6_"O3.>DM4B)M2@N
MJ=>LE*B&*Y/)A.^9?NXJ09&FJ0H49(V9'T3U/&3E50ZX#&/>47";ML-N,XSZJS.!EN:M]92PXIUELW48ODN*.5@/%ERW.(X=OE[Z?CY?"ZM)/**3SWU%+M,>?"3
M)*%Q[G0ZT^E43@J)'^W#Z@&
M2Y0IE]_950JRF_T/%,P;D+W7Y>5,160VFYG$.,]S]4+M=KO*:Y$DB>*BSS[[
MK!EQQ-_P_9`NSJHDGX0<%ZQM*-W+?/>3(LY/))\W35./.RM)$D^\$(^&U%%8
M5>6AF=9QO=)]T.MV*E,I>G9H&,H=XX'BD=@L5C(SN8R1M2L&J5D
MC)JFN%C']0,]K%*@><2XK*79%,>4V/E\7CI<<BJME@ZY6*00FD$*+D9W='0T
MG\^9PCWUU%-RN=%G94N2FJY:UXO%PM.\GC\?'AZ:#)"IA21L="UZ=I/^*3(F
M?]CM=OF1Z2GXKW1.N8AHF;.0<Z,:4X4D.(UW(
MO_^K4/D@")X\>:)>(K4LC'0_IM.[-J/2C.YK`):-O:XS!X!G`L!^@'0L5\5V!>N+K=%H
M5&E>,A@,Z-UIM;/V^WU3@RR*HF+8;;?;-1GIP<&!4NFL]Z]4Y"B*/*5W69LD
M+<>J2WG>XM8>H5+W4BQ.1;=:7Y8*IA_&>F.D8T519,Z="A>4*AV=7#E>:$S(
M-F_FCLHR,T51R#;K/&5RZI7JR?>?99E\M&O3B]S,I.)'D]2.K0"4?J8>W*?B)U.3,7
MCA<(#2./F!P3.H:8H5+*V^VV_$::=6:SF62\1!M<Q5IX3?$!9)6;3J<R$5=M
M=&F:*B68IB7Q`\MS*,\1QK*:>)(0'3<J/G!TU%WS/)@F7NP0-H-JC_%NW
MJ>)7[P/D@7];6"P6<KM39#N.8][*E'GE]NW;<I1&H]%D,J&J;ZXT2$_HBI)P
MEC?3S>AZRY"TFPN37F>T9\JJ;-6Q1^5J72RZNI#4JJX'@&<"`+`,Z#UZ[]X]
M%7)6/;>^U^NQPL0O8Y.]\#G;[;;I$VLVFZ:>(5493IYAOJIT%+-Z"M6$4%<I
M;7"O=&[F.4H#JYN`YU*`),LEM<#Z^G1I+>;!'I9K+2!,`D`Z(@V.>0;5;]WJ
M4U(46J;SR0(M/`[C\9C%0`ZX=&>U6BV^E@R-/CX^+G6/;Q_+I3;-YW.EH-,C
MT\QR]4@6.7F54N?#8#!0LRE7F<=%%@CG*EW7#&&=S^>J=8?))#T+@1>L6OA^
MOL&,VJHC6JTJJJ*/:<>A1U,:MI)G#L+/\YQ2-U6?$MX?Z#S]?I^&EPH7R:'F
MK#P/[W*I^[0Z.IU.EF72#$&?/7JS,ABYKB5WYLED(I,4Y!84QS$-J2F-GNA9
MTY5-L-9VLFXF_B7F,KU5WZM5U]G%8D&7;K5:<O]O-!JR?JQ5`EW9SK+>+&VY
M+'YR0MOM-E_"K/<C+VJ==+KZ$M3=NE*2)-G!_=:TK)5*@FL,E]NWH3V"9P(`
M4`Y6I\Q:+*597JP7JN(<5FTCSW,FG^:97=5<^?:*HJ!CR)^C]OI6JV42R*(H
M%-V5#K=2!BC?N\/A\-EGGUUB>-,TI3.8B:#T7QHQ&;)E/0\]LJDFULJ),@=$
MCDP<QS0X\A[H&PHY\U]:5=*756I9W6FU6E*/X7-*!>ONW;NRC1Y?1:J\9LVG
M70`_\O'Q,=_J*MH,-1UA%4J>BN9E,!C(+ZT+-L]S^;UD1Z:&2IN`U62C^-MB
ML9A.IV^^^:9)4V58H#656GVC9-[#"OK]OD=U3I)$1FA+V98"IEQY/&O*^"4+
MV$H>510%%>E1!83X2>D>I"N>9DIN98$MM(%NP+4#T(S+2C;F&4PV*_F,XC\,
MU4!8SAT;!SF3D.>(OI?1L\I\0/,H]ULI;\JM[7)3J[>`GS'*M2`W.B;2L@$F
MW1C-D3DF\_D\SW-Y0BD>/)CM=MM:C8GNDS[W>CTI"4F2*(I"W9Y:K18_)G5G
MY2$R2WG+8K]6@:$K6B.T`V]=,1XK6<RL*(J-MD)9KF211_C5.]T4JB1)3%FB
M`:^8G0%?*'@F```U8+565JP?.!@,Y,^Y2H')9+B%@%4[ESOXPX</267A5^SY
M^3E]EN[01X\>T=LBBB(KLS6=$LN9(94&;QI]90"ATI#X$<PV).JE-1P.E1JM
MQLH,<BY]*<I.:[/9C`?$HZ3*>:<0+ZL36!;P['0Z)R<GB\6"-;/#PT.Z^21)
M>`2D/[/;[?((=#H=R2WY)&$8RE&RJB/+57;=$$@RS\[.V`51Y?;4I+-*YU%E
MK)12.J5="YFH8!S'?J^C6OO\W^%P*-U?9O$;<RUWNUVIB_-G>1[YV:/1AF'H
M207/\YR6`S>*D,/"*Y03O%NMUG`XI`(_C4;CX.!`NG.YDRW-8*?3H4%8+!;-
M9K/7Z_',TL+A!442SM71J&]-DB1FCQ`U!32G+N<>#9%9WL9CX;(*C+E/>@QM
M+($TL)+O2>^ZY&#\='1%E1?@DG\6,*O,\]R%84AW2UL$GYP$CXUQD\E$5C[C
MPY(D4>'3=+=JR=!C<NXESS(_OF2`IE&&;D!*,A4:(#DQ7T!A&,9Q?'IZ*K/B
MJ5HR#8MR;J=I2FDF-.PJ&WDRF6191M$?K@'WU,>20\HB),VX:PEOKF7J=4EF
M=1.>6FBSV<RZ^]'B4MYCUU50F!<\$P"`&K!J\.8;U/I*4%NV2OGC=^U@,*!7
M5)(D\G+\WN)?'1T=D;8Q&HWX<KU>CT.8^%4=QS%M]]/IE(]DTMOK]=1+@M[H
MBBQ5*8`T'H_E>X7*0DBEC5_/YBM<JNS\X/U^7WYOOK1ZO5Z_W^>'4AJP&GRE
M1,J#Z0`:!^N\F+9\\ZU,^A:W)I>'M=OMV6S6;K<;C88T$LL<0AZ<V6QF;079
M[7;E3$E/$>M881C*^V<9J*YY>[3PU<'][B@'S`Q`]8`GU%53Q)00JYY$096F
M+$G211+HM[8H%ZB'_MVY<\<5]2#+M$BOEZODE2D5UG.Z_LK[@$D;:'C9:<9M
M$KD5RC///$.+40T=31Q%[,NNH6F:CL=COF<:&19:^M!H-$ATZ:+2VR_=1.;6
MRK3!^A1R[;?;[>JJMMQM&HV&/'EU2PT]*?WVO>]]+W^6/69X$!J-AI(9N>U+
M:BJI;RF-D2/`#T5S0>>7CC@SW_+QX\<5'U.*Y7@\)AF@R>6-B.KW\+//9K.#
M@P.>5I[QT6C$-D07QU-QU)3*3B(JYXX&G-),Z'MEF"B*@N2SU^O1@*CHCX.#
M`P^OD_7;>(5*056_O:K>E>8.9F8XNRS:29)XTE!??_UUTT3K,<$`X)D``)1#
M&FY5?W,%,R'0NA'S;Y697WTFYT#P;B]HFJ:DQ"C5A-21.([YY/?NW2.]@;T-
MDF<61<$O;WK7,C^4YU2:JY6!<)P8WSG]2C5!*07]?#*9A&$H]6SY(J<76!B&
M4A?,LLPZ'33XK+1)MX/'+R0G42IY](P4$LGCSY\7BT51%)Q'1,%4G4Z';EB]
MU[D;>+O=EH/&+W@9B2=U+%D/P]7H[^#@@&=YN??]VLM=T&V0E=V,**[Z/G/G
M6YKE<UB3ED-J78^E[3U8YBF9UJJ&RF7"HM5L-FG=2568[%,DTK0ZY`C<NG6+
MIX`G5&:C]?M]E_(JEXDJFN41`ZH@Q5N$K`]$0\<#*(6-GY'24'G;:30:Y(JG
M?7(ZG=)3<*4?KJ3*(90</,]V-'-Y'AP<T(W1@YA]?4TWM8P"F,UFU=M7#H=#
MZX:O=''K;[O=[IT[=\@*1I.E%BGO*OU^7VVMO&:)CYFFA\#PSGDHC1P0>@3K
MULUTJPIXCR5K9E$4%+O>:#387B!'C,:?1T.VV3P^/I8F,+XW5S:L6:&`HU7E
MBN:)ZW0ZM(U;FX4&[X3S<+]EN>=[HF!84"5=E^6.S(+MJV^>2\2D*!N-+!?,
MXRQ3_96E>#J=6C<9&9)#TY=E&3%Y=7[X,\$S`0`H![WLZ=7"NB![8UQ=I_TT
MU?7ZR?/<9#[GY^=L$9>.,E+=I"["9?0:C89\/5.&V&*Q8$63DU)DS49ZLYHV
M3E-#M3(0MH":;VBI[I0.ERSHHM0R?BBE-Y!^$,>QIQ(#CS8YCN@V..V*%5"I
M]M'8*LV,N8&JI:G&BL[#UGUY0JD$,^GE(9*U?*1>%<<QRX:4')F/1\57Y(C1
MG\S$URM1`N05E9>IM"6=8@@J)M`E1<R]6>OE<;822[/X%M\Y,YPHBJSF"?6E
MZ524ZT*6U8GC6&::2;SQQAN4\TR6!0Z(#</0.GWJ'KK=[G`XK&)EH+W%]*UU
M.ITT34>C$:O@\KH\AE$4S6:S^7Q.9^!6*S3:C4:#:1+]G"8NCF-:YO/YG$[%
MA7-4#*JU`I":P4ZG0WOLO7OWK,](M85=G2==E@ZZBIQ-7N\N*D(9"G)%JPU3
MMMZ55Z?`AU)R(@/[E1BH;5,^+,53R*U8AGC(?8-6@;E`:-'QC9V?G]->2BU_
M!X,!S3ZM%%GSZ>#@(`Q#FG3:`TDFU8LFRS*:H-NW;_//5>*T$N8XCFDZK%M!
M%$47%Q>45&^-Z:!GX1)N\N2J7K$2)'/`6ZT6'RP%@R)X5]\\EW"*4CWMX-W5
MGDD4GSQY<G%QD:;I^?DY[RIQ'*N8(*X@/9U.Q^-QDB3T@9^:1NSR\I)XYMG9
M&1U/V\5X/%XNE`8`SP2`&[:$FDUIJ64EC+XQO9>#P<#46F2S+\]KPS3)SV8S
MNA9EE2C;9)9E,H22SB_]+:U6ZZ677@K>70"0]51YN;?>>DM=FEX29O\`5A>4
M`5C>7JO5LOJ7Y#O8&N!'KT;KNUDJ'_2`LB1#4136`,5.I]/I=%2SN/%X+`]6
M+=?IQNCDE-*6YSF/\V@TDK]EK=>,+E8/^-QSSTG5A.Z9;H9/+EU8:A#XF%ZO
MQV>.XYBU25FW-HJB>_?ND6IX?GYNTA)KH2"IIZX]W(M#N*U4TP^I=G-JF=\]
M)1/#+BXNZ&SP)DL``"``241!5-(\5E8-TI0?^I79`U9.$-U&M]MU47>Z6YH%
M&4/(TLN20RU2^+^RDVK@B'\>#H?,#[DB%S].H]$@LX6B.EF6F;7$U(SP4P\&
M`QY_^:LLRSCJDNZ9KD6ADKU>CS5R^M!NMWFL:)>@_8K\^7P)3L.35:.D#,@\
M4CG(699=7E[2/=!<+!8+N7=E649_I7WOSIT[\F&MOC[)G6J!%QW%#TO14MO"
M8#"@B.5.IV,ER7$<6V\@BB+K*C:+XK"H2.8I%[MJW$+5Q<Q-F"6-[H</D)6?
MU<EI$F7\PG@\-LO#T@WT^WURDY(,<R()G=E:LV<RF;AF9SP>GYR<4'BMJQI<
MK]?C%X<<!.DY5S@Z.J(AY5`C]5F27ADQM&DH:QW;:R:329JFQ\?'Q!(?/GQ(
MC)UH(?_JP8,':H=A2GEQ<7'__OT\ST>C$5DM)=D^/S^G"7KSS3<O+R])&*B(
M`*U<%TL'P#,!`/B6'M!NM\WZ$]/IU'1N/'SX4+V?HBB2O=VH&K[UG6?NRVSD
MEC^Y>_<NNQ]5I0>Z*]8G%HL%?584@MZ4G-&7YSE](W64M]]^._#&3WH2,V05
M$%-W[_?[G/8I':TRVI`4%"N7X+Q'F1T4O-/"3I775PXH&@W99UQ"!GW1R<,P
MI-36*(JX!ZG)P53[.*GA46TA[DHO60274>$3D@>)'TKJ+GQ,FJ8R95=R,$F\
MF;Y>7%SP;TF?SK+,JIQ)IE&J'GF:L[%R3_=#^LW%Q85JM\CL(@Q#EGS3J-'I
M=/C+9K/IJ0EL:JXT4-3Z+W"[R#S<V/6G/,]IB'B@K`<3?Z#CXS@FZBOE1R5,
M6HO<+A:+)T^>4,"D61I'NIZZW>Y[WO,>:P,D5>O([]#F8.\@"`X/#RG!6,D,
M%_+I=#I)DM!*H4FG2%HVS]%\\3E)S-@*D&49K4H2!AZQT6C$](,&D,N32NN#
MS-">S6:4)D"!]^/Q6(H<MUJA$RJS@J?ZFC5FP>1@15'(5C1T&"5O\Q9D%@2>
M3":GIZ<T._*69$]=N8/)#9FG7E%NZX-899[$0)Z?S90DDW)/D(D;-%.<J4$W
M'\>Q\L32P_*446-5=BPS_9/WS&$IS6:3YHN>CM.&I;F!'.DNH]5[WO.>X7`X
M&HU<+R.BTW3/T@:J[,)J<Z/OR8[#MRKK%?,44P$M*P\TR?;JAKS9;$97F<UF
MY^?G%&]%,4IG9V>SV8SNG*TPL]F,:/]T.BV*0M5FHS?%Q<7%DR=/6)@IP(''
MBCZ33)Z=G;%PT@APP2?^YMIT=0;`,P%@;:`M]>[=NU9F8GYI>D4ZG8ZLR"\U
M/%E\7V;]26V#[>YFB4C9?)S[C,EWME2L^?.M6[?X?</GI(1/#C]37-<Z,HJ"
M>M(=Y3GS/*>V!ZP&<0D02=5DB!TQ7CD=@<T=2@>K?O2EJ7<N:ZM9T)^H9G69
MH6H39(R@`6^U6C+5C523=KLMZRC**S(WD#U1J>D\'\^S(^.N1Z.1-1@UCF/R
M9942+=.//9U.9:].)0!2,V.9'(U&]*O%8O'X\6-6!^D&\CSG^L8<G/GDR1.E
MUDO/I"1+IF7$.A&UB@];:89K?-22M_I,^(9E5JKD\'1+%!]+XZ,"\+(LH^_I
M&.685>N1(U=YFMKM-@TLW:3BI7+NS"5/8KE8+"C-V-01>:(I`8_DF7:5\7C,
MY:\;C08]@HP7&(U&]!1$4/F)HBBB\W"&I[1#J0D-@D#6UXVBB(66=TC7`G_P
MX(%UIF@TY)A4V>AD\+-JPTL%=15WDCL\NR4E*W:YZ:P&()?ZGN<Y_\FDQ_U^
MGRLY\9>W;MWRF%=DFF48AJH[SGP^IZ?CBUJ?XN3DA+<^DW1Q@2BK*98_AV%(
MF:5YGKMB4_GQS85/3:TI75Q5%V/)M`[U8K'@R[&P26F1_)-RCZUFV366`6?O
M*ULWCH^/R9U())"O]?CQ8S)KTD*8S6:7EY??^,8W:#?FPQX\>$#G/#\_)ZNT
M',`'#QZ06?#1HT>SV>SX^/C\_)QRO$F`*;>34FEDRQP6C.K[,`">"0#7'YSD
M=GAXJ-X-,F?2SZ_HO67V4J.0,]J+DR2A5QTS$-*3S$JM['Z4]\/M$V6]6?*B
MT)>LYK(GC:K#!R)L+$U35C)8#S,9'1</E*],=1@_NV*_ZK`HBEP.7GY%R;^2
M.FCJV=UN]^3DA"/N^$WO4@JM7S)7#QQ)@Z5A/\K'(B?H_/S\N>>>DR4*.0]-
M%JJ1?4UX+GC*B$A+'PY?@K1POAR[!:0_D/2`)$DX.\ZD3V^__3:EXL@T*O(%
M\>.KRKK!N_-_&!<7%Q3-.)E,WGKKK;.SL_OW[T\F$^J?27^ET\[G\Y.3$PKH
MHE.QULXM"LU;98K."\?D@9(M^_.%K)E752##05TF)\I"I$4A32'TF2LW2A,`
M)<Y1U&6OUY-<0G%:DE52_EANB>PIMS/U*5&W)WF%?`I:LRK(7,H;"R>!?LMQ
MMOPO2RG]2YM;J]6B_S:;S7:[36$.P3OQ#F3:(^\N%T:BSHJT$'BRY&":K,;?
MH(+6"YV!GW$RF<@!,<F&N3,HL4^2A,_&@<T4Q"LCY.D1SL[.>']3'0[5C9E3
M3^36DPQ\<7%A5O.67KC@W2D/=`POD\/#0TGA.'R&'I!K7/'-<U=,-I%P"2AI
MF^#_\CC+I3<8#/B`,`SE_"HZ3=U0`IOCD1(9*`98)L#+8>1&G33^YOHRZ2OE
M6[+_ELUM[.T?C\?*6LJ!%:[<8$]9`4FJ_2\=CD;.LBQ-T\O+RS?>>(,M@[1=
M3Z?3^_?OT^7.SLY.3T_??//-T6A$,S(:C?CM_^C1HR1)R%<Y&HU(5J4ED0(B
MCH^/:;]Z[;77TC0].3DAZ^39V5D<Q[1,OO2E+\G9X<(64"S!,P$`T%NYK+3&
MKWEK]"`?IH):2<F0[S-V?$F%5>;&<+<`661R.!S2#Z?3*;^!&HT&O=*H^('2
M+;C88R#Z8G/5F6:S2<H<AW<&07#GSATZC^G[HO<K>YGX-6:UN]/W5FI'%1=9
M<U5O8LZ0E,-.T<NF:X@J,9!*=WEYR=J)K*S#MV$-QZ66XOP42I4W579)IUDW
M]:1R*56#*Z^,1B/6/MOM-E]7V@LX[I$H-!\_&`SD%:4P,$_H]7I/GCRA0::1
M)#WR]/246L#1D%(F*M/"*(J(M]!O294QR1N-R:-'CZ1'@B7MS3??I-P>:O?Z
M\.'#;WSC&Z1'$H\].3DY.3DY.SL;#`84OB5+SI!*9)HAR,,FA4KF!]+42]79
MGY9I+ELK)ZF^5W#E1A8SU7+&Y*)<FU3RVZ>??IJ>@LY#!;W,!^%`XB1)9*T4
M\D!ZB!;S-[HTC9MIER'BQ^/)_L-.IT/#0H8,WF$XQ92K^Y#&'X@6)H'HZT,L
ME/WG)&PTIZ3%2H\]%_941BZ^55[XK/>[E/5GGWV6%KL9@2)W/'.O4%*DFO3P
MW/$JIA1QZOS!.10T68HXT2"3,#")\N0A1U'$:T&)!-^J2B;GK%H^1NW;:9KR
M&`X&`RGY\A*T\]!?^6VENF)2X"7]RT]Z<7%Q]^Y=EP-6F@CIS/26D1'4/%"=
M3H=*$S]^_)@>1QI9PC"DE,ZB**REL[BGJ&PN*NF0:<RE>^,"5^QXY^+G=)\\
M:$1T36LI#QU-=&D3*1='I>DC+R5=8CJ=9EGVUEMO4<&%QX\?T\E'HQ%]DR0)
M[;1OOOEFEF74RG@ZG=)6?'EY>7%QP5K'=#J]N+B@S9]>!R<G)Y2B^?CQXR1)
M7GOM-7JA<(NU^_?OC\=CDFTJ.$19G4Q0>09WJK$S`)X)`%<&4HB9K:F7HNF=
M>^][WZO>"@<'!Z2%TYM,Y@A)U>?@X,`:S4B7D&]*CDGCU*9`E'GD0NW!NSVN
MK#TPX6$G)_4AD"I[$`0OOO@BE63@LG+*;*\R(95=UB26ICZG-#]KY&&2)*1J
M4"K.:#0:#`:F4T6"$C4)Y^?GG)/)FBBGS`7NP$MU9KJB>H1^OT_J`M7W#\K"
M.,U'4ZJ>C+E2M(>.4:9W*8$<@TK@>A6DK(_'8W*#DUH?AB$%N9%>0H<]>O2(
MNRPN%@OJDT8:!MFGR<4]G4Y/3T^/CX_/SLZ(4YV<G)#:03^_O+RD:,!.IT/?
M)TER[]Z]T]/3BXL+HK7$)UNMUL.'#XG!TJQ=7EZ2&?ZO__JOB9V:HVH-_O2(
MV6`PD!T[I'=4A3BZSLD*+DDL6UADCQDYIRKRL-_OW[MWSY,225+D\EJ0)%A[
M]%$&%`TF:8<R3H\[NP:&+T@%/:HV0A)'1T=<8RP0_17'XS'7`:*K<`<FLI1Q
M<EVSV:3-AT9;96KU>CV26[K$DR=/Y*28G6/EPN1T@#S/B9BI'C9,6=FJ99(Q
MDZ]ZM@)SP[%:T(C_\`UP,/!L-J-]DKM]4J56>G:J@$W#6*40EWS1L,B1GU]1
M)EX(/#YT/*>J<J-+JSF&#G-E1IB+469RROK`_7Z?:#G%Z3"%YLAS:FYI4D&*
M7.`%0N$5X_&8Y.KV[=LTJO(-\O;;;Y.?G+8+EK?A<!B&(67_4O"M^42R=OK)
MR0G_5E9"YO).,L6#;E[*$@T:5>22CFM9P&\5QL4YF4$0O/[ZZY/)9+%8C$:C
MX^/C/,_?>NLM?BD<'Q]3:&L<QT^>/*$_)4GR%W_Q%X\>/7KMM=<>/7HTG\^/
MCX^I*@0Q1@HP>?SX\70Z??CP(07$4C3*PX</N7P@O5^2)/G*5[Y"4;N/'CVB
M%\3IZ6F2)&3<I)"NR61R<G)"=WA5_44!\$P`V!62R9%::9K*UQB])^A%*),&
MI].I=!2XWMRF$9H+MT@%B(,AI==+<B16PGJ]'IV3E#RN`2C;\;%RS*H>UW;G
MRD"RGI!LQ7%Y>4DO4>:K]'ICHSL-#JL.)N/B'WI*R%AI)ZNG=-N'AX?TU++S
MFU)&^16NN)PT\%/==A<SM"8IT2.PNA.&H3(]<-=0EP8FCV3MG)^42Y6PZ8'/
M0]_3\+(:U^UV^09D:/1\/F=-E^H$SN=S,BU3>4"*6GSUU5>_]*4OO?KJJ]/I
M].SLC`*NJ&MBH]&X?_\^\8J+BXNSL[-'CQY1X=:O?O6K=*ODZGSCC3<HZO7Q
MX\=G9V<7%Q>4C?G**Z]0FBA1CC1-26"B*)I.IZ1U/7CP@(JL4N\0*CB1IND;
M;[R1IBEG)L_G<X[E4\IN:8,6RH^E2;?6Q*JHS=/(JU`Z6;>)U3YKMIC5(^HI
MLJ6ZX,A*PN;CT[_D:>1SD@V"146Q:'F3[&2S2BDW3*+;D$8<&CV.Z>5"LG$<
ML[>G*`H*P^8536?H=KLTI,0Z9)"%E?[1TN-XO."="FWTJR1)*/E9+6?9F$15
MD%(#XI$$_CG7**H%.C-5X985O-C'RZM8OE]H@EBZ^(/5;\D#1?57Y6:HBL2:
M8ED4Q6`PX.V(8AFL!L'A<,A7E,/5:K5D>JV47C5<5`&(RD3=N7.'*9#,AI">
M22E7RF],MK#@G6`!LJK(''(::GI`6?*WT6APTUHJ`D3G-^TLS"HY@5;6/9+Y
M"#Q!]+ST_6PVXX3\9K.ILFS8<,SQQE5`9RN*8CP>TV>R&Y(ID!;:U[_^]?/S
M<_KOR<G)^?GY&V^\<7Q\_.3)DP</'GSE*U_Y_]E[DR4YKO/\.VN>Y^H)0S=`
M0`1-PA0U6]K(BG^$M+8OP2O?D1>^`>\<H0A'>*>-%984$F62-@F"`^:Q&]U=
M<W6-W^+W]1,OSLG*;H`@"8#Y+A"%ZJS,DV=\Q^?AH;N[N[=NW5HNES@-#P\/
M.YW.X\>//_[X8S;\:]>N/7SX$.?@;#:[?__^W;MW=W=W2Z72__[O_[)OW[MW
MC][@Y\OEDM1<,MY)K_C\\\^Q<HF48FT2S^_U>@\?/E1=.OWFEQ?%$MN9L<3R
MV@HG#>&^_?U]>Q3ECR5X.O5H,IG8##<IRM86TJ'NX"AP2&OOEJ'KJ*H"%K*^
M6`6F[-$N9'^;^3:=3FEPI5)1L!17NKVL6"P^>?)$;9:*I@1=6BOKT:(X1BC0
MCIH2<26=`W.7OK1L!.ETVJ^XLR$=&;V._29+\O0$7]P37<U2I?O:6S:;55]%
M8"/)VB^52KH^F\WJ)]A[SGT<;5@UO8[>62J59$BT6BU0+N6DOW?O'M4U>WM[
MY7+YHX\^"H+@XX\_YOY??/'%O7OW#@\/Q^,Q(5!@/`DT'1P<W+QYD^*?;#;[
M\<<??_GEE_O[^V@M=^[<N7?OWF>??;:WM[>_O\^41DE%<4010</@)]1ZX27!
MUXX*-9U.4>^RV:Q5Q=3AT-5@33GN'KMX]:4Z7-:C1>Z-$-KO&XIV6EJ-WUYI
MK]'W-BSC3(D(GXLU\$*%2=)JM31)_.FG;G2H5JUQ8G_%A%0?9C(93(CY?`XG
M!"N.-`%V+;X4X42Q6$PD$@Z8YW0Z72P63$AP2E7)MKV];7<`1>>T[6CUP3AE
M]\!FL^EX=NRX6/3+B$3$B"V+_<3'8XL6905;"J+@Z<I2'U[;R<.GKY3-[AN?
MRN&4(T\YG-Q\57*FXU!3/K,O-MO3YN'+VM=#A?+-L6+M7F#,P.!U$EAH";3#
MH?:\#V:+E44B[N[N+FL<[-]FLZFJ0D&%.T8O,$*KSB#.FDPF4ZO5F,`<IA;F
M1_]E<.UQ`"Z7?1&;3RNG@[.QK")%8_]D9`>#P>W;MY\\>?+HT:.//OIHN5Q^
M\LDGH]&HV^W^X0]_`"%V-IL!??_PX<.//OKH\>/'N5PNF\W>N'&CT^FPWJE9
MF,UFMV_?KE:KX_%X;V_O^O7KP^'PBR^^&(_'G4Z'O%SVY,ED<N/&C60RB0^Q
MW^_?N'&#`;U^_?K^_CX)S')!XM8\/#R\>?/F9#)Y\.`!W"<4:#Q\^'`P&.SN
M[N+E_,,?_@"?Y[5KUU85[,02VYFQQ/+:"MQK'#9H6M3R^8?W]O:V'PKC^$DF
MD_Q67CU;U2;`MT0BP0X[G4Y%>B96`+SR4IATYG&*^`H6MY)'5KE&UCS>W]\7
MSYYTG>ET:A$O5$@INCQ%S!"+"BOB!(4"0L].Q\[TCWR']](:#])3K>7`G_2R
MTFYAA'.T;8`Q;4@PPB8D,<_ZU_G7S_6U_.F^!D-J'Z"O*JO3A+$TIVH88\W,
M07M3@RT*J,VYM4SQY7*Y7J_/9K.[=^^2+@O/QZU;M\A#_O###S_XX(,//O@@
ME4H1XO[\\\^?/'E2*I5^__O?W[QY\^#@X/;MVW?OWJW7ZYU.Y[_^Z[]NW[Y]
M__[]_?W]Z]>O__=__W>GT\&#_O[[[W_XX8>93.;&C1N/'CW"".QT.@\?/@3'
M$A=[I5(!5_;6K5L4_)#H=7AXF,UF[]^_?_OV[4\^^80,6[PJU.8Y@Z*L2.SM
MT6ADM3I-;\4E[!TLM;KCVG@F)U1T-"PTWAYJG-A"Q%!A(;/*G)H]QAWV1<><
M=H1F@&6B]O-S33R*"5?=@:0X5%4M!,MCE$ZG[2XW&`S*Y3(-YAJR]42N@RZN
M\DX?,$P)^3!PVN!/L5A44X?#H1W]<KELZUV=C<A?ML[0^\DCUDR2O\`Q$BPN
MES,-[*#8#=R9JYU.QY)/^'N+/[O\K`K';6&;Y)Q-_-<F;%L:7C8]?;^J5-6^
M&BWI=#I.);QM(<:GGJMYR`RW5:QV\O=ZO6*Q:"E#+2^4+8'.Y_,4"Q!/`PC7
M@1=F<[8,+OYNP-1*)!(.)[8JP!6Q#TS5<6"0KF0;<W,-A!#[N(EFD="A+%D+
M4^7V[=M!$#QX\*#7ZSUZ].BSSS[[]--/__,___/Z]>OOO__^C1LW;M^^_<<_
M_K'?[__UKW_%QKMSYPZV'!AL^_O[;+`???31^^^_/QP.4ZE4+I>[=^_>:#2B
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M"OJ?5!:'8X;\3-\73NJLD%ILV-`J^H[NY>NF=F0=+9!\1?0_1W\ME\OS^9P&
MJ)]E']K7MX@X@4D#"YZFJM=G[9E,#[IHN5R2\HJKF.VQ6"S>O7OWT:-'#Q\^
M?/#@P;OOOKN_O]]JM=#A.IW.EU]^^<477S2;S<5B\>C1HWZ___GGGY\[=VX^
MGW_^^>=,E0</'I#F>OOV[>5RV>UV,4=);_[\\\_;[?:M6[<FD\D77WRQM[>'
M'R252BV72TCM:K5:K]>C[A>(?-[ZR9,G:"3T`#6E,I]6.07$HH$?1,/7:#1\
MN\L>#8')1G.R5:--OF@;X%DU(0*Y05C^GEWIH=R/-L@?&!":4*LCG\^S6"S+
MGS-%K66R7"ZMNP3Z):`^=!QC)6)4H"OCLV"9B+\45UJY7":KEA4DV$_'XI+[
M0-]CK5F87%'):U!LGGPJE5)7D*<:D?4:NKK]53D<#K6B&0N[*QX>'D:8Z$BH
MM:;$&5%01J1"2`#0HAG^=FK!5%?MJ#Y_9G`<ZJ?<3E>".:3/Z$XJN[#OHI/(
M7PM,0E;99#*AY8RLM1[)@-7F)HC77"YG,U!4ST)8VV'O!`1(+,W6N4.#:4:Q
M6&1\[>9O8:N<$*B,\W0Z+:Z@(`PTR%(0R21VW$-D4^M[H3I1VD`[T8VWMK:H
M>_^W?_NWCS_^^$]_^M.U:]?^[__^[^;-FY]\\DFOU_OBBR\&@\%L-OOTTT_O
MWKT['H^O7;N62"3V]O;NWKV;S69OW[X]'`X?/7I$*'(RF9PY<R:?SX/^C9.7
MVHK[]^_+]X1:/A@,.IU.O5X'5.G^_?O<O]OM=KO=Y7+YZ:>?GCESAA-G;V\/
MV[[;[3:;S6*Q^*<__0D`V_%X?.?.G?OW[V/_DR#SE[_\Y>[=N\5B\=-//QT,
M!C=OWIS-9KN[NX/!X/#P\.#@8&]O[]&C1UBGAX>'W6Z7.6:=Z8XE'\LW*8E_
M_N=__I=_^1=J]Q\^?'@:#.588HDEEEABB2666&*))9988K'R-W_S-T$0W+U[
M]U__]5^?<M%M;F["]1PM1.1P/#M^4_\;*\08`5VP%?D6CRLXQL&#4GFQ6)".
M.)O-2$X#\0(<.;"/5=A@'RT.`]C5YO-YM5KE$;U>#RAV+B!1D`(&_@4]C_0V
M&L`WN#PI4L=!8J$U]%#EZ",.]@!H`5]E_*([.9:O2<C#S.?S3%=<@*52R98M
M@?%3J50>/'BPM;6UO[]/P1(.PDJE,IE,FLWF]>O7WWSS3<6C*I7*PX</27$L
ME\O<D#F93J>KU6JOUV/.@&PQ'H^Y+;.4FQ#5@5H:F!^>R_V9A-UNE[M5*A6B
M.HE$@I#:[N[NVMH:J4>$&JB=H]FL$3U"\)6`\A&)ZO?[=^_>?>NMM_30P\-#
M0(;T#9_5(5M;6Q;RA^_I/9!:^1P<DVX'0?#@P8-*I4).,@$<[L.="5_@Z"V7
MR\ED4JF2@"[0.8\>/;I\^;)^4BJ52.!4AA[MX:W5*KZ$I)O"'@)N:CGKW8]Z
MJ1HJF\T^>/``/$/<YW0@5`']?A_`C,%@D$ZG,YD,W&[L8-R3HD=B<4(990C$
MTD92&5FUE"8J+A0<QU<?/WY\Y\Z=5JLUF4SJ]?I?_O(7TJTO7;KT'__Q'^5R
MF:&!G+!0*-R_?Q]LQHV-C<>/'R>3R5JMMKFY>>W:M8.#@W:[_=O?_O:?_NF?
M4JG4M6O7@B#8WMY^^/#A=#H%S*/=;K___OL___G/#P\/WWSSS<>/'W_PP0>_
M_.4O?__[W__D)S^A-`@$VD*A0-XL??[QQQ_O[.P\?/CP9S_[6;5:_>RSSPJ%
M0K%8O';MVJ]^]:LWWGBC6JVRRM@5F3"M5HO)Z<PK^Z^F(E6F7/;EEU^^\<8;
M3+FMK:W=W=V#@P,N9K)Q?P9+_^HIK'I=P$T`Z!H.AZ21"R.W7"X?'AZFTVGF
M&+]B,O3[_7:[3;)?O]_7ZW2[74&SKCH71J/1^OJZ?4>M$1ZA#H'W<G-STX'=
MLC_4-YJ$3"?]E5EJ>^/FS9OM=KM6JP&C`N5L.IVV*T4K%%P65BC)HA1\*@[)
M]:52"05@.!S:6!-EC?/Y7)M2)I,1,BH_U&=_G^$H#X*`#[U>CSQYN][M$M93
MG-V,<==G#:C=WVP7\5L0L&[<N*$L8D)>7/#PX<-NM\LD))CYYIMOWKMWC\V!
M+6AM;8VGW+IU:V=GY\F3)ZU6Z]&C1QL;&_U^O]ELWKIU:VMK2SOJ<#C4S.1!
M?G#UP8,'9\Z<65]?YSZ0&VD;#(ZY,1@=.YUTA]W=W5JMQBH.CK%>M5=7*A4(
MP!Q>TZ.C([9Q.C"=3A\>'K(G.[T7!,'^_OZ9,V?&XW$JE>IT.O96!P<'V]O;
M!P<'[/8;&QL???31A0L7*,M$6[,-/C@X6%M;2Z52Y%EH.=!=BI1R-#`M50#,
MCBT(!L*\;,6*8<(6Z^S&?,..S;_V&IV;Y/2)8#.52J&+DKO$G@D0]&]_^]M_
M_,=_O'[].BOK=[_[7:O5NG7K%CO;O7OWMK>W/_SPP]_\YC?7KU^_<>/&G3MW
MKEZ]^M>__O7__;__-Y_//_WTTZVMK8</'S+?+EVZ],477R23R1__^,?[^_O_
M\S__4ZU6+UZ\F$ZG]_;V*I7*^OKZ_O[^;#9[]]UWKU^_?O[\^6*Q^,DGGVQM
M;=VX<8..JM5J'WSPP<;&QIDS9W9V=G[WN]_]]*<_O7W[=KO=/CP\Y$`G&:K1
M:'SPP0?GSY^'0;K;[38:C9_\Y"?__N__GLEDUM?706-J-IOGSY__\,,/2Z52
M/I^_<N5*)I-A\]_8V.""Z73Z\.'#^5*SX@``(`!)1$%41J-!9)5JID0B00VY
M!0X\33I`+"]*GL?@$5*<;^U$VS\0+EOJ-GUO32^F!<HE1FDFDX&;7B5/.IE`
M3+&E1SK_=/-*I5*OU_6(2J52J]5T@6C!`(MC)1<*!6`>=6CE<CE+CD1C0G-I
MX$I*)I/^FP;/R+2VJO_CB?LM+)5DDNG'=&TVF^+\X$LR(34ZG)TVN[)<+F/#
MG#]_WMYY/I]35N1,)UM[@',D"`+2065;!L?IXN!8BG5*0/#">-27@O;9W=T5
M`P3)6M@2@<&$5%J1G7B%0L%""M&>_?U]Z="!8<E3T2;?^YEIS@+ASI3>Z:&J
M4Z76:S0:^9`8ZDR+4JB$*TIH'-Y"-56+UVE,:)(;)JY47CM>$5QV]LX^#B&O
MB4+)-$#)X$L+"JJ7)7T16U0;"_TL,I7`)&<J;Q:$9*I)8;[9V=GAZ,UFL^^\
M\P[39CP>[^SLK*VM7;AP`=6'JLY&H_'&&V\`'81%-)O-WG[[[8.#@ZM7KUZY
M<@7CK=EL9C*94JE4K58W-S<[G<[Z^GJM5CLX.,CE<M___O?Y+54/]7J]U6J1
MB`L"9!`$W6[WRI4KJ+FD5*73Z;_]V[\=C497KERY=.F2V&7+Y;+JV00O><IU
M;5/R'/07F](<"B^L<2F52AHL_S)20_T[^]E#6MJ"1PI,[;0%I?33()?+9:%0
ML/5II"D)5$S33*FGUCSP%R8/LI0D_G/]U-]VNPU<<"J5XJVIRQ+B=+%8%$\2
M_F*\78%)U.>O#`>9\'SOK#BJ9NP>2^F=KAP,!JOR5">3R7`XI`<`,;8)BEH^
M3@6U3P,3#6D6FH@[F\T&@P$&0Z52H6_9'S0BVDGLH0"E1*%0<&XK%BMJ!7FN
M97!!GPF=YPYV$;L*G"*#P8#!HBL8S>%PJ/F#]R%X.G.X6JW2'C0KIR[`4BL#
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ML^];![&\O'9F++'$DL_G"?19+'X47`(%3J&+/G0Z'4>=Y3`CKF@/PF0R*?LJ
MD\EP;+-[6A4!'#FJJF0,<]+CJ<&KYQQO,!8&Q_2)\N"H%,W2V0NQ`)4.*\*!
ME^AT.A<N7)"B``JH3#6+ZAFMBEF[*W@:&95^X!B6K>L<WOS51]"Q\"?R?_NV
MO042.-'7HYMSZCLUWA)'-;<(']#$\0J@DN`RI^:-IU`*I;Y2=W&05RH5ZF!Y
M.GTE0'\-QV@T4@8'ING9LV='HQ&P,<0*UM?7[]V[M[:V]LX[[[1:+;S75ZY<
M@6*D6"S6ZW6Z[NS9L^?/G\<!O[&Q4:O5WGOOO=EL=GAXN+&QH>J^6JW6:K6J
MU2K]7*U66ZW6SLX.=)&;FYM@76K5O/GFFP!.T$6$(*K5ZO>^]SU8.J%L;3:;
M;[SQANPW!ZV4Q6754Y]>THZ=M0#IGU`M9+%8B!G2UU>$4G,:?%HV#3NLUOL@
M>\`27<HL=+!S%1R;3J?0S8E&"-<^Z!V")RB7RW#?6:-""\19FT*1L5UT(G]Z
MK5;[]--/CXZ.%#ZBZE)4EI1-BE!DN5R*8!-CP+&H<4]K_MM((S?4_I!,)DDW
MP(;4AAQJR3MUO`"NR&2%%5!`;DJ+T`5.L?IIO$N2P\-#S4;+!<+L52%NX-&!
MIE*I6JW&N@CU:&AGL[JUP&9U3UDR^/&7RR5O9P\FBQGF[(H66X[N56]@DF'5
M:*3LD#'N(J'1S-<]';X69S&JCM'98V>S&:ZQ1"*A0U,EV=0E^O2S!!7QB7#"
M"G:;9F-OE\ME>9.I)98OPR+W:$1L1?%BL>`:A48T?]0\C91#A2*^I>!I<E>0
M&NR+4("=S6;7UM9RN=PO?_G+2J7R\Y__?&=GYX<__.$__,,_Y'(Y&'I;K5:E
M4OG%+WZ13J=_]:M?%0J%<KE\]>K5BQ<ODBATY<J51J/1;K?!]1T,!N^\\\Z%
M"Q>8,]O;VSL[.[5:#6<BYP4X$=O;V[E<[LTWWYQ,)MBE9\^>):\AG\^#[=1J
MM0C#GCU[MM%HT.?U>OV'/_QAJ]6Z<N5*N5S>WMX&$^[O__[O+U^^C*6ZL[.3
MR^6:S>;ERY<W-C8X=&S0R[HA5O$,QQ+;F;'$\BH)075+$;E<+A7!PP(4`JUU
MZSIH!'ZLS/$TRWP2<([-I9%APSU'HY%5"FD8T4X_FL&7H+1Q;@&@Q4F)ZD"S
M!5(O"KMNMXOY@2(;!,&9,V=0$6CV<#A<Q0:^ZJWM-1:YQ!)(YO-Y-`QB<;3V
MX.#`1V!2;)-3QW:+\J;`NI1"(#M?%Y,+#<F'(J6.>9!.IZ47HJ/8\;6,;9R"
M#DDWS4/-12EAF&2"!@:+0AQB\-F0QV%U#GJ2)UKD"9Y"1J+P3H"!Q4X[=^X<
M'GTRFDJE4JE4*A0*K5:K4"C\Y"<_P=X;C4:M5@L<0@*25Z]>W=[>;C0:[[WW
M7KU>KU:K]7J]V6Q>NG3I\N7+:VMKI**<.7-&Q.MOO?56,IDD(Q3+!\]]O5X?
MC\>M5DN9(%>O7JW5:A<O7AR/Q_RV7"ZOKZ^3WRBD&7E`0F6Y7*92*2?P(B>(
M]6)8#&0NT!RFPU>MW%"EWW&@*%0%5,G!P8&C+(K&AF14WV2UH2%ZP`)$,3\9
M=`A+Y:JP4]JV*I%(:.K:L+FE$PR"`/X#S?#0$).UEM][[SVBY?0>-!7@3DE[
MIL=8Q1H7PB-T@DPLR\KK`&(Q'&I;J50BZ*115D9&1`#6[E'ZJQ",9.#9^T0`
M_UKFI^!IEAW_2[O_Z$^6QE-[!04:F.ZR!DE^#E;#((>RLUC/&JW2@/J+*!31
M2H]C*Y;]B=D`A(RU#^T[<K+<O'G3]N1H-"(9U7:X<Q#H<`''T>>@7BZ76$J4
M>,C")'@.!:BSX@@YXN,C:QW*$YF@Q6(1[Y)2AS@CM%'8]`%KF<N&U"'%4.H@
M!LP\>)H0*Y5*.1DQH>EO.G.=*+'0:#<V-AC];#9;+!;??OOM]]Y[;V=GAW#?
MY<N7SYX]>_GRY4:C4:O5,-O.GCU+KO[&QD:A4-C:VLIFL_(,DEJUOK[.7W.Y
MW/;V-D5AV]O;<%W6Z_5,)G/^_/F-C8WE<DG:"QD*R63R1S_ZT7*Y?..--XB:
M-AJ-Z71Z^?+E5JOUHQ_]Z.+%BQP65Z]>Q20N%`H_^]G/2*!E75,QH4Y>%9.,
M8Y6QG1E++*^5H,>42B4"&B0:6>TSG4[[E`80'W,2<&9;9%1]4&4O-`\ZJ$2H
M:%'XA8"G<D1K2?*!.TMC0_$52XH]*64.H<FAKUR_?IV,%RFX)%L*L=:^NP-*
M:74O1T]5L(6;6U6LU^L!/DGH-3#L;1SPBNV$IC72,)%N!V&,$5+%1$]J"3GA
MNA"C].'A(8CP^B&:C6].<]Z'TH)+D["A`":)</PM&7JE4D$OH=I'65CX[\7\
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M$:OJ0IV`%91Z("G0AP`NV):7RV6^P:-!J217TM1^OP]B+3--\4F(YH-CMD",
M;85J`P_>&713O:Q`LT.98RQ1;718,@*6-IE,WK]_WYI5_MC9]U((FH;)P\(3
M87#%#RBKTFZDC*E/G>K/S`@#.R)]PYF'_HL[Q,M.#%88&8X]+UN7U\QD,HP(
M*W<P&*AXRN;#V\GI;_CT:C*9E*MN,!B0G(E/RE+U:#)7J]5<+J?T:1QYI.Z3
MM<LKB_;3EB'@C%/S9!-:B'+K[=5;6.AORS7M#UEHD91_,1.@5"J!.Z!5`,S[
M^OKZ][[W/>;_F3-GR#(EKX0T$T*1E4JEW6Y3^]-H-"AZK-?K&.KE<KG9;.)-
M)N]@?7U]:VOKC3?>`#R6_?_<N7/U>IV?$ZMD@VVU6M0,3Z?3W_SF-_RVT6BL
MK:UM;&QDLUER9$1)2J9WJ]6R*_K==]^-=<[8SHPEEN^6`+'#8<#1-1Z/T2"/
MCH[0$GSU#GXYK";.#%RM2IR3Y68S/'7V2!L6A\'FYB8J(\^552/.+OY*^I`R
MUGB*18.PO-ZH`L)OX/LS9\X$Q]@S&'L*4P#>8%55JR7;T"[?ZV+=7$=O-IO%
MC"3X%JK@*@`2,3I6OT&A(0?O1&H!?\A$'TI@,SB)R=W:^?K&JI(T7EJ4M3E5
MO::*7(Y>&XM#G>)UT'6(06D24F%K/>@:%SZ3^<P<2":3I#^UVVT*CTE2*I5*
M%'`FDTER]K`AZ<^-C0VRK:K5JDKI<KE<K5:KU^O8#Z52">WAZM6K@:G=2J?3
M.SL[H$3D\_F=G9UVNPT,!BA6F4QF<W,3L*6CHR,4*4)A@K_:W]]7FIQT+P40
M`)FPFK&2P^W,1,5<9=%IK=E2S."X[-]2`85./U[$65SH4G:Q^%5J["VAK)LD
MC/D)`FMK:]UN5XIO/I^OU6IHY,UF4U@L-F/3/C'"V/!A]IRY#4Z>^K_9;%HB
ML:.C(]PB\JD)T&4T&N&>8U:H\I#4<75.L5@4H^!L-@/?2YL8MTTD$F2ZVB4O
MTF!R(L0V3$#>B1=%9YI$B-V@J%NVKHK0F*><4$^>/,%9:>-:Q*)I9Z_7<VI0
MG:$!",#9M?SKK0N,TP<OU70Z]:>9K"E:J$5!9SJU\5P,2AQC9PF<P/>R-^]V
MNT0C-8B6J2LX#K,3X;0N$@:+'<EQS>3S>>X&!XQ-PR&1$B^2"D`H9(7.47.@
M5JMQ\+'O!08K1/7#\$YI6]8I8#<0ZI/UO67+E.6IU10QY2Q5S(G^;KLY^'_%
M\-O>WBZ52K5:33FKP3'_<*%0H!Z!0R2?SY\_?YYMG.AQJ]6JU6KM=AN+E/UY
M?7V]4JE<O7I5_+=K:VO-9K/9;%ZX<&%C8^/<N7/4CF+J7[IT:7U]G=3<LV?/
MVF7.Z4!?R6?D3.,(^(-88CLSEEA>6SO3:FE4K$$/114<2"W1$0`=*OO[^Z@@
M;/V6SZU:K>HGCO^X6"Q*I>OU>LK=!5W0ZASY?%Z-(6;%W53K(K"K@X,#R\K(
M/3<V-H2-01M`@O&M:-1!::[":'7ZRDG*XA2A=M^Y9[?;S>5RUK0#PX!FH&P%
MI@9&.H<H^]1IN5S.(H5(\].+J([1*F<V'D@S(F(:JX;;5REPBCLQ-!'*XQ?7
M0,C"(4Y^='1$&9Y%H.$.UC"@5%A=)W6'*0K`.,8J%9@J\5U;6UM?7Q?8%3.S
MU6K-9C,I6_)9P*2J+H*;SO&L6WVHT6@`I::22`J0SIT[AVZGW#.>VVZW*93B
M%3#5,"T`M+"\>7XDBM'G68Z#@((ED%V5=6R+8!TW!V_DI"V$/MK2U5H-7LV0
MCL4T<V94O5ZW3Q'REKYT4'S(VY=9]>677^K^B42B5JL5BT5"Y32I4JG8^T?D
M@JZ*=-F",=D2[7:;#+KE<LF#2'^03@GR"FL0&T,YA-HBJ$,6C(I(*67GR,T$
M(U_P-"B+U?CMVK&=#&ZS77V^3F_M<"U>/TE5.S->10+^RA/Q.U:YS4Q%\@M`
MW.&]=('R2C1I57RH%BJC0;6[P=,1<F?;L1XHV:C!TR4;JIBUX<%<+@<$JV-C
MZQR9'@L!24WXZ73*-6PF;""!J>1/I5*RZUA<*EM5W-LN.O!I]`W^+)N`S9Q1
M!0>3C1[6N<FKD4,A[T/P-*VEG+!*(`(_6=,@U,X4VJ7UF-A_58).JP1_Y9\.
MIV1$][.(?=G>WJ9:_L*%"^OKZ^5CT3+<V=DAMV5K:VMK:^OMM]^N5JNU6BV7
MRUV^?+E2J?`E5+U454`_6ZO5\)6H3PJ%P@]^\`-RE;>VMHK%(N%3T(^#(+AX
M\:(2@G0>J:G*6(DUS-C.C"66[[JP35M^ZLED8L^&>KUNU<=0%$&=Q[CJ"6=1
MPF2K$718SN=SV5'!<7:0<S>B0XY[%0PWQU=Z='2D1"_!_S0:#3)[+9>W@`=E
MN);+Y5NW;BGOBY,#W,M"H9#)9+!@]18TV\(_V+ZR>,[6\1\<H]>N@HQ3198P
M8X4KJ[I$Y_R6)]X"M#KZEJT+U1!;]N<3?0>GVH*/'RVV>L5^J=CD\-8$4$`[
MG\^3.(<F!!.,K=[$M^VXA(55R"0A,Y8INK:V1D=1'D,XB$QLFPB'1>J86P#V
M!!X,@WXH;=NB7R!GSIQAY@!R2!9NN]T6D7HRF=S>WK8&,#]<7U\?C4;D=TEO
MDX9MIU9$>3"S#CX5E1]'A*%"XT5*5PZ-<5GI=#KJ3\VT4!L/"'3Y;EBY\J'P
M=K(KR"*6%5HJE4"#E-G`U.*W-EJK-OCNL%`]+]0T%?&2$OA)<`6NAIQ;\CN8
MYYB:4MP%%RQ#"YN9M4G<U;I1`@.UA9&FQ%J+CJN]RU*F[>[NKGH7\CZL(:?V
M.%V]:B[12)P@HHB+<$A9TX[=AMXC&YS7=^PZ^Q,M0PQO>HQ:;@X:"QGEOS68
MJ/9[[3:[N[MRPU6K5:6PDDFAN6T+\C73P%YR0D_\E_P"S"H+:<8*/3@X4'DD
M'6+QVUD%M.KHZ(CAUC(4+X"Z)9_/BX"$1W>[7:AQ@N,,`FV&%L<(W"/!7%OC
MDQX#TL:QWB$#TTUT0X'<XM]4(]4V2L=#)\GI.?"B+\.CM[&Q018&6W2U6L4!
M5"P620`F3Y5((Y"M^(PH82#5!7S:9K-9K58;C<;V]C9*#K#D]`S)M[E<[NVW
MWT:7P"F,0U!N37+F=<*2L:+_1F3IQQ+;F;'$\AT2X#H#@X-'R27'F)^/Q*D)
MMZ0.>T<MED6QN;G)?9;+)51[P3%=BE4=Q*D0'&>G2*/5&>QCBEBU$MB`P!0Z
M)A()F]U'LS$_`H-]!V0\T2UAF=KSU<GY=(*?D%4X6AK?"!_"_Y6#]1H8`H9D
M,FE5'\4QG'B1!0;TU6M]8TTF#1-AP-ELYB2#<32&`G(X.H3(,.V=Q;MKS68;
M%1&H/81L<*A:D@!H/[@&#"'5`3I8_'JI0J$@1[@J>_E>":X:"_V5;A&'DV-Z
MB>G4[P1['ZN&UFJU\^?/@W^SMK8&ANK9LV=I=JO5:K?;%(XZ]ZS5:MUNUX&M
MEYUY&NC74,MJ%=[LJH@?E*>^N6@G@\V_556A+G"LUDJE`GVN!336I.4#;R<#
MDLB,]H'#PT/M'GJ*S;V7:\/..AN&6F4@,<$<"XT,?Q:@EB0O1:TF>*W\%3X/
M)LE\/I?-$!Q3'03'U=<JG!/5C31^QT^G]2(K@NI0EH:`@OO]OC)49?2RX9"G
M8(DKB(F=,J#D-$95IHZZ[]NE]7K=7D9H:']_G[TK]`ZT$!.(B6=#<-:\M+OK
M8#"H5JM*$P78UG%]#H=#)C]N2E)AQ0YEP^,1YHWO0F6V*&N:V*/3L4)LUF0`
MU=QN%"K+="IIA\/ADR=/>`I,LRKT#8XK!3"QU#P*LZ&"%VHNCP!/2_DXM,HN
M.I[B;/64%#J3WQEW"_5L-QD52OCVX0N!3B4V6*U6-31,=;G"*;QG:VHVFZ3+
M4D[/!:)X9:6\_?;;5%=R4LAQQA#H3&DT&EBMVO.Y@-N2HH(5JINK#V/,V-C.
MC"666`)94+`\+Q8+W,DZMX3EX!\Y.F\LD*-.-4`=5=O9[_>!2^%N#LJ"529D
M75BU0"B4@:&)5RD4AI,T2YY2K595VZE7D/=1V5;``/`69'C^^<]_UGM-IU.!
MC],`YVQV:FS0OSG=.8I4K,5SH;D#SX#F80R+<D`!3*FD$-\K)'BB!0(IKJ]<
M6M;*7"XGPH-5(2"KHSNN65M[R9U!TK-^<1FBRKM^_/BQ5"L9I:H:Y;-\ZA0@
MZ0XV`&L5FDJE(A>#&.V#XVIA9[!\*\M7**-5!-LG]EDV:KVUM05;23J=%JFZ
MLG/]>^*5#U8`8X:.T2K"PVJUZI0@`G++_0>#@9.<IEGD%Q&1XJO^`</),3RL
MD2!H5FL5[.WM.>C3H3U`U5FGTX'Q0C^'XU=;S7P^E]D96A)&*$GP77X^_&0R
M49(JKZS<5^Y?K5;)D`\,K1':)UH['C%FK^YCPVCB/E'&K*A]A(C&!6PL?BZ]
MP\\Q'`Y3J11./=Y(9%'L5RH?P#+I]7IVI>_M[3D&@#@/[5@XVX7>SB8V!T\'
M_ZV3PBGM4PJH?P>ZE*B1,CDAVU![;&6$4-."XQ3]P\-#NIH1M$@SMGH<Y-+)
M9,+/A2<7NG!HI&:[2C^T`('/T5NSMP^'PU:K)<Z/Z72JE1X<%U%S3_BE[49J
M`X/.`4=MOQ`$`H,;Q#<VM;A2J<A_IU6I9<[.#%D7C;>E`?XBTA+FA%*W:WP9
MD=!M:A5*TXD,6Z<7QP.(0UP(4A`C!T&POKXNPP_(V;-GS];K=;O[I=-IZNK9
MEW03-O.MK2W[%$*7.JQUT#2;39##X_S8V,Z,)9985@IE).2RXHR78U4;J)0_
MD2CXX$#3Z=1A/B2"82F;Y2S4ONPH9QR-.C6O7;NF8UA?6C`>%3LIAT?Y3B(>
MX/QS3@)(#H-C?D[IP8/!0-8RRH$2V(3^(OW5!Q+D08>'A^/Q&#U2V7&*?I!:
M+'MRE>;-\8P70"J(R#^M[NY8DA"91!BB]B>R_'T;QO88X*[.?6RLVW*B,FUL
M"A9/W-K:D@8\F\T$'R4S$IJ3B&Z1KF--&FM9.3K-JN-?/Q?E@),C5RP60_$\
MH^\6'*=MKZVM<0?5P<JH\'^.BH-UI-P\QS0*#`&LQ@MN`/OZ%CU2[;&PKB02
M:\&*5<41P('MG7N]'JM)S$!6(S\X.%!\1D,L?Y.US)W(K28)S#$VHL("X?Y<
MOZI^53N)'JT<"E\;7BP6-N:INDI"W"JL98M@>E0J%;P&2O*GL%/YZJ31ZIX6
M7F4\'@L1A.M[O=ZC1X\"4]HGOM#`9!J/1B.N)\_";JV4JMJ*`]X7BGEG0LJ^
MU4#+CV,O\[<+"_WB3!)K`O&:UI@\C<[-;54"K;7&G+3+I%JMSF8S>_]5=LM@
M,.`R)=Q2'1H<X^YP#3DRVLVL,T+KCCO0/UR)/>\T@`-(;$/9;):\V>"8/H1G
M[>[N8E7:*A*+42<7&TL,9%12-T.]2Q8I!SZD3J?C;!K"@5=K;:Z-[S5S9#0:
M6=PUBX\0ZN3RJ6NUDYP2!^@YA-IX0'H"DPVD7J6CY%SVMW0A>[7;;97;))-)
MG5G!,2#_N7/G@B#XP0]^@!W[3+,]EMC.C"66[[3D\_E"H4`I(YFBT@)5C:#-
M5&>&T`YU;AT='>%EI[B%+=[JN#KP9,=*0;%FB35[=*#:+$WM\K:DS8+$Z"`4
M*JPB(1'G'S54^7S^RI4K:JU(YQ0[G<UF_!##P#G`A)$K:-9"H=#O]^VS=(!9
M1G(GGB`2424P6X7,FGS6DTV_S68SJXBH,W6E-.8@"!AW"\NDZ_O]OE7O-$`:
M"T=-X8?,`0P5C;L8YVVQJ.QY>:FAW!"&ODVEMDJ,?>7G@^]3RZ4_^>ES7S'K
M"8;T4"4L-#,9S48E@H[MJAENAQYH7&:1)1H-U4TUOKHS'I!5@*+6\`!V17B,
M2DS09(!LT!8GH^DZ/"M<L+N[J]5JISTML5GK@<FMS>?SX*8$*_`M3U3X5L7G
M&8[)9,)L5P/D@P!V*)?+B5(8JUC3GF1O0$W5#&U-K%]>(3@&P=*5(@RDPJW7
MZ_%?;2D*?EIB1HLK.YU.#P\/;9Q'Y0;HS;3D67%H6<YL7\XDL9.0UEI6DE5,
MF'YX&1`LS;'9;$:^KFV_$]VE`QV*8.W&>@1]J^4`5G!PS%U9+I=7]<:J_<3&
M\8;#H1-75Z%$I],1>W-P7.*;2"1XNCBBB+R1J()?E5"\6J7^A!B,GVM"VC4U
MG4Z;S29XVM:,I[08E%J[5.WH1.!FV>J5Y7*I64VQP^EG$:[#KT-OT6FB*F*6
MB?J!M)V(.^#84MH1[93#6O<!=9SOY0QRG)*Q&AG;F;'$$DN4V!H_;;CV2+/J
M((#^HM;0#V4,<-Z+14T_U$U\WCPG$4Y:X'OOO6=5/<<``.:1STJ>'`P&#MP%
M;F;G3$57<Y0G#M'1:&3SIFB8Y24/CMDIX-*0QB/R%84R@F,:3X>5%.6LW6ZC
M5*GP+T*$5!1*%&%O:QDO[5DK%4K004*,T!T(&4'7%M$8FXHLH2!M.!R2]*5!
M)++M6`B6-?[HZ(CG,ME$HVKGX2JK[^5W)_LM]$/KP3'CJ%6O'?4E-/#H6`68
M.M;:W-W=U5`"LD*&7BJ5HK#P-(UGAJ!X$5LCQUY+%0<-A6%,42AJ)I,)L3OK
M]YG-9B)BM;8TUH5FJ6,)L#"CF7A"=[;3:-6!H8KI=KMR?JEM1)7%$$M-J0*5
M%GM)`4Q560N?4U'H8K%(/5YP'&)U7`#^PK=\)QL;&ZH=T#(7OY3%7N*VZEB+
M$7JBA#+!<!_KO"!=17'[$X-7VHZ$JBKCS6X.@<D$"9Z._I$/+_Y&"TCN0%);
M"UG%%/`)V[[U>WMW=Y?A@Q2:G%A^A;7&O]/IE$.0"7-X>)A,)E5)2Q$[>`'J
M,39)&)C@/B'H:MTZUOP&;<A"#.@UA0]G_;9V2U$)C)W_V@T5([A````@`$E$
M052&PZ&3TNR<AJ&5JZOV6\>C9.5KBF=R:#HNO&<R^9R+&5/?-+5[3JCA&DK$
M$DML9\822RR!54:IQZ`.$-L#!A$V5GL*ZMAP4JUD]6&2P6=E]3P=D^SOUI:S
MA@0@,?Y)X(/R6UO%'@`Z"V7J3*=3QU!)I],6ME$*)9J33Q<FPD-5X]`\7I:\
M7QU(K58+R$3;7?:X(NA'HA3/THL0._)?W%*;KM(+=W9V+(<[N(A^FIF4&)1@
M]`,%IH)CB`5[?OM4;]8QX9S<%MXC,/G2P=/%O1S/@*^006>518N4ZVNZOO/B
MY7$MBQ+6\8"LDKMW[[*:1'(C>\;V[:K`HQU?!J7?[\/00.V634\(CBN$_<"X
MHQJRNK76?!).$LL9,OF)*/H597P0EE"G_$`+<#48#`@L.%B[HICG,M[%H@>'
MBN):W,3/]!.^E]T05BF:>-`T=0DQI5(ID2[R[M0<*GU7'!5Z3?4_Y9WJ4B[`
MU0)X9F"R!D(C;]8-I&+L1"*A;$FUI%PNJ^5@B0<>TF^$TTJ[EE:6)4YT'$!.
M%G?HMB/L(L!+[8)U"#;8)*WUPD1R8'MM'U:K58:>Q@O&*3"9O<UFDRYUDLR=
M,TY,)Q#\.N^52J4JE<K>WIZ27&B>2%P"$P:T<U6N-/*NF3-:X,)^<QQ`C@G'
MR47-L`T\VNT:%"[!V_K>EFB_E?#8?#LJ=(A7N1B2R>0I\6:?S]1TV@8`F[,;
MVQ4=X:CBA(7RQ,+\VF/H69F38HGMS%ABB>7_/W)(OP'JH%JM+A:+;K>K5%A[
M5`AZQ]?>BL6BI020:]_1C=!O+&^UU1N<^AR=;=KN=08(%-'Q2JIA.A$Y/.QE
MJ@^,.("EB4($&AKB(U8`QIU5]Y/)9+?;%1N[[F\;;!/)]%+@9UHV"*L.RJA0
M"%0J9CJ=KM5J]+Q(.$4T8GM#"H$08GRQA7QTM:/-Z$7\#$]J2JT+P'*F2__0
M^XY&(QM!XH<JD_/%#IPSK"\#Q!]M:#:;/J[IJJ[6#]$O;<*M?64G>]`:I<[3
MQ3AO5URP`D#(]B%:&C:DU;PMUI>_9@N%@J)/>@23P<;J&7TUV%%8+4UH<%R\
MQQQ()I/6)O&A,J.52#]L"[7/:#2RB\CN2XXE3Q6<#-'%8D%6<&!0.M'^Q1:K
MX*WL;9:,"E^U@NAG=A*1+DZG4XK'[*+0+FKW@;6U-:V4=#I]<'``;P?6K%6[
M)Y.)DXT<NA?U>CT"U':(':XF71\ZHX`Z<]:L=8CPLIHASBQ5[D;P-%25W1!L
MNH3=1540(?<6QIC_RL[TZW:[Q6+164V\YG`X=)"B58)K;V(AA8/CE./`8Y&U
M?6(?)QO)>5/?)E1>,5WGKP7E9B^7R^?;$IT-Q#DZ0[T2H4ORZ\;(<6[N>$``
M`;(GU"J63MM+MC@SEEAB.S.66%Z`@+6@[5AX?3KF55X2')-,"C'<*CTRYV:S
MV>'AH;)G,6DH!;0.0F70!<9_+W1XY_R0XJ)V"F?%T0Q\QVJ]7G>T"NSJT!]*
MM>(4Q\A<+I?"1@H\?@4=L=9G/YO-['%%?UK_ZX,'#]05,@_T5[!D5&+*@ZQF
M3_.X`P^BUDN018X2[\"THHZLXA[L]7I2)7E0M]OU51;K@"@4"MRM7J\O%@M9
MSC8KVP%L#(X=WBA2SQ&-_)J*?YY5?-Y1ROE.TSS-88V^-%3KHY'AC3<'OD$_
M6.TDHSKNF%"KP#+<6L7142B%6V/M#368Y'#'D>%\ED&5S^<A/@F.,PEU-ZG4
M;!<*;=F":DNJZ2SSX.D`K]:7;;:^%!$.#>.'`J>Q>P5-Y;D`SZH-3NQ7V$7T
MJG8&K!T^B*TG,(003"&EC\)VHQ%QR"0LX=-T.@72&<Y#X&=M/JIN$KJU2FR>
MJE"['4Q4/F@3<W8M#:6(B.'+4:S8&0B*]QPWQ"IQDDOM3306(+?QCLUF4_`_
MZ72Z7"XS!.2R.G-8"&1*?K93BQ0`_]'BYE7[;7PRE4K!S0@9LBTZU3QDRH%2
M6R@41+ZBN+W?:>IV(07XMI/X8"P2>VB7KOK3JE(.!]O6/C'T^Z\UGBD)-0N)
M9-H=.*(8)*ZQC"6V,V.)Y6N4LV?/IM-I6ZWA6!3VE"5-RQ)78/S,9C-'4;#)
M)\ED4O_5J6!!:W58AJKFJ53*AY%0S8QS$/H.5$M<KC8[-JJJ*^4DEIIN=73:
MZ:AKZKH(#/?'CQ_/YW.2)-543CXIT#=OWK3ML2R1$%2H?VBJ$B#1C>[?O^_7
MT_J:BFX[&`S45_("(,UF4ZT2J*^>I91C>\"3YYE*I2P[16`P_4('UT$9?=7%
MR5H\C5\\]!H_.]VFBUMV!+M4;7&R4+(L7T)@DKVM<*7"/K)G+,2KG6EJB1@U
M^OV^)K^:1SF<;QAP\W*YK,=)R7;*B87V3'VF.D?D''[7V;5I:U/5/$N.IQY6
MP@)8LLZ8XH22'PI3G]<4HXF(3-@/94PZ>1QBW"5$IL@AVZEL.=$SBK'3-DGV
MS'@\/C@X('<7AP)YGKI22*0T/J)8SF[R),8[?$*^F\E!JQX,!C)6>2CVDK)Y
ME6JA&UJ'G2:;#W_ML`?W^WT+7"QP&ILH2U6MY@P0W!:DA]O2L99EE/I;NX7N
M[^\[6,?P@I9*)=P!L-V(^\J>>H5"X<LOOU09/(_#(%?;2*X9#`:4[&)S!B;"
M[SR=7534RK[@""@6BX):#96(4.<JG*15=F/$4[Z!_?:4WL9OJY&QQ'9F++%\
MUX5456NTR`TLMLG`@#V@@CCGKA,SR60RSNDH[<$>;[Z+T2^Q")ZF\++'AG]R
MB$L]5&N7^/D\]^_?M\H*A&E6E[458O8^P0J20^=*4EA%!V?U&,@)2)?R]7+!
M]/->5K?H]_O4,3J#0K&?'<I0F[/;[=)(%6Y)F?/C'B*JEEVMX*J:E,OET(!M
M(\?CL;15ZWK0;+$7O-*2S68UJ4`Y/LVO@)+B)[YZ=R*IIKU`M"@VSUP.&O&.
M^--5,T>1$'Y^X\8-YP4!I$$MGDZGFIRK3&AG)@1/%_<R9^RZ\`OA^(GF,X`Z
MRD$-GHY%^%N'C&1-:2<I],Z=.VP[FL].)$?IM<*;#4ST7L.A)HF-DS]QF0K>
M(%:Q?<(-\87)QB#7P](JVMT5C$U<!IH`\B,XG2#V5">]WYHZB41"9IBVM7Z_
M[QAXVL=\[X-L.6?WLQ.`PEJ'3T6H:9JH:D8BD<!P=?;>Y7+9;K<SF0RS@GG(
M;8G#4S)@G\5^>__^?<=3:3^`6:5R<3OM:1+FJ.#N!/)$L+W5:G&9!2$'P4[!
M3')P5+HOP]C"O"<2"0Q1V=C.J&G'<."@['')VNEVNZLP5\E%7[4IK:JWE+<E
M](G?O)QH.MKY&5=7QA+;F;'$\NW(<#BT6J/LO7P^SY$F1@$.O^%PV&@TK*4D
MIWN[W99JXJ`LA-9I^$==:'*734^R]PS-`PP-<OJ_=9`DOOCB"_^A.IQX5C:;
M56C4%A?I5O;8LZB`MB7B,;.`-X/!`#YH(:]*8\,VDVV`ESHPZ7R%0@$("IM`
M)7U==)0RO_WTLWP^C[9JTZ5"LXRX"?YRZ18*:DE;LL%GZMDB%)IL-OMZ0/;Y
M4_0T.6/*?R:U3V.-,:^^M:-FISV4CUK(&`FE4DF3P6KG063R&,)SR^7R8#`0
M9Z;6`DE]J*$VTU+STW$E6#>'G!KC\9BG%`H%1<Z9>)JWW$=ZO&Q(V!KL^PJR
M)=3WX?NV1J,1MZ4-2D;`NO#AP9;+)0:2144^.CK2KF*K9Y7?2YL%PR-K,)5*
MX8OA!859R@7R%@GIEY\/!@/ZAWX&U)0_0:>IB3293$B:D,]"DS"?S\/VZ4PD
MMA1K:0>&1\=)H02IV+=4@Z>S3D*G6;_?;[?;0NMAK[8S!'L/9P?I`!<N7-!^
M<G1T)*QLD*[T6_;`P$#RX/IDSAP=';7;;?P%#'<NE]O=W:6K.?M2J90EQK2O
MIAJ_3J?#3?SD&O)H(&]4!G5PC.XCPU7@L8R+K""`D31U:0"L)[ZO\,3P'1G[
M_7X_PI(D!KOJKZ&.W0A[TA+;O%1B%WXTS4DLL<1V9BRQ?%TB'='J&=;><T@:
M`<;P78G3Z50:\&`PL/@BL]G,+R,)3<Y1PIAC.OHGG$VEDTA[B+8\#P\/G4B1
M#B&TP%ZO)P`/6C693'*YG)X(WQVM0O.`6M!Y$-^H*ZSZJ_"I=#+E-/K5<?;@
M3":3A'2FTZFZQ08$>")D#`RNX\K5N^LIJ*J6_2\"OP&UB>EA85U$]F!_&X$<
M&SS-D_GZR>GQ).S,L;U7+!;3Z72_WV>DH(=U%$V+"BNXU^`82XD[*]<T-/9N
MUQ$/ZG0Z"G<[D2XGM]8Q?55UA@X]'H^SV2QU>BBC(L7I=KN4%UJ0%2<61P<R
MQV1'A4XGWDL3FRW+1YGV=P.IR*QW']=7G(?J21
Re: huge polyline performance [message #719605 is a reply to message #719475] Sun, 28 August 2011 00:21 Go to previous messageGo to next message
Tom,
Thanks for the answer.
(I sent a full post (with attachments) that seemingly got lost...)
Painting speed doesn't change considerably with SWT.DOUBLE_BUFFERED.
I post the code below.
Gabor
		canvas = new Canvas(this, SWT.DOUBLE_BUFFERED);
		canvas.addPaintListener( new PaintListener() {
//				e.gc.setLineWidth(20);  //-- lot faster if commented out
(no subject) [message #719607 is a reply to message #719475] Sun, 28 August 2011 00:03 Go to previous messageGo to next message
Tom,
AWT 2-20ms
M`UC!SJ4\SU<G`-<9_V
MA=\E7&'N\@KJ0"<$4Z
MNO;BI;M7SYI?_(S9'/
M?2BV6BU)1ZO$=+CL
M+WX<&D#5OIB&B$]B
(no subject) [message #719612 is a reply to message #719475] Sun, 28 August 2011 00:03 Go to previous messageGo to next message
Tom,
AWT 2-20ms
M`UC!SJ4\SU<G`-<9_V
MA=\E7&'N\@KJ0"<$4Z
MNO;BI;M7SYI?_(S9'/
M?2BV6BU)1ZO$=+CL
M+WX<&D#5OIB&B$]B
(no subject) [message #719613 is a reply to message #719475] Sun, 28 August 2011 00:21 Go to previous messageGo to next message
Tom,
Gabor
(no subject) [message #719617 is a reply to message #719475] Sun, 28 August 2011 00:03 Go to previous messageGo to next message
Tom,
AWT 2-20ms
M`UC!SJ4\SU<G`-<9_V
MA=\E7&'N\@KJ0"<$4Z
MNO;BI;M7SYI?_(S9'/
M?2BV6BU)1ZO$=+CL
M+WX<&D#5OIB&B$]B
(no subject) [message #719618 is a reply to message #719475] Sun, 28 August 2011 00:21 Go to previous messageGo to next message
Tom,
Gabor
(no subject) [message #719622 is a reply to message #719475] Sun, 28 August 2011 00:03 Go to previous messageGo to next message
Tom,
AWT 2-20ms
M`UC!SJ4\SU<G`-<9_V
MA=\E7&'N\@KJ0"<$4Z
MNO;BI;M7SYI?_(S9'/
M?2BV6BU)1ZO$=+CL
M+WX<&D#5OIB&B$]B
(no subject) [message #719623 is a reply to message #719475] Sun, 28 August 2011 00:21 Go to previous messageGo to next message
Tom,
Gabor
(no subject) [message #719625 is a reply to message #719475] Sun, 28 August 2011 00:03 Go to previous messageGo to next message
Tom,
AWT 2-20ms
M`UC!SJ4\SU<G`-<9_V
MA=\E7&'N\@KJ0"<$4Z
MNO;BI;M7SYI?_(S9'/
M?2BV6BU)1ZO$=+CL
M+WX<&D#5OIB&B$]B
(no subject) [message #719626 is a reply to message #719475] Sun, 28 August 2011 00:21 Go to previous messageGo to next message
Tom,
Gabor
(no subject) [message #719629 is a reply to message #719475] Sun, 28 August 2011 00:03 Go to previous messageGo to next message
Tom,
AWT 2-20ms
[Updated on: Sat, 15 October 2011 06:59] by Moderator
(no subject) [message #719630 is a reply to message #719475] Sun, 28 August 2011 00:21 Go to previous messageGo to next message
Tom,
Gabor
(no subject) [message #719635 is a reply to message #719475] Sun, 28 August 2011 00:03 Go to previous messageGo to next message
Tom,
AWT 2-20ms
M`UC!SJ4\SU<G`-<9_V
MA=\E7&'N\@KJ0"<$4Z
MNO;BI;M7SYI?_(S9'/
M?2BV6BU)1ZO$=+CL
M+WX<&D#5OIB&B$]B
(no subject) [message #719636 is a reply to message #719475] Sun, 28 August 2011 00:21 Go to previous messageGo to next message
Tom,
Gabor
(no subject) [message #719638 is a reply to message #719475] Sun, 28 August 2011 00:03 Go to previous messageGo to next message
Tom,
AWT 2-20ms
[Updated on: Sun, 04 September 2011 00:20] by Moderator
(no subject) [message #719639 is a reply to message #719475] Sun, 28 August 2011 00:21 Go to previous messageGo to next message
Tom,
Gabor
Re: huge polyline performance [message #719650 is a reply to message #719600] Sun, 28 August 2011 03:20 Go to previous messageGo to next message
Well if it is only this one component you could simply use the
SWT-AWT-Bridge and embed your Swing-Control.
Tom
Am 28.08.11 06:03, schrieb andzsinszan:
> Tom,
> AWT 2-20ms
Re: huge polyline performance [message #719680 is a reply to message #719650] Sun, 28 August 2011 07:34 Go to previous messageGo to next message
Tom,
Thanks for the idea. Now I use SWT-AWT-Bridge. Rendering is as fast as with the Swing/AWT version.
There are some flickering issues during resize - I don't care much about it.
A snippet of the code for all those who are interested :
public class WavJPanel extends JPanel{
   public WavJPanel(Composite parent){
	Composite swtAwtComponent = new Composite(parent, SWT.EMBEDDED|SWT.NO_BACKGROUND);
	Frame frame = SWT_AWT.new_Frame( swtAwtComponent );
	frame.add(this);
	public void paintComponent(Graphics g) {
//-- etc.
Re: huge polyline performance [message #719800 is a reply to message #719680] Mon, 29 August 2011 00:54 Go to previous messageGo to next message
Although problem solved,i am curious why SWT is not performing well,
One thing i noticed is you are creating the Transform Resource again and again in each paint,Why not create it once in the constructor and reuse it..
Also setAntialias(SWT.ON); should also help
Try it i think this will make thire performances match.
[Updated on: Mon, 29 August 2011 07:10] by Moderator
Re: huge polyline performance [message #719801 is a reply to message #719800] Mon, 29 August 2011 00:57 Go to previous messageGo to next message
And i think this repeated posting is a bug,this has happened secound time in two weeks.
Re: huge polyline performance [message #719905 is a reply to message #719801] Mon, 29 August 2011 08:25 Go to previous messageGo to next message
vilay,
Thanks for your reply.
setAntialias(SWT.ON); helped a bit, but not too much (5-10% faster).
In order to reuse the transform, I have to reset it to the identity function.
transform.identity();
Doing some extra measurements, it seems that the real bottleneck is ''drawPolyline'',
The creating and setting the transform itself takes less than 1ms.
Thanks anyhow.
ps. the uploaded png-s appear as base-encoded ascii -> kinda difficult to overview the thread.
I noticed that treeview is fine.
Re: huge polyline performance [message #721543 is a reply to message #719905] Fri, 02 September 2011 01:00 Go to previous messageGo to next message
Just an idea...
Is it possible to create an image in the memory of the wave, and transform that image during user's resize events?
Perhaps, a thread in the background can recalculate the polyline and update the view later.
Oh, and during animations (~20fps) polyline is just too heavy : drawing an image would be faster I guess.
(animation : as the cursor runs with the audio play)
I used this kind of hybrid buffer technique on a stat project with R.
1. Swing GUI; R created images - through JNI calls - even for resize events (to handle ticks, linewidth etc)
2. during extensive R and slow I/0 processes the previous image was shown to the user - scaled if necessary.
Overall it had a feeling just as with web sites that load pictures gradually : first somewhat blurred, sharp when loaded.
So any ideas if/how a polyline can be painted to an Image in the memory? I will do some research on the weekend.
Re: huge polyline performance [message #721553 is a reply to message #721543] Fri, 02 September 2011 01:57 Go to previous messageGo to next message
It is possible and there is a snippet on similar terms but for GIF animation..
you can modify all the gif related code to your code..
http://git.eclipse.org/c/platform/eclipse.platform.swt.git/tree/examples/org.eclipse.swt.snippets/src/org/eclipse/swt/snippets/Snippet141.java
but in your case it would be a bit complicated since the wave render takes too long...
Hence you have to update the once created image with the changes on every thread call to avoid the overhead and also to avoid the image creation....
[Updated on: Fri, 02 September 2011 02:14] by Moderator
Re: huge polyline performance [message #737721 is a reply to message #721553] Sat, 15 October 2011 06:57 Go to previous message
Sorry, my follow-up is long overdue.
Here is what I did - in case someone is interested.
Although I worked with JLabel and AWT's 2D Graphics, I'm sure it's also doable with SWT as well.
//-- Creating the polyline with the zillion data point
GeneralPath polyline = new GeneralPath(GeneralPath.WIND_EVEN_ODD, samples.length);
//-- Painting a BufferedImage of the wave graph .
//-- The calculation takes place for each resize event.
//-- In order to avoid performance issues, resize events that
//-- are too close in time are collapsed (code omitted here).
BufferedImage waveAsImg = new BufferedImage(w, h, BufferedImage.TYPE_INT_ARGB);
Graphics2D g2 = (Graphics2D)  waveAsImg.createGraphics();
g2.translate(...);  //-- resize to fit JLabel (=my canvas)
g2.scale(...);
g2.draw(polyline);
g2.dispose();
//-- During paint only the memory-buffered graph is repainted.
//-- This allows for animations.
    super.paintComponent(g);
    Graphics2D g2 = (Graphics2D) g.create();
    g2.drawImage(img, null, 0, 0);
Previous Topic:Hide Shell
Next Topic:TreeViewer with only one TreeViewerColumn
Current Time: Wed Nov 05 08:05:51 EST 2025
Powered by FUDForum. Page generated in 0.09120 seconds
