Home » Eclipse Projects » Standard Widget Toolkit (SWT) » No ToolTipText on Windows 7
No ToolTipText on Windows 7 [message #693811] Thu, 07 July 2011 04:46 Go to next message
Originally posted by: Thomas Barth
is it possible to get ToolTipText on a Windows 7 system? New users
(women only) of my application misunderstand certain buttons!
This is how I set the ToolTiptext
ToolItem toolItemBreak = new ToolItem (toolBar, SWT.NONE);
toolItemBreak.setToolTipText(ResLoader.getProperty("tool.Break.text"));
toolItemBreak.setImage(imgBreak);
I works on Windows XP and Linux.
Thomas B
Re: No ToolTipText on Windows 7 [message #693952 is a reply to message #693811] Thu, 07 July 2011 10:20 Go to previous messageGo to next message
ToolItem tooltips work for me on Windows 7 (tried 32- and 64-bit just to
be sure). Can you try hardcoding the value in the setToolTipText()
invocation, to ensure that ResLoader.getProperty("tool.Break.text")
isn't just returning an empty string? If this doesn't help, are there
any changes on your machine that might affect how a tab folder would
display/behave (choosing a non-default theme, etc.)?
Grant
On 7/7/2011 4:46 AM, Thomas Barth wrote:
> Thomas B
Re: No ToolTipText on Windows 7 [message #693981 is a reply to message #693952] Thu, 07 July 2011 11:11 Go to previous messageGo to next message
Hi Grant,
ResLoader.getProperty("tool.Break.text") returns a default string, if
the passed ressource doesnt exist (e.g. "E: tool.Break.text is
missing"). I ve also hardcoded the value but I still don't get a tooltip
on windows 7. I ve checked it on several win7 32/64 bit systems. I got
the info from the windows 7 users too. I didnt change anything on the
windows 7 systems.
Maybe my java compiler settings are wrong / outdated? All users have
Java 1.6.0_xx-bxx installed. But I still use the compiler compliance
level 1.5
and the JNLP file contains the element
<resources>
<j2se version="1.5+" />
<jar href="/my_application.jar" />
</resources>
Could this be reason ?
Thomas B
Am 07.07.2011 16:20, schrieb Grant Gayed:
> Grant
>> Hi,
>> Thomas B
Re: No ToolTipText on Windows 7 [message #718975 is a reply to message #693981] Thu, 25 August 2011 13:05 Go to previous messageGo to next message
I would like a solution to this problem as well.. Thomas, did you find a solution?
I am deploying our RCP application through web start on Windows 7 as well. All my SWT tooltips work fine when I run the application from within Eclipse or when I export as a standalone product with a .exe.
But they never show up when I run through webstart!
I am using version 3.7 for the target platform and java version 1.6.0_26.
I'm still investigating whether or not it has something to do with different startup parameters such as -clean -console -consoleLog -debug.
Another idea is differencec in how the equinox launcher is run.
Re: No ToolTipText on Windows 7 [message #718980 is a reply to message #718975] Thu, 25 August 2011 13:21 Go to previous messageGo to next message
It's not in the command line options for the launcher.
I do notice however that my webstart application does not have the windows-specific fragment bundle for equinox launcher (org.eclipse.equinox.launcher.win32.win32.x86_1.1.100.v20110502.jar) which contains a dll (eclipse_1406.dll). It doesn't seem to need this fragment to startup ok through webstart.
Does anyone know if this might explain the problem?
Re: No ToolTipText on Windows 7 [message #719201 is a reply to message #718980] Fri, 26 August 2011 07:29 Go to previous messageGo to next message
It's not in the Eclipse launcher but it is probably caused by (webstart?) calling AWT's Toolkit.getDefaultToolkit() before opening the workbench window.
See this bug report https://bugs.eclipse.org/bugs/show_bug.cgi?id=355541
Re: No ToolTipText on Windows 7 [message #719206 is a reply to message #719201] Fri, 26 August 2011 07:55 Go to previous messageGo to next message
For me it turns out to be the same as this bug https://bugs.eclipse.org/bugs/show_bug.cgi?id=349387 and can be solved by not using Sun's JDK 1.6.0_26.
Re: No ToolTipText on Windows 7 [message #719553 is a reply to message #719206] Sat, 27 August 2011 15:11 Go to previous message
Am 26.08.2011 13:55, schrieb SlowStrider:
No ToolTips
No FileDialogs
No native looking TabFolders
All bugs fixed in Java 7 :)
Previous Topic:SWT Text spell checker
Next Topic:Why not just Draw Labels,Instead of creating one?
Current Time: Sun Jul 27 09:37:48 EDT 2025
Powered by FUDForum. Page generated in 0.07194 seconds
