Home » Newcomers » Newcomers » How do I remove obsolete or unwanted perspectives in the "next-perspective" dialog?
How do I remove obsolete or unwanted perspectives in the "next-perspective" dialog? [message #718572] Wed, 24 August 2011 13:21 Go to next message
When I press Ctrl-F8, that executes "next-perspective" which gives me the ability to quickly switch to another perspective. At the present time, there are perspective choices in this dialog that I don't care to ever switch to again, and there's even one corresponding to a plugin that isn't even installed anymore. How do I remove choices from this dialog?
(no subject) [message #718875 is a reply to message #718572] Thu, 25 August 2011 10:16 Go to previous messageGo to next message
> dialog?
That list is based on the perspectives that you currently have open.
Unless you've changed the default UI layout, the list of perspectives is
located in the upper-right corner of the Eclipse window. You can
right-click on a perspective and choose Close.
Eric
Re: (no subject) [message #718983 is a reply to message #718875] Thu, 25 August 2011 13:27 Go to previous message
Eric Rizzo wrote on Thu, 25 August 2011 10:16
> dialog?
Eric
This partially worked. There are two perspectives in that list that I don't care to see anymore. One of them is associated with a plugin that I still have installed, and another one is associated with a plugin that I uninstalled a long time ago (it has a default icon on it). When I selected "Close" on the former, it dutifully left the perspectives list in the upper-right and in the Ctrl-F8 list. However, the persistent one is still persistent. Selecting "Close" on that item does nothing to either the upper-right perspectives list or the Ctrl-F8 list.
Previous Topic:Helios bug? - project dependencies
Next Topic:JEE related keywords is showing errors in eclipse
Current Time: Sat Jul 26 09:34:38 EDT 2025
Powered by FUDForum. Page generated in 0.29762 seconds
