Home » Archived » M2M (model-to-model transformation) » [QVTo] How to extend a model
[QVTo] How to extend a model [message #697089] Fri, 15 July 2011 09:52 Go to next message
Hi all,
I'm new to m2m transformations,
Is there a way to transform a model A to a model B (conforming to the same metamodel, UML in my case) in which, for example, the model elements of B are the same model elements of A except for the addition of some properties (like a stereotype, or and extended name)?
Is there a way to "clone" elements and then add or change some of their properties?
Since I didn't find a way to do this, I just tried to change the name of the UML::Model element with the following in-place transformation:
modeltype UML uses "http://www.eclipse.org/uml2/2.0.0/UML";
transformation NewTransformation(inout source:UML);
main() {
 var m := source.rootObjects()![Model];
 m.map toNewModel();
mapping inout Model::toNewModel(): Model{
   name := self.name + 'newName';
Unfortunately the output is the same model with the actual UML::Model element (which I meant to change) with the name correctly set to the new one BUT with an additional UML::Model element which is void.
I managed to change the name of the model without introducing a new UML::Model by using a helper function, but this does not generate a .trace file which I need.
Anyway this is not what I want, I did it just for practice.
What I really need is a transformation with a input UML model and an output UML model, in which the output file is the same of the input except for additional properties.
Is there a way to achieve this?
Re: [QVTo] How to extend a model [message #697095 is a reply to message #697089] Fri, 15 July 2011 10:11 Go to previous messageGo to next message
Hi Alex
The lack of a 'clone' or 'copy' is a significant language omission.
Ed Willink
On 15/07/2011 14:52, --alex-- wrote:
> Hi all,
> their properties?
> main() {
> m.map toNewModel();
> Anyway this is not what I want, I did it just for practice. What I
Re: [QVTo] How to extend a model [message #718617 is a reply to message #697089] Wed, 24 August 2011 16:55 Go to previous messageGo to next message
Hi Alex,
Consider using .clone() and .deepclone() methods. First creates shallow copy of the object, second creates deep copy.
For example:
var m := source.rootObjects()![Model].deepclone().oclAsType(Model);
Sergey
Re: [QVTo] How to extend a model [message #724021 is a reply to message #718617] Sat, 10 September 2011 07:22 Go to previous message
Thanks for your replies.
I finally end up by creating a, successful, INOUT mapping.
I did not try .clone and .deepclone since I read they cause problems with Stereotypes and my models depend heavily on Profiles!
Previous Topic:[QVTo] UML Stereotypes application not set when launching transformation from Java
Next Topic:[QVTo] factoryEntries in class EclipseRegistry/ interface UnitResolverFactory are empty
Current Time: Wed Jul 23 06:45:11 EDT 2025
Powered by FUDForum. Page generated in 0.06539 seconds
