Populating a report using the Report Engine API [message #719196] |
Fri, 26 August 2011 07:06  |
I'm not sure if this is the right place to ask this question, so please bear with me if it isn't.
I'm using the BIRT Report Engine API to execute reports from my Java application. As I understand it, you would normally configure a data source and a data set within the report template. When the report is executed, this information is used to retrieve the data used to populate the report.
What I want to do is to provide the data used to populate the report directly from my Java application, without having to configure a data source and data set within the template. Is this possible?
Thanks in advance!
Re: Populating a report using the Report Engine API [message #719267 is a reply to message #719196] |
Fri, 26 August 2011 10:40  |
If you just want to push the data you could always add the object to the
appcontext from the RE API and then use a scripted datasource to iterate
over it. Or you could call the DE API from the RE API to add it
dynamically. I have a attached a scripted data source example that uses
the initialize event to load up a map that is then used in the scripted
data source. In your case you would load up the map in the RE API
program and set it in the appcontext like:
task.getAppContext().put( "mymap", loadedmapobject );
Then in the scripted data set open event you could get this object by
using the following:
reportContext.getAppContext().get("mymap");
The only draw back from this approach is that it will only work at run
time unless you implement the appcontext extension point for the designer.
Jason
On 8/26/2011 7:06 AM, Ross Freemantle wrote:
> the report.
> Thanks in advance!
FUDForum. Page generated in 0.04709 seconds
