| Eclipse 3.0 M1 and Linux [message #71870] |
Wed, 02 July 2003 14:50  |
Originally posted by: abochert.tooligan.com
Hi!
I have a question: I try to run Eclipse 3.0 M1 under Linux (Mandrake 9.1).
Java-SDK (1.4.2) has been installed, PATH properly extended I get however
an error starting eclipse: an XML-file (plugin.xml) couldn't be parsed...
What is wrong?
Thanks for every answer
Artur
| Re: Eclipse 3.0 M1 and Linux [message #73631 is a reply to message #71891] |
Mon, 07 July 2003 13:36  |
Originally posted by: jared-eclipse.mn.rr.com
The stack trace says unexpected end of file. Sounds like your install is
corrupt. Maybe you got a bad download or unzipped the archive incorrectly
(using jar instead of unzip?)?
- Jared
Artur Bochert wrote:
> Starting Eclipse for the first time (please wait... complete the
> install...)
> Error dialog: Problems during startup. Check the \".log\" file in the
> \".metadata\" directory of your workspace.
> /home/artur/workspace/.metadata/.log:
> !SESSION lip 02, 2003 19:10:22.73
> java.version=1.4.2
> java.vendor=Sun Microsystems Inc.
> BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=pl_PL
> Command-line arguments: -os linux -ws gtk -arch x86 -install
> file:/home/artur/Apps/eclipse/
> !ENTRY org.eclipse.core.runtime 2 1 lip 02, 2003 19:10:22.74
> !MESSAGE Problems encountered loading the plug-in registry.
> !SUBENTRY 1 org.eclipse.core.runtime 2 1 lip 02, 2003 19:10:22.74
> !MESSAGE Parsing error in \"plugin.xml\" [line -1, column -1]:
> \"Unexpected end of file\".
> !STACK 0
> org.xml.sax.SAXParseException: Unexpected end of file.
FUDForum. Page generated in 0.26836 seconds
