[ATL] Error loading file: ... The feature 'DFSResource' is not a valid feature [message #719239] |
Fri, 26 August 2011 09:54  |
Hi all,
I tried to load OWL.ecore (from UML to OWL of ATL Transformations Zoo) as an input model for my transformation (both using ant tasks and Eclipse configuration for latest ATL version) but got the following error:
BUILD FAILED
E:\Projects\Galileo Projects\ATL Transformations\Ecore2SynthesisApply-atl.xml:19: Error loading file:/E:\Projects\Galileo Projects\ATL Transformations\Metamodels\OWL.ecore: The feature 'DFSResource' is not a valid feature
But OWL model contains no such feature. It contains 'RDFSResource' class.
For some reason class name with first symbol being cut is considered as a feature.
I also have a similar problem with loading my own model as an input model. The error was as follows:
BUILD FAILED
E:\Projects\Galileo Projects\ATL Transformations\Ecore2SynthesisApply-atl.xml:19: Error loading file:/E:\Projects\Galileo Projects\ATL Transformations\Metamodels\Synthesis.ecore: The feature 'alues' is not a valid feature
As in case of OWL, my model contains no 'alues' features, but contains several 'values' features and 'Values' subpackage.
Again, for some reason, a name with first symbol being cut is considered as a feature name.
I tried to load these models with some earlier ATL Bundle (1.0.0) and they were loaded successfully.
Could someone please cast light on these strange errors?
Thanks in advance.
FUDForum. Page generated in 0.07111 seconds
