Home » Eclipse Projects » EGit / JGit » Tag icons
Tag icons [message #718902] Thu, 25 August 2011 10:29 Go to next message
I see two different tag icons in the 'Git Repositories' view: a "normal"
one which is also used for local tags and one with some sort of dark
blue angle on the left side.
What I wonder is why are my own tags, even if pushed to the shared base
repository and then fetched in another workspace (and hence no longer
local) still show up without that dark blue angle? Or is that blue angle
meaning something different?
Dani
Re: Tag icons [message #718937 is a reply to message #718902] Thu, 25 August 2011 12:08 Go to previous messageGo to next message
The blue L-shaped angle decorates light-weight tags which don't have a tag message.
The user guide [1] should show the corresponding icons, I will add that.
[1] http://wiki.eclipse.org/EGit/User_Guide#Light-weight_and_Signed_Tags
Re: Tag icons [message #719179 is a reply to message #718937] Fri, 26 August 2011 04:44 Go to previous messageGo to next message
> tag message.
The user guide also says that the lightweight tags are shown in yellow.
While that's true, non-lightweight tags also appear in yellow, so that
sentence is a bit confusing.
Dani
Re: Tag icons [message #727714 is a reply to message #719179] Wed, 21 September 2011 17:11 Go to previous message
I added some screenshots to [1] to explain this better.
Previous Topic:Retrieve Tag information using JGit API
Next Topic:[Announce] JGit / EGit Release 1.1
Current Time: Thu Jul 24 23:17:56 EDT 2025
Powered by FUDForum. Page generated in 0.07850 seconds
