Home » Eclipse Projects » EclipseLink » (no subject)
(no subject) [message #718546] Wed, 24 August 2011 12:10 Go to next message
Hi I am getting same error,
But i am using Eclipse , jdk 6, Jboss 5, Sporing message listener. Weblogic 11g is using to send messages . Getting messages from WL Queue to my app thru some logic.
I am able to print xml messages in the console, but getting exception before unmarshal this,
Code :
JAXBContext jc = JAXBContext.newInstance("com.bopeep.gen");
Unmarshaller unmarshaller = jc.createUnmarshaller();
// unmarshall into Classes from a File
bilgMsg = (BILGMSG) unmarshaller.unmarshal( new StreamSource( new StringReader(stringMessage)));
Please see the below error and help to resolve this
Exception:
11:41:49,475 WARN [DefaultMessageListenerContainer] Execution of JMS message listener failed, and no ErrorHandler has been set.
java.lang.ClassCastException: com.sun.xml.bind.v2.runtime.JAXBContextImpl cannot be cast to javax.xml.bind.JAXBContext
at javax.xml.bind.ContextFinder.newInstance(ContextFinder.java:149)
at javax.xml.bind.ContextFinder.find(ContextFinder.java:285)
at javax.xml.bind.JAXBContext.newInstance(JAXBContext.java:372)
at javax.xml.bind.JAXBContext.newInstance(JAXBContext.java:337)
[Updated on: Wed, 24 August 2011 15:01] by Moderator
(no subject) [message #719384 is a reply to message #718546] Fri, 26 August 2011 17:04 Go to previous message
Hi Chitti,
Are you attempting to use EclipseLink MOXy as your JAXB provider or the reference implementation? If you wish to use MOXy be sure to specify a file named jaxb.properties in with your domain classes with the following entry:
javax.xml.bind.context.factory=org.eclipse.persistence.jaxb.JAXBContextFactory
You also appear to be hitting a ClassLoader issue. You can try using
JAXBContext jc = JAXBContext.newInstance("com.bopeep.gen", DomainClass.class.getClassLoader());
-Blaise
[Updated on: Mon, 29 August 2011 10:09] by Moderator
Previous Topic:Incorrect OSGI versioning on milestone builds?
Next Topic:@PostConstruct method breaks DDL generation
Current Time: Wed Jul 23 04:25:21 EDT 2025
Powered by FUDForum. Page generated in 2.42244 seconds
